ISSUE 17.5.0 • 2020-02-03
Logo
The AskWoody PLUS Newsletter
TROUBLESHOOTING: Tools for monitoring drive health
BEST OF THE LOUNGE: Do-it-yourself notebook repair
LANGALIST: Locked out due to one broken keyboard key?
PATCH WATCH: Microsoft agrees to clean up a small Win7 mess
YEARLY TOC: AskWoody Plus Newsletter — 2019 articles
TROUBLESHOOTING
Lance WhitneyBy Lance Whitney
Today’s PC storage media — traditional disk-based drives and newer solid-state models — are remarkably reliable.
And that’s sort of a problem: we can become lulled into forgetting that they do fail — that there’s always a chance of a catastrophic malfunction, especially as the drive ages. So it’s good practice to periodically check your drive’s health and find potential errors before they result in lost data.
There’s a plethora of utilities for checking the reliability and condition of both traditional platter-based drives and solid-state drives. Most use information gathered by the Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T. or, simply, SMART) tools built into nearly every modern drive.
Drive-health apps act as the interface to the SMART system, displaying the collected data in a relatively accessible and digestible format. (In truth, they provide more data than most PC users will ever need or understand.) Some also include additional tools such as separate read/write scans and even drive-wiping.
As you use these utilities, you’ll notice that there’s a lot of esoteric technology related to drives. Two you’ll run across are automatic acoustic management (AAM; more info) and advanced power management (APM; more info). You’ll typically want to ignore them — except possibly to check whether they’re enabled. In most cases, it’s probably better to have them turned off.
Note: Drive-health apps will report the same SMART stats, but they’ll differ in how they interpret that information. So while some might report that certain SMART numbers represent a serious issue, others might not. They may also provide different predictions of overall drive health.
Here’s a sampling of drive-health apps. They’re all free and support both traditional drives and SSDs.
CrystalDiskInfo
If you’re just looking for basic SMART stats, CrystalDiskInfo (see Figure 1) is up for the task. But it’s otherwise a relatively bare-bones package. The Health Status button gives a simple “Good,” “Caution,” “Bad,” and “Unknown” indication of drive status. (It also gives a somewhat mysterious percentage on SSDs.) Below that is a drive-temperature gauge. Other displayed details include drive specs such as firmware, serial number, interface, buffer size, and power-on count and hours. The lower half of the main screen shows the drive stats collected by the SMART system over time.
CrystalDiskInfo main menu
Figure 1. CrystalDiskInfo is a basic tool for displaying SMART data. But it will also send alerts of possible drive errors.
You can generate graphs of key data and change specific details — though you might have to hunt for them. For example, to switch the temperature reading from the default Celsius scale to Fahrenheit, you must click Function/Advanced Feature/Temperature Type. You can also set up CrystalDiskInfo to send email-based alerts, should your hard drive start to develop any problems.
There’s online help for this app, but it’s rather thin. CrystalDiskInfo is probably best for system admins who know the ins and outs of drive stats and who want to receive alerts when a drive on a managed system is running into trouble. The app comes in both portable (zipped) and “installed” versions.
HDDScan
If you’re looking for a drive utility that’s more user-friendly and has an extended set of tools, HDDScan is a better bet. It will display SMART data, but it also has its own set of drive-scanning options. The main menu has just three buttons: SMART, TESTS, and TOOLS — which includes the temperature monitor.
The SMART button displays a list of specs, and your only options are to save the report to file or print it. Clicking TESTS pops up four options: VERIFY, READ, BUTTERFLY, and ERASE (see Figure 2). The first three of these exercise the drive and report any errors found. You can queue up one test after another and then just let them run unattended to thoroughly analyze your drive. Obviously, you’d select the ERASE option only if you want to scrub everything from a drive.
Drive-test options
Figure 2. HDDScan includes its own set of drive-health tests — plus drive-wiping.
HDDScan can also reveal additional information about drives in the TOOLS section (see Figure 3). For example, clicking TOOLS/DRIVE ID displays a wealth of details about the drives it finds — including interface type, sector size, and level of Direct Memory Access (DMA) support.
Clicking TOOLS/SMART TESTS gives you access to three additional tests: Short, Extended, and Conveyance (which checks for “transportation issues”). The short test is ideal when you want to run a quick check of a drive’s performance. The extended test is, as you might expect, more thorough, but it can take hours to complete.
Figure 3. HDDScan’s TOOLS section
HDDScan is portable — there’s no formal installation — and its limited help is on the hddscan.com home page. It’s a good, general-purpose drive-health utility.
GSmartControl
The primary selling point for GSmartControl is its cross-platform support. There are versions for Linux distros, FreeBSD, macOS/Darwin, Windows, and others. As with HDDScan, GSmartControl digs out SMART details and also offers short and extended tests.
Unlike HDDScan, GSmartControl starts out with a quick and basic drive test — simply click the icon listing your drive to see whether it passes, as shown in Figure 4.
GSmartControl's main menu
Figure 4. GSmartControl has a simple interface that begins with a basic drive test.
Double-clicking the icon opens a more-detailed screen that displays a trove of data about the drive. However, most of that information is displayed as simple text logs, so you’ll have to wade through a lot of technical minutiae.
