I am unable to get an internet connection using a Windows 7 PC. My connection using a Mac works fine. I used the same cable to the same port on the router with the Windows PC.
I have been using a Mac for years without issues. This is the first time I’ve tried connecting a PC running Windows 7 Home Premium.
I am thinking that the problem may be due to the firewall settings. When I set up the PC, I did not intend for it to be connected to the internet. (Long story – I just can’t spend the time trying to keep up with the constant security updates involved in maintaining a Windows system. I find Macs are much easier to maintain.) Anyway, during setup I set *up a very restrictive Windows firewall. I’m enclosing two files that (1) summarizes the system setup – shows the ethernet connection is OK, and (2) shows the firewall setup.
Any thoughts as to whether the firewall might be the problem?
