• Major problem, computer do not start. (XP Home SP1)
    Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » Major problem, computer do not start. (XP Home SP1)
    Now there are BIG problems. Anyone who read my post “Damaged system files or …”, and SMBP you kindly gave some answers. Well, as I did have some work to finish I didn’t get to the point where I would just Format/clean install.
    Sigh, for the moment I’m up and running from my old 486-DX266 (W95/IE5.0-crap and no protection ), it does not have the programs or files I need for the moment or anything else.
    This morning I found that Media player 9, also patched som weeks ago, didn’t want to run,. Something about wmp.dll was not expected version (don’t remember, 3980 and it was 2980). Forgot about it, had to do some work. This afternoon the #%!& machine suddenly did the “twice reboot” and froze in boot menu.
    I rebooted, chose RC from boot menu, ran chkdsk C: /r. It did some of it’s testing and the froze on 14%. Said something about irrevocable failure, then it rebooted.
    Up came blue screen; Windows has been shut down Page_Fault_in_Nonpaged_area. If first time restart otherwise try this or that …
    Tech. info. STOP:0x00000050(0x8B000346,0x00000001,0x807C9EC1,0x00000000).
    OK, I have not installed anything lately etc. etc so what could I change, started Safe Mode, nothing special in Event viewer: I had deactivated some unnecessary services many months ago, only thing I could think of, so I turned them back in previous status, auto, manu. Also I did reinstall Media player patch. Rebooted this time nothing happend, the machine froze before BIOS-process, on this machine there is a “screen” first at boot up that shows info about graphic card: “Nvidia geforce4 MX 440 bios …” or something like that.
    Turned machine of, waited, rebooted and it started to reboot by itself.
    I don’t know what to do next, as I said, I was preparing a clean install. Almost everything is on back up etc. But I have some work to finish.
    Regards,
    Argus
    Viewing 5 reply threads
    • #713043
      Argus,
      From the sounds of it, DO IT.
      Bob
      • #713081
        Yes, that would probably help… but I have some work on the machine I just need to have finished until to-morrow.
        Of course I didn’t ask the question so I shouldn’t expect an answer, but what can cause the message: page fault in nonpaged area? So far I’ve seen almost everything explained with that; memory problems the most. In some cases people have been mixing memory modules, and tweaking them etc. That’s not the case with this machine.
        I had a feeling that something was very wrong even though as described in post “Damaged …”, it only looked as DirectX was involved. That censored thing is hard to correct. Dxdiag, when run, said no problem and reported 8.1. Of course no problem as it was old dxdiag, which somehow replaced newer one in System32. If I looked for the new one in registered pack and run it (9.0b) it found problem and said; try to reinstall.
        Well my tools are: complete package of 9.0 (localized for my language), patch 819696 (localized whatever). Since I some month ago had applied patch 819696, the version registered is 9.0b, thus the system tells me when I try to install 9.0 complete: “install has finished” after just one second. I have seen the help on this matter, conclusion install newer version. Well do we have a newer version, No! Of course I could d/l a complete 9.0b, 32-33 MB, but that is way to much. I have the essential files: 8.1 org. disk, 9.0 complete pack, and the patch to 9.0b. But there is no way round. And since I ran sfc, described in earlier thread, some files got messed up.
        Thanks for your answer
        Regards,
        Argus
        • #713091
          Argus,
          Page fault in non-paged area is almost ALWAYS a memory problem of one sort or another. Depending on how much RAM and how many “sticks” of memory you have, you could try pulling the sticks and cleaning them lightly with a “pink pearl” eraser on the contact strips, then re-inserting them. Also, if you have more than one stick you could remove one at a time to see if you still get the error. If yes, put the first stick back in and remove the other in a process of elimination. Maybe you could at least do this until you complete the intended work.
          If still NG, then get out the BIG ERASER and wipe it all out with a clean install. disappointed
          Bob
          • #713107
            Bob
            Thanks for your answers. Yepp, I agree about memory. But I’ve seen that people said they got that message when trying to install a new hard drive etc. etc. It was hard to find anything on MS pages about “page fault…”, but then again this is a so censored slow machine I’m working from (486, 20 MB) I could stand waiting to search for ever.
            Well, in my case the memory part is easy since I only have one stick on that machine. Before I do the clean install I will surely take a look inside the machine.
            Thanks so far, I will log off and try to start the other (it’s going to be a long night).
            Regards,
            Argus
            • #713299
              Argus, STOP! Don’t do it! You CANNOT install Windows XP on your computer!
              You need at least 266 MHz processor and 64 MB of RAM to make WinXP to run as fast as a turtle.