The General tab shows drive specifications such as model number, capacity, interface, and much more. Attributes tells you whether the drive has failed any specific tests or tasks.
The Statistics section displays information gathered over the life of the drive, including hours in use and temperatures. (This feature doesn’t work with some drives.) The Self-Tests section is where you can run the short and/or extended tests that are built into the drive (see Figure 5).
Figure 5. GSmartControl running a short drive-health test
The Error Log displays any recorded errors found in the tests, and Temperature Log shows the drive’s current temperature plus, on most drives, historical data. The Advanced tab gets you into the deep weeds of drive stats.
GSmartControl comes in both “installed” and portable versions. Documentation is sketchy and found online. It does give a summary of command-line options.
HDD Health
PANTERASoft’s drive-monitoring tool HDD Health is designed to continually audit drives and alert you of possible problems. Once the app is installed, it lives in the Windows notification area. You can get a quick report on drive health and temperature by simply hovering over its icon. Double-click the icon to open the app.
Drive health is reported as a percentage, based on changing SMART stats. The Hard drives tab displays general information about a selected drive, including color-coded health and temperature bars (see Figure 6). The Partitions section shows total and free space for each partition on the drive, and System gives tidbits about your PC’s processor. (Annoyingly, I could not find a way to change the temperature gauge scale from Celsius to Fahrenheit.)
HDD Health drive info
Figure 6. HDD Health provides continuous information on predicted drive health.
To see specific SMART information, click the Drive menu at the top of the window and select SMART Attributes. Select Extended Info to see more details on the drive such as its model number, interface, and serial number. Here you can also find out which specific drive features are supported, including DMA, write cache, and power management.
HDD Health’s few options are found under the File menu, where you can select whether the program starts automatically. You can also customize how and when the app sends alerts (see Figure 7).
HDD Health notifications
Figure 7. HDD Health lets you configure alerts via sounds, popup messages, emails, and network messaging.
There are, of course, other third-party drive-monitoring tools, as an online search will show. You should also check for any drive tools provided by the drive’s manufacturer.
Running any of these apps periodically — and especially when you suspect drive trouble — is good insurance against an unexpected and catastrophic drive failure and data loss (as are, of course, regular system backups).
Best of the Lounge
When Plus member Slowpoke47’s aging Acer laptop went dark, the early speculation was a failing battery. Could that account for a screen that’s too dim to read?
Not one to throw out something that can possibly be fixed, Slowpoke47 posted that supposition on the Lounge — and quickly received helpful suggestions. With trusty multimeter in hand, Slowpoke47 cracked open the laptop and tested various components. Ultimately, a new screen put the portable back into full service.
Routers
Plus member rrufener was concerned when unknown devices occasionally appeared on the guest network. A Wi-Fi breach didn’t seem likely in a rural area, so rrufener turned to AskWoody readers for clues about what these unknown devices could be.
Multimedia
Plus member Casey H had issues with a copy of Corel’s WinDVD Pro 12. The Blu-ray- and DVD-play options were “grayed out.” Was it a PC-to-display connection problem? With help from fellow Loungers, Casey H found the cure.
UPGRADING
Moving to a new computer is often tricky. Plus member bmeacham used PC Mover to migrate the contents of an old PC to a new one. All good — except Windows Backup and Restore (Windows 7) no longer backed up some important folders. Renaming folders and tweaking the registry did not help. Bmeacham naturally turned to the forum for help. But he eventually came up with the solution on his own.
APPLE
Resident all-things-Mac guru Nathan Parker shares a link to a Macworld article on how to clone Catalina-based drives — and not run afoul of its new data format.
Windows
This topic comes up as regularly as sunrise. Plus member Ratters1960 knows that using a standard account is safer for day-to-day computing but is unsure about the best way to create one. Readers weigh in with suggestions and opinions. What’s your favorite technique?
Windows
Lounger anotherwindowsuser solved one problem by reinstalling Windows 10 — but then created others. Anotherwindowsuser could no longer sign in to the Windows Store or add a Microsoft account in Settings. All sorts of errors could cause this problem, but fellow Loungers quickly provided a solution. The discussion then took a turn … to questions about trusted cloud backups.
LANGALIST
Fred Langa
By Fred Langa
When your keyboard malfunctions, common PC tasks such as simply typing in your sign-in password can become difficult — or even impossible.
But every copy of Windows offers an easy-to-access on-screen keyboard that can help keep you going until your physical keyboard is repaired or replaced. Here’s how to instantly access and use that virtual keyboard.
Workaround for a malfunctioning keyboard?
Ross Taylor asked:
  • “What do you do when you can’t enter the password for a laptop because one of the keys isn’t working?”
The first thing I usually do is mutter a long string of expletives. A malfunctioning keyboard can be massively frustrating — it can be a struggle to do much of anything with your PC, including signing in. Grrr!
When I’m done cursing, I regain control over my PC with these three steps: an emergency workaround, an interim fix, and a permanent repair.
Step 1 – The emergency workaround: This initial fix truly takes only seconds to implement. All current versions and editions of Windows offer the built-in On-Screen Keyboard (OSK; sometimes also called a soft keyboard). The Windows OSK is not limited to laptops and touch-enabled PCs; it works on any Windows PC.
