I need help! I have a 700 mhz machine with 512mb ram running WinXP. I have a wireless Linksys router that is hooked into my main computer, and have my kids computers hooked up to broadband via wireless USB adapters. They all receive good signals, and I have had no issues with their connections. However, on my third machine, I have tried a Linksys USB adapter and never could get it to connect. I thought maybe there was an issue within the operating system, so I had a fresh load of XP put on the machine. I even went to a MS adapter because I have had good luck with them. Anyway, yesterday, I hooked up the MS adapter, and followed the instructions explicity. The internet set up fine, and the internet gateway and wireless connection icons appeared in the Network Neighborhood. Even though the signal was low, I was connected. However, I left the machine and came back, and the connection was gone….not low or anything…just said the wireless signal did not exist. I tried a system restore, and uninstalled, and then reinstalled the adapter. Never did receive the internet gateway icon again, and it still says the network signal does not exist. The settings on the router and the other adapters are all correct, and this adapter mirrors them. I don’t know what it is with this computer, but it has been contrary. I thought maybe it was a flaw in the operating system, but it is now doing it after I have a fresh load of the OS. I have spent HOURS trying to make this work! CAN SOMEONE PLEASE HELP???
Wireless Problems-HELP
Home » Forums » Networking – routers, firewalls, network configuration » Wireless Problems-HELP
- This topic has 16 replies, 4 voices, and was last updated 20 years, 11 months ago.
Viewing 5 reply threadsAuthorReplies-
WScbaldrey
WSklott54
AskWoody LoungerMay 4, 2004 at 11:43 am #823052Nope, I don’t think it is a positioning problem. I really do believe that there is some conflict in the pc itself that no one can determine. It is in the same room where another connected pc works fine. (small bedroom) It was in another room further from the base station before, so it was moved. That isn’t the issue. It worked initially, although with a weak signal, but then something in the pc or its software caused the signal to no longer be recognized although the hardware was working fine.
WSklott54
AskWoody LoungerMay 4, 2004 at 11:43 am #823053Nope, I don’t think it is a positioning problem. I really do believe that there is some conflict in the pc itself that no one can determine. It is in the same room where another connected pc works fine. (small bedroom) It was in another room further from the base station before, so it was moved. That isn’t the issue. It worked initially, although with a weak signal, but then something in the pc or its software caused the signal to no longer be recognized although the hardware was working fine.
WScbaldrey
AskWoody LoungerWSTravlingMan
AskWoody LoungerMay 4, 2004 at 11:51 am #823054An easier way to check would be to move the wireless router to a differant place, change the direction of the attenia. If that does not work then log onto your Linksys router through a computer that is connected and check to see if the router has the computer listed in its’ list. go to DHCP then at the bottom of the window click on DHCP Client List),You should be able to release and renew this list also. It takes a few minutes to reset so be patient. If that does not work let us know and we will try something else!
WSTravlingMan
AskWoody LoungerMay 4, 2004 at 11:51 am #823055An easier way to check would be to move the wireless router to a differant place, change the direction of the attenia. If that does not work then log onto your Linksys router through a computer that is connected and check to see if the router has the computer listed in its’ list. go to DHCP then at the bottom of the window click on DHCP Client List),You should be able to release and renew this list also. It takes a few minutes to reset so be patient. If that does not work let us know and we will try something else!
WSTravlingMan
AskWoody Lounger-
WSklott54
AskWoody LoungerMay 17, 2004 at 2:50 pm #828356Doesn’t seem to be an adapter or router problem, because they both work elsewhere. Someone suggested I install a new USB card. Perhaps the USB connection in the machine is bad. It is very funny that both times (With 2 different adapters) that the wireless connection existed for a short time after initial install, and then just disconnected itself. It then would not allow me to make the connection again. The device manager shows the hardware device is connected, but for some reason it is not recognizing the network.
WSklott54
AskWoody LoungerMay 17, 2004 at 2:50 pm #828357Doesn’t seem to be an adapter or router problem, because they both work elsewhere. Someone suggested I install a new USB card. Perhaps the USB connection in the machine is bad. It is very funny that both times (With 2 different adapters) that the wireless connection existed for a short time after initial install, and then just disconnected itself. It then would not allow me to make the connection again. The device manager shows the hardware device is connected, but for some reason it is not recognizing the network.
WSklott54
WSklott54
DaveA
AskWoody_MVPMay 22, 2004 at 1:33 pm #831076Do you have “Hibernation” or any other “Power saving” items turn on?
If so, USB connections are knonw for losing connection and not found again.
As for the icon, did you add the required check mark to display the icon?
DaveA
AskWoody_MVPMay 22, 2004 at 1:33 pm #831077Do you have “Hibernation” or any other “Power saving” items turn on?
WSTravlingMan
AskWoody LoungerViewing 5 reply threads -
advice for setting up a new windows computer
routtco1001
12 hours, 55 minutes ago -
It’s Identity Theft Day!
3 hours, 2 minutes ago -
Android 15 require minimum 32GB of storage
17 hours, 44 minutes ago -
Mac Mini 2018, iPhone 6s 2015 Are Now Vintage
17 hours, 54 minutes ago -
Hertz says hackers stole customer credit card and driver’s license data
18 hours, 24 minutes ago -
Firefox became sluggish
Rick Corbett
15 hours, 19 minutes ago -
Windows 10 Build 19045.5794 (22H2) to Release Preview Channel
22 hours, 23 minutes ago -
Windows 11 Insider Preview Build 22635.5235 (23H2) released to BETA
22 hours, 52 minutes ago -
A Funny Thing Happened on the Way to the Forum
18 hours, 23 minutes ago -
Download speeds only 0.3Mbps after 24H2 upgrade on WiFi and Ethernet
John
19 hours, 46 minutes ago -
T-Mobile 5G Wireless Internet
WSmmi16
4 hours, 55 minutes ago -
Clock missing above calendar in Windows 10
WSCape Sand
4 hours, 46 minutes ago -
Formula to Calculate Q1, Q2, Q3, or Q4 of the Year?
WSJon5
The time has come for AI-generated art
Catherine Barrett
17 hours, 41 minutes ago -
Hackers are using two-factor authentication to infect you
23 and you
Max Stul Oppenheimer
April’s deluge of patches
13 hours, 54 minutes ago -
Windows 11 Windows Updater question
3 hours, 20 minutes ago -
Key, Key, my kingdom for a Key!
2 days, 19 hours ago -
Registry Patches for Windows 10
Drcard:))
2 days, 23 hours ago -
Cannot get line length to NOT wrap in Outlining in Word 365
DDU (Display Driver Uninstaller) updates
Align objects on a OneNote page
3 days, 5 hours ago -
OneNote Send To button?
3 days, 6 hours ago -
WU help needed with “Some settings are managed by your organization”
Peobody
3 days, 14 hours ago -
No Newsletters since 27 January
rog7
Linux Mint Debian Edition 7 gets OEM support, death of Ubuntu-based Mint ?
2 days, 15 hours ago -
Windows Update “Areca Technology Corporation – System – 6.20.0.41”
Bruce
2 days, 13 hours ago -
Google One Storage Questions
LHiggins
1 day, 21 hours ago -
Button Missing for Automatic Apps Updates
pmcjr6142
2 days, 5 hours ago
