BEN’S WORKSHOP By Ben Myers The latest version of SpinRite, long regarded as the go-to software to recover data from corrupted hard drives, adds testi
[See the full post at: SpinRite 6.1 offers us help for solid-state drives]
Home » Forums » Newsletter and Homepage topics » SpinRite 6.1 offers us help for solid-state drives
- This topic has 35 replies, 13 voices, and was last updated 3 months, 3 weeks ago.
AuthorTopicViewing 15 reply threadsAuthorReplies-
WSRolandJS
AskWoody PlusDecember 16, 2024 at 4:25 am #2726102Check with a few data recovery specialists on well-known, well-respected data recovery discussion boards and with their companies.
A while back, there was very in-depth, thorough documentation about how many recent hard drives, hybrids, solid states, etc., work. Also, caution was encouraged about Spinrite 6.0 and 6.1 and other similar products. Caution is necessary because such products might clash with the low-level workings of recent and present-day hardware.
I have used Spinrite 6.0/6.1 in my 100MB+ hard drive/DOS 3.3/Windows 3.11 days. It was a hard drive report card tool for me.
Test on non-critical hardware before using such products on business hardware.
JRichards
GuestDecember 16, 2024 at 9:13 am #2726162I recently bought Spinrite only to find out after the software arrived that it doesn’t work on any drive exceeding 2 TB (they don’t seem to advertise this fact). I don’t think anything has changed since then. When I complained about the deficiency they refunded my money, but I wasted a lot of time finding out something that should have been stated on the top of the page. I like the concept of Spinrite, and if they have fixed this issue, I would buy it again. You should have mentioned this in your article (unless I missed the mention, or you also didn’t know).
AskWoody PlusDecember 17, 2024 at 1:15 am #2726354SpinRite 6.1, the newest version, can handle multi-TB drives, subject to BIOS limitations. See this post by Steve Gibson on the GRC Forum:
There’s no maximum for SpinRite. Some early testers used 16TB drives, and I have one here that works nicely.
By the way, SpinRite 6.1 also runs much faster than 6.0.
rbailin
AskWoody PlusDecember 16, 2024 at 9:33 am #2726167Could you please explain why there is difference in the data transfer rate between the “front”/”midpoint”/”end” of SSD drives? There’s no rotational delay or seek time on SSD’s, and no physical track size differences between the first and last tracks. One would think that all sectors would have the exact same access times and transfer rates. (One of the reasons that optimizing an SSD offers no benefits.)
And why would re-writing the entire SSD slow down the transfer rates on non-SATA drives?
JulianHicks
AskWoody PlusDecember 16, 2024 at 10:32 am #2726184The apparent reason is because firstly, SSD drives emulate disk drives in that the OS treats them like HDDs using LBAs [Logical Block addresses]. HDDs and SSDs are treated as if the device has a consecutive set of blocks starting at LBA 0 and ending at LBA n [where n depends on the drive size].
Low number LBAs are at the ‘front’ of the drive, high number LBAs are at the ‘end’ of the drive.
OS systems tend to allocate data with low LBA numbers first so the device slowly fills up from the ‘front’ to the ‘end’. So typically Windows is installed at the ‘front’ and other ‘stuff’ at the middle or near the ‘end’.
The final part of the explanation is that SSD data has been found to deteriorate so the ‘read only’ predominant nature of Windows files means that portion is likely to deteriorate more than at the ‘end’. The ‘middle’ and ‘back’ blocks to be rewritten more often and their ‘quality’ is restored.
I think the deduction is that the SSD read rate across the drive is consistent with the interface performance, but what you see at the ‘front’ is the hidden drop in performance by the hidden read retries by the controller due to ‘bit deterioration’.
It’s well worth fully reading the Spinrite FAQ pages…
Regards – Julian
Jim Wooden
AskWoody PlusDecember 16, 2024 at 10:17 am #2726179I’ve been a subscriber to SpinRite since I think V3.1, still have it.
For my everyday machines I monitor the SSDs with this: https://www.hdsentinel.com/
Dynamite program and the developer is VERY responsive.
For the record, I’m just a happy customer, I have no affiliation w/ the company.
Jim
JulianHicks
AskWoody PlusDecember 16, 2024 at 10:44 am #2726189Ben, I think I’d agreee with anyone that the Spinrite 6.1 write up is not totally clear!
Personally I think I’ve deduced that the Spinrite 6.1 update only works ‘properly’ with direct SATA interface SSDs and not with USB or Nvme ones. The FAQ for Spinrite does explain this, as the 6.1 version requires a BIOS boot. Although the code apparently has direct PATA and SATA interface drivers, it relies on BIOS interfaces for USB and Nvme which slow it down! That’s why your NVME performance figures don’t seem to be ‘right’.
We all need to wait for Spinrite 7.0 which will ‘UEFI boot’ and have native USB and Nvme drivers to perform ‘properly’ for a true evaluation.
Julian
AskWoody_MVPDecember 16, 2024 at 2:39 pm #2726257Hey Ben,
Nice article and got me to dig out my Spinrite 6.1 USB and play a little.
I noticed that if you are using an EXTERNAL USB drive enclosure:
- Spinrite may not recognize a drive in certain USB enclosures. No problem with others.
- When trading USB devices you need to have them connected then RE-BOOT from the Spinrite USB to have the device recognized.
So far I’ve done one 500 GB WD 2.5″ drive on level 2 (it’s old and wanted to fully check it’s integrity) a Crucial 128 GB SSD on level 3 (this one has had problems in the past and eve had it’s cover lifted to look inside. It’s now held together with packing tape). It worked fine. I currently have a 1 Tb 2.5″ HDD running on level 3, time estimate 13+ hours!