The OSK is part of Windows’ always-available Ease of access settings. This accessibility feature is primarily designed to assist users who have dexterity or vision issues. But its features and settings can also be used by anyone whose PC is having keyboard or display problems.
Because these settings are fundamental to the OS, they’re always readily at hand. For example, Windows’ default sign-in/unlock screen typically shows three icons in the lower-right corner: Network (or Internet), Ease of access, and Power. (See Figure 1.)
Ease of access icon
Figure 1. The Ease of access icon is typically found in the lower-right corner of the sign-in screen.
Just click the Ease of access icon, and the menu shown in Figure 2 will appear. Next, click the menu entry On-Screen Keyboard (see Figure 2) — a more-or-less standard 81-character keyboard will appear on your screen (see Figure 3). You can resize and reposition the keyboard as needed.
Figure 2. The common Ease of access settings — including On-Screen Keyboard
the OSK
Figure 3. Windows’ virtual keyboard
To use the OSK, start by clicking the input field or text-entry area where you’re trying to type (so Windows knows where the characters are supposed to go). Next, simply click the virtual keyboard’s keys as needed, and the characters will appear in the designated area.
For example: To sign in, first click the PIN or Password field area to indicate where you want the characters to go, then click the appropriate OSK keys to enter your PIN or password. You’ll be signed in normally. Easy!
If you’re already signed in to Windows and need the OSK, you can call it up instantly, anytime, with this three-key combination: WinKey + Ctrl + O. If you can’t type the three-key combination because, say, the “Ctrl” key isn’t working, you can call up the virtual keyboard by typing OSK into the Windows search box and selecting On-Screen Keyboard when it’s offered. If none of the keys is working, mouse to Settings/Ease of access/Keyboard, and turn on the toggle under Use the On-Screen Keyboard.
One of the oddities in the OSK is its Options key (Figure 4), which opens a box containing some potentially useful settings.
OSK options
Figure 4. The OSK’s Options key calls up a dialog box of keyboard settings.
The current (Win10/1909) options are:
  • Use click sound: Enables audible feedback for each key press.
  • Show keys to make it easier to move around the screen: This adds special-purpose keys — Mv Up (move up), Mv Dn (move down), and Dock (attach keyboard to screen top or bottom) — to let you move the OSK window around without a mouse. It also adds Fade (makes the OSK translucent so you can see what’s behind it) and Nav (shrinks the OSK to just a ribbon so you can see and navigate the rest of the screen).
  • Turn on numeric keypad: Expands the OSK with a right-hand, 17-key, numeric keypad.
  • Click on keys: Click or tap an OSK key to enter that character. (This is the default setting.)
  • Hover over keys: If you can’t click, select this option and move your cursor over an OSK key — the character the cursor is hovering above will be entered automatically after a user-adjustable delay.
  • Scan through keys: If you can’t mouse or move the cursor, use this mode to enter characters in three steps. The OSK will begin to scan itself serially, row by row, lighting up each row of keys as it goes. When the row containing the character you want is illuminated, click or press the spacebar — or use a mouse-click alternative device such as a joystick trigger.
    The OSK will now serially illuminate sections of the selected row. When the row section containing the character you want is illuminated, click/press the spacebar (or your click-alternative device) a second time. The OSK will then serially illuminate each character within the selected section. When the character you want is illuminated, use the spacebar or click-alternative a third time. That character will now be entered, and the OSK will resume the three-step process for the next character to be entered.
  • Use Text Prediction. The OSK will suggest words for you as you type, so you may only have to type the first few letters of a word to enter the whole thing.
There’s some additional OSK information available on the Microsoft Support page “Use the On-Screen Keyboard (OSK) to type.” But, alas, like too many of the current MS online help pages, some of the information is either out of date or just plain wrong. For example, my explanation for Show keys to make it easier to move around the screen is correct. But the Microsoft support page says, “Use this option if you want the keys to light up as you type.” Huh? This setting has nothing to do with that; the OSK keys always light up when you click them. Come on, Microsoft!
The OSK can be a lifesaver in emergencies, but let me say this up front: typing on it isn’t fun. Mousing around a virtual keyboard is a lot slower and clunkier than typing on a real one. Yes, you’ll be able to sign in and use your PC via the OSK, but with reduced speed and efficiency.
So, once the emergency is over, you’ll want to move on to a better fix right away.
Step 2 – An interim broken-keyboard workaround: Your car probably has a spare tire, right? It’s likely to be one of those compact, “donut” temporary spares, intended to keep you rolling for a short distance until you get the real tire repaired.
The OSK solution is handy when you’re traveling, but at home or office, it’s a good idea to have a “spare” keyboard on hand. I keep a generic and inexpensive (about U.S. $10) USB keyboard in my closet. If anything goes wrong with my daily-use keyboard, I can quickly swap in the spare and immediately pick up where I left off. The spare is a wired keyboard, so there are no Bluetooth drivers or dongles to install or configure — and no batteries to recharge.
