I switched from a DSL provider to a new cable provider. I have one desktop connected directly to their modem that works for internet access. I want to set up my other desktop for wireless access.
When I take the ethernet line out from my PC (the one connected directly and works) to the router and a new ethernet cable from the router to the PC it should work but it never does. Data should travel from the modem to the router to the PC using all ethernet cable. When I switch it back it works.
I’m thinking that perhaps my IP address of the computer is hard coded on their server so when I switch the cable from my PC to the Router which has a different IP address it won’t work. Is this correct? What do I need to have my cable internet provider change on their end in order for it to work?
