• Win7 64 USB speed problem
    Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Win7 64 USB speed problem
    • This topic has 56 replies, 8 voices, and was last updated 11 years ago.
    Details of my pc.
    OS: Win 7 Ultimate 64
    Motherboard: Manufacturer ASUSTeK Computer INC.
    Model M2N-MX (CPU 1)
    Chipset Vendor NVIDIA
    Chipset: nVidia nForce 6100-405/430
    Chipset Model MCP61
    Chipset Revision A2
    Southbridge Vendor NVIDIA
    Southbridge Model MCP61
    Southbridge Revision A2
    System Temperature 32 °C
    BIOS: Brand American Megatrends Inc.
    Version 0406
    Date 15/01/2007
    CPU: AMD Athlon 64 X2 3800+
    Recently, I had inserted a external drive (I have two of the same externals, one is always plugged in) and it wouldn’t find the right driver (which is strange, like I said, I have two of the same drives LOL), anyways.. on to what I have done…
    Someone told me to uninstall all USB in device manager, and let windows reboot and it should fix the problem.
    Well ever since then I have had anything plugging in pretty much telling me “device can perform faster”, which I NEVER had at all ever before on this PC.
    I have OpenHCD and Enhanced.
    I would like to disable OpenHCD so everything MUST use the enhanced (which is 2.0)
    I found this thread, and thought I would give it a go
    http://windowssecrets.com/forums/showthread//158231-How-to-disable-USB-1-1-ports
    I tried the option there… disabling legacy support… and well booted up, PC then told me it needed to run start up repair etc. So I closed down, started up, into bios again and enabled legacy, booted fine.
    I have tried updating my bios. But mobo doesn’t have ezyflash, and not recognize afudos and having it on flash drive, and pressing alt + f2, I get “cable not connected” on monitor. and nothing else.
    Any help would be greatly appreciated. Cheers.
    1.1 speeds is killing me… 3 hrs or more to transfer a 1gb file… is making pull my hair out.
    Viewing 42 reply threads
    • #1452538
      Have you also looked into this?
      http://windowssecrets.com/forums/showthread//158231-How-to-disable-USB-1-1-ports?p=932683&viewfull=1#post932683
      I have never done that myself, but it seems to be what solved the other guy’s problem.
    • #1452544
      I know which hub and such is what, and what goes where… been hunting a fair bit and looking a fair bit.
      Sometimes the external shows with the other ones, on the enhanced.
      Othertimes it goes on the openhcd, and then I get the “your device can perform faster”
      http://prntscr.com/3hwl1r <=– thats what I see when it happens
      I would like to know how to force them onto the other SPARE bold ports… but have no idea how to.
      I have tried to "disable" the actual openhcd AND usb root hub itself
      http://prntscr.com/3hwlnf
      BUT, its greyed out..
      am kinda lost with this stuff.
    • #1452552
      The Asus site for the M2N-MX mainboard shows your BIOS is really out of date (and that the latest supported OS is Vista 32/64bit). I was actually looking for a chipset driver for Win 7 x64 but no Win 7 drivers/utilities are available there. I checked the Nvidia site but, again, the latest chipset driver for the Nvidia 430/6100 is for Vista 32/64bit.
      36971-nvidia
      Click to enlarge
      Just a thought… the mainboard manual shows that Asus EZ Flash is only available when the mainboard is connected to VGA/RGB output. I don’t suppose you’ve added a graphics card to the PCI Express x16 slot and are using that instead of the onboard VGA port (hence “cable not connected” on monitor)?
      Alternatively, do you have the mainboard support CD? If so, try using the Asus Update utility to update the BIOS from within Windows (and re-install any chipset driver if it supports Win 7 x64).
      Does your USB configuration in the BIOS look this:
      36970-asus-USB
      Click to enlarge
      If the controller mode is set to Full Speed instead of HiSpeed then you’ll only 12 Mbps (similar to USB 1.1), not 480 Mbps.
      I’m not too sure what else to suggest as you have already tried un-installing the USB ports and hubs then re-booting… which usually fixes this type of issue.
    • #1452588
      https://vip.asus.com/forum/view.aspx?id=20091204151118578&board_id=1&model=M2N-MX&page=1&SLanguage=en-us
      That there has the win7 drivers…
      and also…
      http://support.asus.com/download.aspx?SLanguage=en&m=Tools&os=17
      http://prntscr.com/3i2xk8
      BUT, when I try to install for eg the ATK and update it….
      The drivers for this device are not installed. (Code 28)
      The installation of this device is forbidden by system policy. Contact your system administrator.
      To find a driver for this device, click Update Driver.
      I don’t have the mainboard cd no, as I got this PC secondhand, and then added psu out of old pc, and soundcard and gfx card.