Surely, the $10 keyboard won’t be as heavy-duty and comfortable as your standard device — like a car’s spare tire, it’s best suited for short-term use. But even a cheap physical keyboard is likely to be much better to type on than the virtual OSK. And it’ll certainly serve until your main keyboard gets fixed or replaced.
Where can you find very inexpensive, keep-as-a-spare keyboards? Oh, just about everywhere, as this Google search shows: usb+keyboard. Really! Ten-dollar (and under!) keyboards are common.
Step 3 – A permanent fix for a broken keyboard: No mystery here: when feasible, repair or replace the original defective keyboard. There’s a world of excellent Bluetooth and plug-in (USB) keyboards available for just about every typing preference and budget.
But no matter what, while you’re sorting out the repair or replacement, your spare keyboard — or even the OSK — can keep you typing in the meantime.
By the way: While you’re checking out the OSK, note Windows’ other Ease of access features. For example, Narrator can speak aloud Windows’ menus, dialog boxes, and some app contents to help you navigate and use Windows — even if your PC’s display is dead or malfunctioning.
You can also use Win10’s built-in voice recognition to speak aloud some kinds of Windows and app commands — and to record free-form speech-to-text dictation. (It requires prior setup.) For more information, see the Microsoft support articles Use voice recognition in Windows 10 and Use dictation to talk instead of type on your PC. Supported voice commands are listed in the article Windows Speech Recognition commands.
For more overall information on Windows’ Ease of access options, see the MS Support article “Make your PC easier to use,” or visit the main Microsoft Accessibility site.
PATCH WATCH
Susan BradleyBy Susan Bradley
The NSA might have rained on Windows 10’s patching parade in January, but most of the attention was focused on the demise of Windows 7.
You’d think Microsoft would get the last batch of free Win7 updates right — but apparently not. January’s Patch Tuesday fixes broke Win7’s wallpaper. If you used the “Stretch” option for background slide shows, you ended up with just black! Microsoft’s initial response? The fix would be offered only to those who had purchased Win7 Extended Security Updates (ESU) keys.
Really, Microsoft? Sure, it’s a relatively minor problem … but you’re going to end general support for a still-widely used OS by breaking it? Fortunately, saner minds prevailed; Microsoft backtracked and stated that a fix would be released to all. We don’t yet know how or when, but it’s reassuring when Microsoft cleans up after itself.
Is your Win7 system still getting the upgrade-nag popup? Keep in mind that it’s not too late to purchase a Windows 7 ESU license by filling out the Harbor Computer Services request form. For more info on ESUs, see my article and discussion via an AskWoody post.
Other January patch notes: The first 2020 updates for Windows 8.1 and 10 workstations appear to be playing nicely. But I am tracking some isolated issues with Windows Server fixes. For example, there are reports of constant reboots after installing monthly rollup KB 4534297 on domain controllers running Server 2012 R2. At this time, there are no workarounds — the only solution is to uninstall the update.
Microsoft has resumed posting preview updates for most versions of Windows. As always, these updates are completely optional, and we don’t recommend installing them on production systems.
Chromium-based Edge: The new Edge might have a better core, but keep in mind that any bug impacting Google’s Chrome will also be felt by Microsoft’s latest Edge edition. The real question is whether Microsoft’s documentation will be able to keep up with Chromium’s fast updating cadence. For example, Microsoft waited until January 28 to post an advisory that the new Edge had been updated on January 15.
Given “classic” Edge’s rather unimpressive history, I recommend checking out New Edge (aka Edge Chromium, aka Chredge). Of course, many of you are already using one of the alternatives: in addition to Google Chrome and Firefox, consider old standards such as Opera, Brave, and Vivaldi.
Exploits du jour: As I noted in the previous Patch Watch, 2020 patching started off with a bang in the form of a U.S. National Security Agency advisory. The NSA took the extraordinary step of recommending that all Windows 10 users immediately install Microsoft’s January updates to block CVE-2020-0601 (aka crypt32.dll).
As yet, there are no reports of in-the-wild attacks using this exploit. (It’s still mostly “proof of concept.”) In fact, I would not expect to see headlines about actual crypt32.dll attacks — it’s a bug that can silently wiggle into systems. More important, the major antivirus vendors are incorporating defenses into their products, and Windows Defender will sense when a maliciously signed certificate is being used.
In the previous Patch Watch, I was more concerned about vulnerabilities related to Remote Desktop (a client-side app) and Remote Desktop Gateway, often used by businesses for allowing remote access to their systems. Of the two, RDG was the more worrisome.
Over the past two weeks, I’ve become less anxious about this threat. Currently, CVE-2020-0609 and CVE-2020-0610 can be exploited only from within a network — i.e., it can’t be used remotely (more info). That’s good news: it means an attacker can’t use SSL port 443 for an external connection. At this time, attacks can be launched via port 3391 — a port I’ve never opened when I’ve deployed Remote Desktop Gateway.
January’s patch summary
Last month’s updates were a real test of potential threats versus waiting to see whether any major patch issues showed themselves. Given the nature of the NSA-revealed vulnerabilities, the early recommendation was that large firms and organizations should patch sooner than usual. That advice turned out to be largely unnecessary. Nevertheless, January’s updates proved well behaved.