LolPhirae
Guest -
Paul T
Mike
Guest -
Paul T
LolPhirae
GuestDecember 18, 2024 at 8:21 pm #2726665You need to justify this claim. What evidence do you have?
You are welcome to read e.g. this thread at https://www.hddoracle.com/viewtopic.php?f=36&t=2929 or many others. SpinRite may actually harm your data recovery efforts by doing writes/erases on already damaged media, or it will just return random garbage, or… Most of the marketing claims are really just – pseudoscience and pure snake oil.
Do yourself a service and use something like ddrescue for your data recovery attempts. In addition, the basic principle here being to offload the data somewhere else, not to mess with faulty media.
Paul T
wavy
wavy
AskWoody PlusJanuary 2, 2025 at 5:57 pm #2730773I can see that now, many useful improvements including speed.
But still a Bios boot not UEFI.
I was hoping that purchasers of 6.1 will not be able to upgrade to 7 for free but you only will get a reduced price.
Just because you don't know where you are going doesn't mean any road will get you there.1 user thanked author for this post.
heretick
AskWoody PlusDecember 25, 2024 at 1:37 pm #2728478Hello all, real noob here. Could I use SpinRite to recover a SSD drive that Win 10 has somehow suddenly stopped recognizing? All File Explorer shows now is one big C drive (contains OS), but the former larger partition D drive (all saved data) is no longer visible/appears to no longer exist …
Thank you for any light you can shed on this – sorry for my noobiness!
ManagerDecember 25, 2024 at 1:47 pm #2728482Are you using Win10 or Win11? What version 22H2 or 22H3? What Edition of Windows, Home or Pro?
How large is the SSD? In the search bar type “Disk Management” (without the quotes) and press Enter. When the window pops up, stretch it side to side in the display and take a screenshot of the center panel. Post the picture here as an attachment.
heretick
heretick
Paul T
heretick
AskWoody PlusDecember 25, 2024 at 2:53 pm #2728508It has Win 10 Home 22H2, disk mgmt shows abt 237 gig size SSD – but –
When I first bought this Asus laptop new, I partitioned the hard drive to give C:\ for OS about 35% of space and the rest to D: to save data, pics, files, etc. All of a sudden can’t see the data partition/drive letter anymore in Windows File Explorer, afraid won’t be able to recover files
JulianHicks
Paul T
AskWoody MVP -
heretick
ManagerDecember 25, 2024 at 4:06 pm #2728534Did you have a second disk in the computer or an external one attached to it? It iappears that the disk you are showing is 256GB, not the 1TB it would have to be if you also had a 650GB partition for a D: drive. Is there a second drive that is not showing/working/installed/connected?
Run msinfo32 and see what size SDD it reports.
BTW, do you not have a backup of your data?
heretick
AskWoody PlusDecember 27, 2024 at 6:04 am #2728960It’s my poor eyesight + crummy memory…it is, in fact, a 256 G SSD, after looking up make and model, ASUS Vivobook 17″ X705 Micron MTFDDAV256TBN-1AR1ZABYY 256GB SATA Solid State Drive intel core i7-8565U CPU 1.80 GHz 4 cores 8 threads
No recent backup, unfortunately (so dumb!!!), now guessing all my data previously saved in D is gone…
Manager
AskWoody PlusDecember 25, 2024 at 4:29 pm #2728537Could I use SpinRite to recover a SSD drive that Win 10 has somehow suddenly stopped recognizing? All File Explorer shows now is one big C drive (contains OS), but the former larger partition D drive (all saved data) is no longer visible/appears to no longer exist
It sounds like your SSD may have developed some kind of problem with the drive’s formatting and file index. Others may have a better diagnosis, but if what I said is the case, then I doubt that SpinRite will help with your issue. SpinRite is designed to “refresh” sectors where the data signals have weakened and are in danger of being lost. It’s designed to fix weak data sectors, not drive formatting gone bad.
Sueska
Manager -
AskWoody PlusDecember 27, 2024 at 6:48 pm #2729156Owners of SpinRite version 6.0 (such as me) got 6.1 at no extra charge. However, owners of version 6 (and presumably 6.1) will be able to get the next version, 7.0, at an unspecified “reduced price“.
Looking around a bit, it seems that decades ago, Steve charged $39 to licensees of SpinRite 3.1 or 4.0 who wanted to move to the then-new version 5.0. (Note that the full price for new owners was $89, where it still is today!)
EP
AskWoody_MVPJanuary 27, 2025 at 2:45 pm #2743099I’d be very careful & cautious in using SpinRite as mentioned by this person:
https://www.disktuna.com/and-now-im-done-with-steve-gibson-and-spinrite/
Viewing 15 reply threads -
Davidhs
52 minutes ago -
5 hours ago -
MS Office 365 Home on MAC
MickIver
6 hours, 59 minutes ago -
19 hours, 3 minutes ago -
J9438
20 hours, 35 minutes ago -
17 hours, 35 minutes ago -
dmt_3904
18 hours, 23 minutes ago -
Login screen icon
8 hours, 46 minutes ago -
AI coming to everything
4 hours, 45 minutes ago -
2 days, 5 hours ago -
No Screen TurnOff???
BigDaddy07
2 days, 18 hours ago -
n0ads
2 days, 4 hours ago -
You can’t handle me
3 hours, 10 minutes ago -
1 day, 21 hours ago -
3 days, 5 hours ago -
2 days, 8 hours ago -
Lumma malware takedown
EyesOnWindows
3 days, 14 hours ago -
Meet Gemini in Chrome
3 days, 18 hours ago -
Trump signs Take It Down Act
4 days, 2 hours ago -
2 days, 7 hours ago -
3 days, 5 hours ago