      36975-4fxcEurD
      I have been told to go into bios and turn ezyflash 2 on (cos it not support afudos), and will this is my bios view as it is now…
      36976-VMDdqm84
      “I don’t suppose you’ve added a graphics card to the PCI Express x16 slot and are using that instead of the onboard VGA port (hence “cable not connected” on monitor)?”
      Yeah, am using hdmi to my monitor.
      You think if I get a old vga to vga and plug it from mobo to pc, that should allow me to update bios?
      I still have the M2NX0907.ROM renamed to 0907.ROM (For any BIOS update I wouldn’t go any higher then M2NX0907, there is one newer bios for that board but only adds support for some newer CPU’s and if you don’t have an issue with CPU warnings then I would avoid that one like the plague as it adds a function that will not allow you to revert back to an older BIOS.)
      So change to vga to vga. Put the usb in, restart press alt+f2 and bios should start updating.
      Is there a way to save this one?
      Thanx for the help guys.
      What really has me stumped is… it was all working fine and dandy, until I was told to remove all the usb stuff from device manager.. that means without bios update etc- which scares the crap outta me LOL)
      • #1452604
        This link to the Asus Support site shows a link to Nforce drivers for Win 7 x64. Did you use this to download and install the Nforce driver, leading to this screenshot?
        36975-4fxcEurD
        If so then the last line in the screenshot shows successful installation of a chipset driver (nVidia nForce 610i, which I assume is another name for the 6100-405/430).
        The link also shows a link to ASUS Update but the link appears broken. However, see below.
        and also…
        This link is to drivers for Windows XP. If you change the dropdown from WinXP to Windows 7 64-bit then the display shows no drivers (but does show ASUS Update V7.18.02 for Windows 32/64bit XP & 32/64bit Vista& 32/64bit 7 so you could use this to update the BIOS from within Windows).
        I’m not sure what ATK is but it looks like a virtual device and the link is for power management (ATK ACPI) so I’m not clear why you would want to try and install it.
        36976-VMDdqm84
        Click on the Advanced tab (in the BIOS) then select USB Configuration and post a screenshot.
        ”I don’t suppose you’ve added a graphics card to the PCI Express x16 slot and are using that instead of the onboard VGA port (hence “cable not connected” on monitor)?”
        Yes, this may work if you have a floppy disk drive… but see my comment about downloading ASUS Update V7.18.02 for Windows 32/64bit XP & 32/64bit Vista& 32/64bit 7 to update the BIOS from within Windows.
        The manual for your mainboard (see Version E3548 – M2N-MX user’s manual(English)) shows that the built-in EZ Flash BIOS utility expects the new BIOS to be on a floppy disk, not a USB stick. The ASUS Update utility (section 2.1.5) works from within Windows and allows you to save the current version of the BIOS.
        This IS the usual way of resolving these types of issues and may be worth doing again after we’ve checked that the USB configuration in the BIOS is correct and that there are no issues in Device Manager.
        To summarise, I think the best way to proceed is:
        1. Check current USB Configuration in the BIOS (Advanced tab > USB Configuration) and post screenshot.
        2. Download and install ASUS Update (but only if you’re determined to be able to update the BIOS).
        3. Post a screenshot of all devices in Device Manager, expanding the USB section.
    • #1452606
      Usb configuration is good.
      1.1 enabled
      legacy 1.1 enabled
      2.0 usb enabled
      and the speed is hispeed (not full speed)
      ASUS Update V7.18.02 for Windows 32/64bit XP & 32/64bit Vista& 32/64bit 7 <=– am trying that now
      if you're determined to be able to update the BIOS <=– what im determined to do… is to get everything running on my 2 speed usb… NOT 1 speed (never happened before)_, so bios, drivers etc shouldn't have to be redownloaded and installed etc. and its also a fresh install, but still not help LOL)
      36977-1msdABr
      Like that you mean?
      36978-zH5FqBn
      EFT 3 images are the OpenHCD 1.0 controller (8 ports available) the right 3 are the 2.0 (with 7 ports available)
      I can attach mates drive to the USB on mobo at the back, and it goes LEFT, for 1 speed. I remove it, plug another drive in, it goes right side. but it alternates.
      Also this image…
      36979-PHAezZub
      But this, from HWiNFO32 shows something weird, that doesn't show in device manager OR speccy…
      36980-3aEun5b
      The samsung drive, is actually a Iomega drive. but yeah, see the yellow ! mark there? its not in device manager at all…
      No, driver genius is where the screenshot is from., with the fails… so I had to find manually (and then still couldn't install)
      PROGRESS.
      bios is now updated thank you 😀
      But that doesn't solve my usb issue…
    • #1452610
      You have chipset drivers installed; you’ve successfully updated the BIOS (so that rules out corrupt settings); you’ve confirmed that USB Configuration in the BIOS is set correctly (i.e. set to HiSpeed) and Device Manager doesn’t show any issues with any USB root hubs and host controllers. You said that the problem became worse after following advice to remove the USB devices (root hubs and host controllers) in Device Manager.