- What to do: At this time, both business and consumer Windows users should install January’s Windows and Office updates, if they’ve not done so already.
Windows 10
I promise: This is the last time I’ll remind Windows 1803 users that it’s way past time to move up. PKCano posted how to bump up to Version 1809; I recommend Version 1903.
Servicing-stack updates
  • 4528759 for Versions 1903 and 1909
Cumulative updates
  • 4528760 for Versions 1903 and 1909
  • 4534273 for Version 1809 and Server 2019
  • 4534293 for Version 1803 (Enterprise and Education editions only)
  • 4534276 for Version 1709 (Enterprise and Education editions only)
  • 4534296 for Version 1703 (Long-Term Servicing Channels; LTSC)
  • 4534271 for Version 1607 (LTSC) and Server 2016
.NET Framework
This month’s .NET updates include security patches, so they need more attention. Note that Win10 1809 has three updates listed. But you should see only one to be installed.
  • 4532938 for Versions 1903 and 1909 (.NET 3.5 and 4.8)
  • 4532937 for Version 1809 and Server 2019 (.NET 3.5 and 4.8)
  • 4532947 for Version 1809 and Server 2019 (.NET 3.5 and 4.7.2)
  • 4535101 for Version 1809 and Server 2019 (.NET 3.5, 4.7.2, and 4.8)
  • 4532936 for Version 1803 (.Net 4.8; Enterprise and Education editions only)
  • 4532935 for Version 1709 (.NET 4.8; Enterprise and Education editions only)
  • 4532934 for Version 1703 (.NET 4.8; LTSC only)
  • 4532933 for Version 1607 (.NET 4.8; LTSC only) and Server 2016
Preview cumulative updates
Here’s the list of preview updates. (There’s no preview for Version 1703 at this time.) Again, we do not recommend installing them on production systems. The following were released on January 23 and 28.
  • 4532695 for Versions 1903 and 1909
  • 4534321 for Version 1809 and Server 2019
  • 4534308 for Version 1803 (Enterprise and Education editions only)
  • 4534318 for Version 1709 (Enterprise and Education editions only)
  • 4534307 for Version 1607 (LTSC) and Server 2016
Windows 8.1/Server 2012 R2
Windows 7 users who are Win10-phobic should consider Windows 8.1. Its monthly rollup format will be familiar.
  • 4534297 – Monthly rollup
  • 4534309 – Security-only
  • 4534251 – Internet Explorer 11 (install with the security-only update)
  • 4535104 – .NET Security quality rollup
  • 4534978 – .NET Security only update
Windows 7/Server 2008 R2 SP1
The workaround for Windows 7’s simple black-wallpaper bug is to use a slide-show setting other than “Stretch” — at least until Microsoft sends us a fix.
  • 4536952 – Servicing-stack update
  • 4534310 – Monthly rollup
  • 4534314 – Security-only
  • 4534251 – Internet Explorer 11 (install with the security-only patch)
  • 4535102 – .NET security and quality rollup
  • 4534976 – .NET security-only update
Server 2012
Be aware of the ongoing Cluster Shared Volume flaw.
  • 4534283 – Monthly rollup
  • 4534288 – Security-only
  • 4535103 – .NET security and quality rollup
  • 4534977 – .NET security-only
Windows Server 2008 SP2
  • 4536953 – Servicing-stack update
  • 4534303 – Monthly rollup
  • 4534312 – Security-only
  • 4535105 – .NET security and quality rollup
  • 4534979 – .NET security-only
January’s security updates fix a remote-code-execution vulnerability.
Office 2016
Office 2013 SP1
Office 2010 SP2
The following Office non-security enhancements and fixes were released January 7, 2020.
Office 2016
  • 2920709 – Visio Viewer; duplicate windows class names
  • 4464575 – Visio; crashes with .vsdx files
  • 4464586 – Office; ability to bypass credential prompts
  • 4484140 – Project; cost-value errors
  • 4484168 – Office; new PowerPoint commenting feature (subscription versions only)
  • 4484212 – Outlook; fixes various Outlook issues
  • 4484213 – Skype for Business; toll-free numbers display
  • 4484216 – PowerPoint; new commenting feature (subscription versions only)
  • 4484218 – Office; ODBC Data Sources application stops
  • 4484219 – Word; language and UNC fixes
Office 2013 and 2010
There are no new non-security updates for Office 2013 and Office 2010.
Refresher: Patch Watch rules for updating
It’s a new month of patching. Once again, here are our current recommendations for patching Windows and Office. They may change as Microsoft evolves its updating process.
  • Monthly security patches ship on the second Tuesday of each month (Patch Tuesday). For all versions of Windows, defer this month’s updates for at least 15 days. (Windows 10 will still wait for 15 days if you click “Check for updates.”)
  • Microsoft sends out preview updates, typically on the third Tuesday of each month. They are completely optional and should be skipped on any system not used exclusively for testing. I list the previews in our Master Patch List spreadsheets, so you can look up their KB numbers and see whether they’re available. Again, we strongly recommend you don’t install them on production systems.