              See Windows XP Home Edition System Requirements for more information.
              The best decision for this machine (486, 20 MB) is Win98 SE. (486 processor runs usually at 20 MHz, NOT 486 MHz – remember it!)
            • #713408
              kaplinb,
              I think Argus is talking about his other ( newer) machine, NOT the 486,that he is temporarily using until he can get his other system running on XP. He said in his first post that he is using the 486 as a temp. yikes
              Bob
            • #713598
              kaplinb
              Thanks for your concern, but as Bob wrote, and I wrote earlier, my interim solution is to write this on an ten year old machine. The machine having problem (with XP) is well equipped to handle the OS. I didn’t mention anything about tech. data for the XP machine, sorry for that. For whatever it worth, the XP Home machine is a:
              AMD athlon XP1800+, 256 MB, 80 GB, 64 MB Nvidia.
              kaplinb, Bob and anyone
              But when we are talking about both machines; it’s almost funny to compare. During the last night I have had more problems with the new one than the old over a period for ten years. Even the battery is still same in the old. I installed w95 1996. With the new one (1 year old) I don’t know what to expect next. I did manage to copy the important files I was working on, between the reboots. And for the rest; I now have everything, almost, on back up.
              Durng the last 24 hours my XP machine have rebooted in every possible way. If I, for instance, myself booted and started Recovery Console from boot menu in the purpose to check for errors from last reboot, I could end up with machine froze at half way in typing password, then suddenly a reboot. Another time the monitor was blank, as if it didn’t got any signal. So my question is: do the machine have some hard ware problem, that needs to be fixed before a clean install? Some times, as when it froze before BIOS, how can I start a clean install/format from the XP CD when the machine does not get pass BIOS. But then again other times it’s no problem… During this process I didn’t get any error message, only thing was the chkdsk report in event viewer. And at one occasion problem with ZoneAlarm.
              Last night I took a quick look inside the XP machine, everything seems to be ok. Nothing loose. The memory stick is a little hard to reach, it’s tight, so I didn’t try to pull it out just to check.
              Regards,
              Argus (who slept 3 hours the last +36…).
            • #713613
              Hi Sleepless in Sweden, Argus,
              Everything keeps coming back to memory problems. It seems if I were in your shoes, I would first try pulling that memory stick out, checking and cleaning as I first described, then reseat it back in another memory SLOT if you have more than one.
              That failing, I would buy another memory stick or even borrowing one from a friend to try, with the original one removed.
              Still NG, I would strip out everything from the MB, except the HD, video card and minimum RAM. Adding one additional piece of hardware at a time to see if I could find a fail point.
              Somewhere in here I would attempt to wipe the MB clean and try for a fresh copy of XP.
              If STILL no go, I would be faced with the potential of a bad MB or CPU. Depending on your finances of course, I would probably get a new replacement MB & CPU combo.
              Not an easy task, for sure, but you seem to have a variety of potential problems to solve. groan
              Bob
            • #713634
              Bob
              Thanks for your reply. Yes, as you said earlier, I will try to take look at the memory stick and also move it to another slot. I also have a Ethernet card on PCI that I don’t use, could try to take it out and as you mentioned check with minimum hardware in place and then add.
              Well, first it’s time to get some rest.
              Regards,
              Argus
            • #713794
              Argus,
              Windows XP itself is very stable operating system. If you have all kinds of problems during bootup, I would suspect the hardware. It can be motherboard, memory, processor and even power supply. Memory is the easiest thing to check. (Remember: the video card has memory also, so the problem with video adapter can interrupt system memory functioning.) Then, if different kinds of problems still remain, it can be power supply: slight power fluctuations can significantly disturb your computer functioning. If your computer is still under warranty, I would recommend to contact your vendor.
            • #714630
              kaplinb
              I agree XP is very stable. That is the reason why I got worried from the error message that time, and also the machine is so new that I would not think of hardware problem.
              Thanks for your tips
              Regards,
              Argus
            • #714631
              kaplinb
              Regards,
              Argus
            • #713795
              Argus,
            • #713635
              Bob
              Regards,
              Argus
            • #714628
              Bob
              Yes, your’e right, sounds like memory, but I could not understand (or didn’t want to) why hardware failure, because the computer is only 12 months old. Anyway, I checked the memory, looks fine and clean. I moved it from slot 0 to slot 1. I only have on memory stick with 256 MB. Before I moved it the computer had been turned of for some day, after all the rebooting.
              Well, after the move I turned it on, changed quick power on self test in BIOS to do a full check on start. No problem!
