Hi, I have been using a dynex switch box for 3 computers to access the internet with no problems. A few weeks back verizon (dsl) had me configure a new connection due to a problem. I am running XP prof. 2002 sp3. Since the change we can only connect one computer at a time. Keep getting the limited connectivity box on my taskbar. I know very little regarding the info below but thought it may help. I also have three connections in my network connections folder they are my verizon online connection, local area connection 2, and local area connection (which I think is broadcom netextreme gigabit ethernet). Have been looking around trying to find just what all the TCP? DNS? and other terms and choices are and which ones should be checked but have had little luck. You guys through this and windows secrets has saved me many times. Appreciate any help.
esmd3
.Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:Documents and SettingsWindows XP>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : your-6c37980b86
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . : 00-18-71-6C-8C-83
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 169.254.55.84
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : Westell WireSpeed Dual Connect Modem
Physical Address. . . . . . . . . : 00-60-0F-E7-9D-2F
Autoconfiguration IP Address. . . : 169.254.131.88
PPP adapter verizononline:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 108.8.57.68
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 108.8.57.68
DNS Servers . . . . . . . . . . . : 71.242.0.12
68.237.161.12
NetBIOS over Tcpip. . . . . . . . : Disabled