    Keep this in mind: On older platforms, it’s clearly stated that the optional updates are previews. But Windows 10 doesn’t make that distinction. You know they’re previews only because they show up a week or two after Patch Tuesday — and they’re not necessarily released on a Tuesday. (Yes, it’s annoying and confusing for WSUS admins.)
  • Remember: Updates can be deferred on Windows 10 Pro and above. If you’re running Win10 Home Version 1903, you can pause patching in seven-day increments; for earlier versions, we recommend upgrading to Win10 Pro.
  • Ensure that Windows 7 is set to download or check for updates, but don’t automatically install them. It’s your best defense against problematic patches.
Stay safe out there.
YEARLY TOC
No doubt about it: 2019 was a banner year for both AskWoody and Windows Secrets. We restored the Windows Secrets newsletter and brought back many of your favorite contributors.
Over the year, we reported extensively on the final days of Windows 7: how to prepare for its end of support, how to choose an alternative operating system, and where to get extended security updates.
But we also published such diverse stories as securing your technology toys (16.2.0), a substitute for Facebook (issue 16.4.0), and a three-part series on using Chromebooks and Chrome OS (16.44.0 – 16.46.0).
And, of course, there were the regular columns: Patch Watch, Best Utilities, and the ever-helpful LangaList.
We know that you have these newsletters safely tucked away in your email archives. But that’s not an easy way to locate specific articles that you might want to read through again. So here’s the full list for 2019.
Thanks for your ongoing support!
16.47.0 — 2019-12-23
Windows 7 Bradley Hunting for an elusive Win7 ESU license
From the Publisher Leonhard A big year for AskWoody — and a bigger one to come
LangaList Langa “Battery-limiting” apps help enforce the 80/20 rule
Best Utilities McElveen Freeware Spotlight — Folder Painter
16.46.0 — 2019-12-16
Google Chrome OS Raphael The Chrome OS FAQ, Part III: You’ve got a Chromebook. Now what?
LangaList Langa New laptops prompt new concerns
Patch Watch Bradley Closing out the patching year …
Cloud Services Babinchak When moving to the cloud goes really bad
16.45.0 — 2019-12-09
Google Chrome OS Raphael The Chrome OS FAQ, Part II: Which Chromebook should you buy?
LangaList Langa Removing bloatware and OEM mods from new machines
Best Utilities McElveen Freeware Spotlight — PrivaZer
Gadgets Lasky Versatile gadget gifts for stuffing stockings large and small
16.44.0 — 2019-12-02
Google Chrome Raphael Chrome OS FAQ, Part I: Is a Chromebook right for you?
Patch Watch Bradley The (sorta) quiet release of Win10 Version 1909
16.43.0 — 2019-11-25
Woody’s Windows Watch Leonhard Seven Semper Fi: Windows 7 do’s and don’ts
LangaList Langa Hardware questions move to the fore
On Security Bradley ‘Tis the season — for holiday scams
Troubleshooting Whitney Solving search problems in Windows 10
16.42.0 — 2019-11-18
Woody’s Windows Watch Leonhard All roads lead to Win10 1909 — but you can take your time
LangaList Langa A time-saving shortcut for new-PC setups?
Patch Watch Bradley Ready or not, Win10 Version 1909 is here
Windows Spector Working outside an admin account: Safe but annoying
16.41.0 — 2019-11-11
Network Troubleshooting Whitney Resolving Windows network-connection problems
LangaList Langa Hybrid attack can extract data from inert RAM
Best Utilities McElveen Freeware Spotlight — WPD
PC Buying Lasky PC bargains: Buying a laptop on Black Friday and Cyber Monday
16.40.0 — 2019-11-04
Woody’s Windows Watch Leonhard Peering into the Windows tea leaves
LangaList Langa More on restoring drivers from local backups
Windows Patching Bradley Take charge of Windows 10 and Office 365 updating
Best Utilities McElveen Freeware Spotlight — Best diagnostic tools
16.39.0 — 2019-10-28
Privacy Whitney How to view and protect the privacy of your MS account
LangaList Langa When and how to restore your local driver backups
Patch Watch Bradley Getting ready for Windows 10 1909
Best Utilities McElveen Freeware Spotlight — SyMenu
16.38.0 — 2019-10-21
Woody’s Windows Watch Leonhard Seven Semper Fi: Three months to go; here’s what to do.
LangaList Langa Free tools help prevent Universal Serial Bus slowdowns
Windows 7 Support Babinchak Microsoft wants to sell you security patches for Win7
Ultimate Utilities List Capen The return of our occasional Ultimate Utilities list
16.37.0 — 2019-10-14
LangaList Langa Easily back up all your PC’s current drivers
Patch Watch Bradley October’s updates look promising; however …
Network Troubleshooting Whitney Using the ipconfig command to troubleshoot network problems
Best Utilities McElveen Freeware Spotlight — Windows Registry Recovery
16.36.0 — 2019-10-07
Woody’s Windows Watch Leonhard Shedding light on September’s out-of-band Windows patches
Patch Watch Bradley Finally! We have a true out-of-band IE update
LangaList Langa PC always boots into ‘Manufacturing Mode’
On Security Bradley Are self-encrypting hard drives secure enough?