              One funny side effect. I had a question in an earlier post with programs like Sandra, Aida32 and windows system reporting more memory than installed. That time it looked like this:
              Bank 0 256 MB
              Bank 1 Empty
              Bank 2 512 MB
              Thus 768 MB, even if there only was 256 MB installed. No, big problem. The censored who built the machine may have programmed wrong info. to DMI.
              Now it looks like this
              Bank 0 512 MB
              Bank 1 Empty
              Bank 2 512 MB
              As I said, I moved memory stick to Bank 1 and this is programmed to DMI as empty… So now AIDA32 DMI info shows me 1024 MB, but installed memory is shown as 256 MB. Also Windows System info. from Help/about, About this machine shows 1024 MB.
              Funny, but it works.
              Also, I found a loose screw inside the machine! Ah well, not the first time. I can not find anything were it should be placed. When the machine was only 2 months I had problem with a CPU fan and had to send it for a change. That time I also found a loose screw. Those censored censored who built the machine had missed one of the screw to the MB, and I had to put it there myself.
              Regards,
              Argus
            • #714644
              Argus,
              The probability of hardware failure is HIGHER in the first few months of operation than after a longer period. This has been statistically proven in engineering circles and is the reason why a new product should be given a “burn in” time, to discover weakness in any component or the circuit design itself.
              At any rate, besides the memory reporting error, does it seem that you are up and running OK now? crossfingers
              Bob
            • #714668
              Bob,
              Yeah, I should know that, I am a engineer (not data, electronics etc.). You are right, almost every man made system have a probability of higher failure rate first period.
              Some minutes ago I was in the process of writing this answer to you, and exactly when I was going to write: “it now seems OK”, BANG. Blue screen:
              BAD_POOL_CALLER
              STOP: 0x000000C2 (0x00000007,0x00000CD4,0x00000000,0xE2107f08)
              censored censored A short search shows something about driver problem. Result includes MS info at KB314492. I really don’t know what to do next…
              To my knowledge I only have two drivers not signed by MS etc. and it’s to my modem and sound. Over the last year it’s been hard to find, for instance a specific XP driver for my modem. They say it’s XP driver on the manufacturer site, but may seem like a win2000, and from my point of view should that not be a big problem.
              Regards,
              Argus
            • #714669
              Bob,
              BAD_POOL_CALLER
              Regards,
              Argus
            • #714688
              Argus,
              Get some info re: bad_pool_caller at 0xc2
              There is a table of codes to determine the type of bad call.
              Also, it mentions a driver verifier utility you can access by going to Start>Run and typing verifier to find out what drivers are unsigned in your system. Then chase after getting updated drivers from the manufacturer if possible. Some obscure drivers can be a real pain to find, I know.
              Bob
            • #714689
              Argus,
              Bob
            • #714725
              Argus–
              I second Bob. I PM’d you I believe to check drivers when I first saw that memory stop message. If you tell me what your modem make and model is, I’ll try to find the best driver and show you the site I used.
              The KB they refer you to is this one, and unless you’re a developer or someone who is able to debug it’s not going to help
              314492: How to Debug a Stop 0xC2 or Stop 0x000000C2 Error
              So what do you do:
              1) Check the drivers and give me the modem maker and model number.
              2) Like a high percent of stop errors, this error is the result of a faulty driver or software. You want to really make an attempt to get the latest drivers and check device manager for any clues, bangs, any thing else that looks suspicious. If you recently installed any drivers, you might roll back to see if that makes this go away.
              3) Consider any recent maintainance on the system.
              In device manager, right click your devices and select Properties. Click the driver tab then click the Rollback Driver button.
              You could still have some incompatible hardware somewhere or an internal hardware problem on the device itself.[/i]
              Notice on the site linked below, there is an XP compatibility list on the task pane that slides out for all types of modems.
              You can also check the Windows XP Hardware Compatibility List by clicking on the particular device type in the column on the left–and verify your device is on the list. If it is, and you have the proper driver, then zero in on the hardware device and see if it is failing. The device vendor site often has diagnostic utilities you can run on the device–or you could pull that device version from another system.
              There are also Driver Testing Download Kits but I’ve not used them.
              SMBP
            • #715322
              (Edited by Argus on 16-Sep-03 11:52. Added more info.)
              Bob and SMBP
              Yes, drivers seems to be in conflict one way or the other.
              Primo: I think, still, that having some of my DirectX files messed up, older together with new, might be a major problem that can cause errors in many ways. Exactly how DirectX works together with my graphic driver Nvidia (40.72) in day to day use I don’t know. I can understand that it can be big problem in games. Since some days back I can not run Media player 9., as described earlier. First error was that it did not get the expected version (2980 inst. of 3008?). I had the latest patch for WMP 9. So I reinstalled it, now it only say something: unexpected error.