      I can’t think of anything else to do except a) remove the settings history of your USB connected devices then, if that doesn’t work, b) un-install the root hubs and host controllers from Device Manager and re-boot.
      a) remove the settings history of your USB connected devices:
      1. Read page 1 of this Techspot article and carry out steps 1-6.
      If this doesn’t correct the situation then:
      1. Make sure you are using a PS/2 mouse and keyboard.
      2. Unplug any USB-connected devices.
      3. Uninstall the USB root hubs then USB host controllers from within Device Manager.
      4. Reboot.
      You might see this dialog for a while. If it goes on more than a couple of minutes, just click on the Close button and go into Device Manager.
      36982-usb
      Click to enlarge
      Let us know how you get on when you re-attach your external USB drives.
    • #1452614
      Alright… downloaded and moved.
      I know with XP you could use ps2 as same time as USB.
      So I plugged a, surprised a found one ps2 mouse into slot… I get lights, but no mouse movements.
      So I rebooted pc… maybe it needed to “register” or something…
      I got this error…
      36984-agpWII6E
      I hit f1… goes into bios, I hit esc, don’t save changes and it boots up.
      That could just be a thing about saving?
      Anyways, with this ps2 thing. What if I have none? Or I have, but they not get recognized?
      so I restarted, hit f1, went into bios. f10, saved and exited. booted up (woot) and well, unplugged keyboard put it in ps/2 slot with adapter.. but nope, still not pick up.
      http://prntscr.com/3i5qeg
      ==> If, instead, you get an error message like Command not recognized it means you didn’t move Drivecleanup.exe to the right directory
      http://prntscr.com/3i5qid
      http://prntscr.com/3i5qui
      DriveCleanup.exe file name
      http://prntscr.com/3i5r1g but in system32 … nothing is there?
      I am at a loss now… it tells me it is THERE, when I try to paste it in there. BUT, tells me that error… looking IN the folder, it isn’t there at all to be found.
      Well I thought “fk it” and ran it from where I could see it..
      http://prntscr.com/3i5tci
      http://prntscr.com/3i5tg3
      rebooting now.
      Plugged drives in one by one… and is exactly the same.
      3 externals on the mobo, show up as normal, on enhanced.
      Plug new drive in… and BOOM. straight to the OpenHCD with the 1 speed… and that is in the FOURTH usb port on the mobo… right next to the other three.
      Explain that one for me please LOL
      *confused and dazed and bald now*
    • #1452629
      From the BIOS screenshot it appears the BIOS correctly identified the first 3 mass storage devices as USB 2-capable and mounted them as HiSpeed (i.e. using EHCI). However, immediately after mounting the second Seagate drive the BIOS corrupted (CMOS checksum bad) so you had to correct this. (If it happens again, try using F2 so the default values are used and you can continue.)
      Just in case it’s an issue with one of the Seagate drives (failing drive controller?), you need to do several tests of booting with different mass storage devices (looks like you have a wide selection) to see if there is a ‘mix’ of devices which always causes a CMOS checksum bad condition then try to narrow it down to the one particular drive (probably one of the Seagate’s) which is the culprit.
      For example, use:
      [INDENT]Pass 1
      My Passport external drive
      Toshiba USB3 external drive
      Seagate Expansion Desk 1 external drive
      Pass 2
      Seagate Expansion Desk 2 external drive[/INDENT]
      Another thing to try is to use something like Speccy (which I know you already use) or HDTune to check the health status (S.M.A.R.T.).
      As you already know, there’s something weird going on with your PC. If you look at the http://prntscr.com/3i5tg3%5B/B%5D%5B/url%5D screenshot, you’ll see at the bottom that the registry information was identified but not removed.
      36985-drivecleanup
      Click to enlarge
      If you ran DriveCleanup.exe from an elevated command prompt then it looks like there may be a permissions issue in the registry because the information under HKEY_LOCAL_MACHINESYSTEMCurrentControlSetEnumUSB and HKEY_LOCAL_MACHINESYSTEMCurrentControlSetEnumUSBSTOR was not deleted.
      To check, you can do the same by using Nir Sofer’s USBDeview. Download the x64-bit version, unzip it, right-click on usbdeview.exe and choose Run as administrator.
      When USBDeview opens:
        [*]Scroll to the right and drag the USB Version column far to the left so you can see it.
        [*]Remove your external mass storage devices. USBDeview should show them change to disconnected.
