With or without the charger connected, the battery charge status light flashes yellow four times, then tray icon shows I’m (very) slowly losing charge and insists the charger is plugged in and not charging. When I plug it in, the screen brightens just a bit, unplug it and it dims a bit. So I assume I am getting voltage and current. It’s like the circuit insists I am not charging. I have:
- Measured the output of the charger at the end-19.2 volts, right where it should be
- Turned the laptop off, disconnected the battery, charger, held the power button down for 20 seconds, reversed the procedure, rebooted-same issue.
- Ran the laptop off right at the outlet, bypassing the UPS-same issue
- Went into Device Manager, uninstalled and reinstalled the APCI power managers (there were three)-same issue.
- Gone through the diagnostics (f12) at boot, and it insists the charger is fine, but the battery is 55% health, or so-so. This should not cause this issue, tho, I think.
The laptop was fine when I left it, came home, hooked it up and this nonsense started.
Hoping to get a fix here before I run out of power as this is my only PC!
HALP!