16.35.0 — 2019-09-30
Patch Watch Bradley Here’s why we’re not patching Internet Explorer
Best Utilities McElveen Freeware Spotlight — Win7 Games for Windows 10 and 8
16.34.0 — 2019-09-23
Woody’s Windows Watch Leonhard Has MS cleaned up its Win10-update mess? (Spoiler: No!)
LangaList Langa How to stop two Windows Defender annoyances
Productivity Whitney How to fill out a PDF form with Adobe Acrobat Reader
Security Babinchak Changing my mind about Facebook
16.33.0 — 2019-09-16
AskWoody.Com Evolution Leonhard Coming soon: Windows Secrets archives!
LangaList Langa A ‘tip of the iceberg’ problem with RPV
Patch Watch Bradley The patch waiting game — September edition
Best Utilities McElveen Freeware Spotlight — TweakPower
16.32.0 — 2019-09-09
Letter from the Publisher Leonhard Where we’re headed with AskWoody Plus — an update
LangaList Langa When software just won’t let go
Upgrading Bradley Considerations migrating from Win7 to Win10
Security Whitney How to block malware with Windows’ built-in security
16.31.0 — 2019-09-02
LangaList Langa What to do when Windows can’t run EXEs
Patch Watch Bradley August updates still dribbling in
Best Utilities McElveen Freeware Spotlight — NirLauncher
16.30.0 — 2019-08-26
Woody’s Windows Watch Leonhard Another patching debacle — how we got here
LangaList Langa Spotting fakery in system specs
On Security Bradley Options for secure remote access
Small Business Computing Babinchak What does digital transformation mean for small business?
16.29.0 — 2019-08-19
Productivity Whitney MS Word and Google Docs now play nicely together
LangaList Langa Oops! Recovering a file after a factory restore
Patch Watch Bradley August update warnings prove overblown
Best Utilities McElveen Freeware Spotlight — StopUpdates10
16.28.0 — 2019-07-29
LangaList Langa Many ways to track down a PC’s energy problems
Patch Watch Bradley Wrapping up July Windows and Office updates
Windows 10 Whitney Windows 10 gets better at taking screenshots
Best Utilities McElveen Freeware Spotlight — Quick Access Popup
16.27.0 — 2019-07-22
Woody’s Windows Watch Woody Why can’t Microsoft reliably patch its own hardware?
LangaList Langa Decoding a vague ‘Unknown Device’ error
Win10 Tutorial Capen Deciphering Task Manager’s App History
Conquering Windows 10 Whitney Taking control of default apps in Win10
16.26.0 — 2019-07-15
Windows 10 Whitney Create an MS Family to share your computing resources
LangaList Langa Win10’s 18-month ‘service life’ complicates updates
Patch Watch Bradley July updates come with a few warts
Best Utilities McElveen Freeware Spotlight — Eraser
16.25.0 — 2019-07-08
LangaList Langa How do you know if File History is really working?
Best Utilities McElveen Freeware Spotlight — CipherShed
16.24.0 — 2019-07-01
On Security Bradley Windows 7: Preparing for an uncertain future
LangaList Langa A welcome change in Win10’s cleanup tools
Patch Watch Bradley Putting June’s updates behind us
Windows 10 Babinchak Really useful Windows 10 features
16.23.0 — 2019-06-24
Woody’s Windows Watch Leonhard Why I recommend pausing Windows updates every month
LangaList Langa Optane disappointment leads to a ‘Plan B’
Best Utilities McElveen Freeware Spotlight — System Information Viewer
Windows 10 Whitney How to maximize your battery charge in Win10
16.22.0 — 2019-06-17
Cloud Storage Babinchak Microsoft finally got OneDrive right
Patch Watch Bradley Are we ready for the new Windows 10 1903?
Best Utilities McElveen Freeware Spotlight — ccPortable
Windows 10 Lasky Moving to Win10: Apps lost and found
16.21.0 — 2019-06-10
Windows 10 1903 Whitney How to work and play in Win10’s new Sandbox
LangaList Langa Test-driving Intel’s Optane in a new PC
Best Utilities McElveen Freeware Spotlight — Graph Paper Printer
Cloud Storage Spector Finding your photos in the cloud
16.20.0 — 2019-06-03
Woody’s Windows Watch Leonhard A dozen reasons why you don’t want Win10 1903 — yet
LangaList Langa Taking the plunge with a new PC
Patch Watch Bradley Windows 1903 gets its first update
Troubleshooting Whitney How to fix OneDrive file-synching problems
16.19.0 — 2019-05-27
LangaList Langa Tracking down ominous noises in your PC
Digital Media Bradley Entertainment in the media-streaming era
Best Utilities McElveen Freeware spotlight — AppleWin
16.18.0 — 2019-05-20
LangaList Langa Common reasons for backup and imaging failures
Patch Watch Bradley Got XP? Got a patch!