              Secundo: I have updated my audio driver some hours ago. In my case, onboard (ECS K7S6A mainboard), it is the SiS7012 driver from ECS, v 1.10 which I think is WHQL. I don’t think my previous version was WHQL. I also checked/updated the AGP driver from SiS to latest 1.16a.
              Tertio: I’ve checked the “Verifier”, before I only know about “Sigverif”. I realy don’t know how I should use Verifier, and MS certainly don’t put much help in the help files. With Verifier in “standard settings” it finds some drivers not signed. Before audio was included not after new driver. The rest, all but one or two, are related to Roxio CD-burner program. I use Easy CD and DirectCD.
              I also have one question, and I don’t know if it has something to do with my described problems. When I did a check with “Sandra” some month ago I saw one line in report: “Disabled host controllers are present. Check BIOS Settings.” I do not know how I should interpret this?
              Regards,
              Argus
            • #715380
              OK, for the moment is the subject not completely true. It is possible to start the computer etc. if you’ve followed the thread.
              To day I also found my Media Player 9 files so I could do a reinstall. It worked very well, the patch KB 819639, is already there and will not install again. So far WMP is up and running like ever before.
              Thats always something…
              Argus
            • #715381
              Argus
            • #715323
              Bob and SMBP
              Regards,
              Argus
            • #714726
              Argus–
              So what do you do:
              SMBP
            • #714645
              Argus,
              Bob
            • #714629
              Bob
              Bank 0 256 MB
              Bank 1 Empty
              Bank 2 512 MB
              Bank 0 512 MB
              Bank 1 Empty
              Bank 2 512 MB
              Regards,
              Argus
            • #713614
              Bob
            • #713599
              kaplinb
              Regards,
            • #713409
              kaplinb,
              Bob
            • #713300
          • #713108
            Bob
            Regards,
            Argus
        • #713092
          Argus,
          Bob
      • #713082
        Regards,
        Argus
    • #713044
      Argus,
      Bob
    • #714219
      Okay Argus–Round II:
      The page fault error message is strongly diagnostic of a hardware problem that needs to be corrected, particularly in conjunction with the symptom of running chkdsk /r from RC and getting repeat errors on serial runs. If that’s the case, formatting and reinstalling the operating system a hundred times a day for the next hundred days is not going to solve the problem–that’s why these error messages are different and numbered.
      Since you realized 3 days ago, that you should turn on System Restore so you can have it available for XP CPR did you in fact turn on System Restore?[/i]
      If someone has not shown you how to use the MSKB or google for error messages and the many sites that specialize in defining error messages, PM me and I’ll help with that.
      Page Fault in a Non-Paged Area Good Ole Stop in the Name of Love 0X000000X50[/u]:
      Microsoft MVP Jim Eschelman’s Article on this Error and Memory Problems
      Here’s the skinny on this: This error occurs when requested data can’t be found in memory[/i] and check your Network card placement because it can sure be a cause. So can a driver that’s corrupt or deteriorated. For example, an incorrect video driver can cause a video RAM related paging error. I would check manufacturers of my major hardware for driver updates and also device manager for bangs.
      It’s probably related to a hard disk fault which isn’t surprising with the repeated errors you report on serial chkdsk runs. Did you recently add RAM and was it compatible with the previous RAM memory stick?[/i] Don’t limit this to only system ram. This error can also be caused by any of the following being bad:
      1) Main memory
      2) L2 Cache
      3) Video RAM
      The easiest way to make the diagnosis here and isolate the problem is to replace what’s suspected of being bad with something good. That means replacing the video card if suspect; checking the memory sticks for compatibility; detecting a problem with onboard Cache by disabling cache in the BIOS; then your system is going to run like a slug, which is normal when you whack the onboard cache from the bios, but if the stop error message goes away you need to replace the motherboard most likely.
      You can quickly replace RAM chips to see if the problem is corrected. If several sticks of RAM are already in the system, then replace one at a time and then reboot to see if the problem disappears and you have your diagnosis there.
      Software doesn’t get a pass with this problem as with most hardware problems, but again just blowing off XP and reloading isn’t going to solve this problem in all probability because it’s involving hardware. Check drivers and system services.
      SMBP
    • #714220
      1) Main memory
      2) L2 Cache
      3) Video RAM
      SMBP
    • #714227
      Your Direct X Version Controversy Doesn’t Exist Any More:[/u]
      I took care of your direct X controversy here:
      Post 293522: How to Use the XP Registry to Settle Version of Direct X Installed
      SMBP
    • #714228
      SMBP
    Reply To: Major problem, computer do not start. (XP Home SP1)