Best Utilities McElveen Freeware spotlight — SwiftSearch
Web Security Whitney Secure website accounts with Microsoft’s Authenticator app
16.17.0 — 2019-05-13
Woody’s Windows Watch Leonhard Sticking with Win7? You aren’t alone
LangaList Langa How to safely remove vendor-installed junkware
Best Utilities McElveen Freeware spotlight — USBFlashCopy
Troubleshooting Lasky Use system images to fix major PC hassles
16.16.0 — 2019-05-06
Woody’s Windows Watch Leonhard Beware the crapware in Win10 1903
LangaList Langa When a Win7 ‘no-reformat reinstall’ is not the way to go
Patch Watch Bradley A Japanese era begins; an older Windows era struggles
Windows 10 Whitney Pairing your phone with Windows 10 for better security
16.15.0 — 2019-04-22
Woody’s Windows Watch Leonhard More on April’s Win7- and 8.1-patching debacle
LangaList Langa Users stuck on Win10 1803 ask: ‘Force upgrade or wait?’
Best Utilities McElveen Freeware Spotlight — Desktop Restore
Windows Security Whitney Four ways to sign in to Windows — without a password
16.14.0 — 2019-04-15
Windows Secrets Update Leonhard Windows Secrets Lounge merging into AskWoody.com
LangaList Langa Why won’t some Win10 PCs update?
Patch Watch Bradley April patching plays a late joke on Win7/Win8.1
Office Babinchak Managing meetings like a polite pro
16.13.0 — 2019-04-08
Woody’s Windows Watch Leonhard Bombshell: Updating Win10 will be better — really!
LangaList Langa A reader’s laptop becomes a fire hazard!
On Security Bradley Preparing for Microsoft’s patch-security changes
Best Utilities McElveen Freeware spotlight — Hekasoft Backup & Restore
16.12.0 — 2019-04-01
Woody’s Windows Watch Leonhard What to tell friends who use Windows 7
Patch Watch Bradley Windows 10 1903 just around the corner
Networking Spector Fixing Wi-Fi problems with a mesh network
Windows 10 Lasky Revealing File Explorer’s hidden treasures
16.11.0 — 2019-03-25
On Security Bradley Office 365: The trendy new phishing target
LangaList Langa Win8/10’s secure-boot process still causing trouble
Best Utilities McElveen Freeware Spotlight — Folder Monitor
The Internet Whitney How to find and change DNS Settings
16.10.0 — 2019-03-18
Woody’s Windows Watch Leonhard Seven Semper Fi: How to ride Win7 into the sunset
LangaList Langa Win10’s new winver alternative
Patch Watch Bradley Microsoft starts the Windows 7 countdown
Digital Entertainment Spindler The new world of professional ‘digital’ sports
16.9.0 — 2019-03-11
LangaList Langa Don’t put all your admin eggs in one basket!
Office Whitney One new Office app to rule them all
Quick Tip Capen Quick fix for a broken Default apps list
Windows 10 Lasky Making sense of Win10’s Storage Sense
Best Utilities McElveen Freeware Spotlight — DeviceTool
16.8.0 — 2019-03-04
LangaList Langa Windows Update errors cause OS-version problems
Patch Watch Bradley Win10 1809 still not ready for business
Best Utilities McElveen Freeware Spotlight — Safe Startup
Best Practices Lasky Instant file transfers with Win10’s Nearby sharing
16.7.0 — 2019-02-25
Top Story Leonhard How to get real help with Windows, Office, and more
On Security Bradley Do we really need protection from Spectre and Meltdown?
Best Utilities McElveen Freeware Spotlight — Policy Plus
Security Alert Capen Internet home rentals: Staying secure as a guest or host
16.6.0 — 2019-02-18
Woody’s Windows Watch Leonhard Dispatches from the browser-war’s front lines
LangaList Langa Should you trust a hard drive after a major error?
Patch Watch Bradley Japan has its Y2K moment
Best Utilities McElveen Freeware Spotlight — MultiPack Visual C++ Installer
16.5.0 — 2019-02-11
Woody’s Windows Watch Leonhard Where we’re headed with Windows Secrets
LangaList Langa Three somewhat unusual, but interesting, reader queries
Best Practices Lasky Ten tools and tips for better/cheaper printing
On Security Bradley The end of the road for Win7 looms
16.4.0 — 2019-02-04
Woody’s Windows Watch Leonhard Phantom features, and the Win10 treadmill
LangaList Langa Unraveling Win10’s file ‘permissions’ issues
Social Networking Spector Hate Facebook? There are alternatives
Best Utilities McElveen Freeware Spotlight — Ron’s WebLynx
16.03.0 — 2019-01-28
Woody’s Windows Watch Leonhard Breaking news: Windows 10 patching improves
Patch Watch Bradley Green light for patches; yellow for Win10 1809
Tech Tip Capen Networking: Power over Ethernet
Best Utilities McElveen Freeware Spotlight — Account Profile Fixer
16.2.0 — 2019-01-21
Woody’s Windows Watch Leonhard Preparing for the Windows 7 winter
LangaList Langa Five different ways to fix airplane mode malfunctions
On Security Bradley Making your new tech toys secure
Best Utilities McElveen Freeware Spotlight — User Profile Wizard
16.1.0 — 2019-01-14
Introduction Capen Now open under old management
Woody’s Windows Watch Leonhard Would you pay to rent Windows?
LangaList Langa (Tap tap tap) Hey, is this thing on?
Patch Watch Bradley Win10 Version 1803 gets honor as most buggy?