        [*]Press CTRL+F7 to display the root hubs. Your Options should look like this:
        36986-usbdeview-options
        Click to enlarge
        [*]Select all the disconnected mass storage devices (especially any marked as using USB 1.10) and use File > Uninstall Selected Devices.
        36987-usb1
        Click to enlarge
        [*]If you are using a mouse connected using PS/2, select the USB Root Hubs and use File > Uninstall Selected Devices. (Don’t do this if you are using a USB mouse ‘cos you won’t be able to shut down using the mouse.)
        [*]Shutdown.
        [*]Re-attach 3 mass storage devices (Western Digital My Passport external drive, Toshiba USB3 external drive and another Western Digital external drive).
        [*]Restart PC and watch for signs of BIOS corruption.
        [*]Report back with results.
    • #1452659
      Will come back and edit this post and report after this… but will say the “CMOS checksum bad” only appeared after the bios upgrade.
      If you re-read my post, you will see that I couldn’t.
      I extracted the zip. I moved to system32, and cmd (as admin) told me it wasn’t a internal or external command” so I went looking for it IN the system32, couldn’t see it at all. So went to drag it in again, and was told that it was there and to overwrite it. After I over wrote it, I STILL couldn’t see it in system32, so I ran it from folder on the desktop. Which then opened it.
      Alright… not sure if good thing or not.. when I upgraded bios, and it was getting cmos checksum bad after it, and I had to press f1 or f2, and I did f1, went into bios, and then f10 to save settings… never had the stall again, BUT I its either going too quick to notice it, or it not showing on bootup… the flash screen or whatever… it goes from cursor top right… straight to windows loading up. So I not see any text, except “windows” when starting up. Not sure if good or bad.
      36990-7DPnhiY9
      Not sure why usb keyboard says removed, cos I couldn’t and can’t remove it, as no ps2 keyboard… so thats strange… and it turned all the NAMED ext hdds into “mass storage” tho while trying to find the drivers, it had the correct name for them…
      USBD3eview shows this now
      36991-uJ5ijQHP
      I will attqa6ch the toshiba… on the other MOBO usb slot that is free… and see what happens.
      It shows in USBDevices as a 2.10 (it was doing 1.1 from same slot yday.
      Will eject it, and put the Expansion Desk 2.10 Seagate Expansion Desk (I have TWO of these drives. One is on TV, the other is always connected to PC.) and see what happens
      36992-ihDMpgLg
      Okay… that also goes 2.10 (which is good) but it still sees the Toshiba drive.. and what are the other two I have highlighted? “human interface devices”
      Plug something in front and the issue not resolved…..
      36993-IOP5NxiC
      I never ever got the “perform faster” msg, until I uninstalled all the USB devices from device manager when the issue first arose.
      It seems that the drive below, in HWiNFO32 is causing problems? but it is the only place I see it is a issue, device manager shows as fine and all…
      36995-QYZiL5ai
      Info from speccy about that certain drive.
      This is interesting… the iomega drive (which shows as samsung)…
      36996-wcmNU5y
      Why doesn’t it show like all the other devices? 🙂
      Thanx for the help peoples.
      • #1452661
        Your USB-connected system’s setup now appears to be sorted, i.e. all mass storage devices are now running at USB 2.0 with the exception of one of your two USB-connected Expansion Desk external drives.
        The Western Digital hard disk-based device with serial no. WD-WCAZ6533537 appears to have a problem… so you need to determine whether this is to do with the drive itself, its HD controller or the USB interface providing the link between the drive and your PC. (Post again if you need help with diagnostics on this particular device.)
        The rest of the USB sub-system now appears to be fine.
        For info, HIDs (Human Interface Devices like USB keyboards and USB mice) will always use USB 1.10 (‘cos humans just aren’t as fast as computers… except for my daughter txting) instead of USB 2.0 or USB 3.0.
        Also, the Iomega device (using a Samsung hard disk) is just using a USB-based ATA/ATAPI bridge controller to connect the device.
        It looks like both your BIOS update and USB problems have now been sorted.
        As this appears to have been your first topic since joining the forum, I hope this has helped.
    • #1452678
      Sorry, don’t mean to be contradictory, but its not sorted.
      I never ever got “this device can perform faster” EVER now I am- I would like to get it BACK to that, so as whatever drive I plug in, it goes to 2.0… not the 1.1 speed crap. Understand, why I am saying the problem is not sorted?
      How it is now, is exactly how it was when I first came here with the problem- nothings changed.
      I just plugged usb mouse back in……
      36998-aArSnTAJ
      Well as you can see, that is using 2.0…
      “(Human Interface Devices like USB keyboards and USB mice) will always use USB 1.10” <=– with my pc, its not 1.1 as you can see.
      4 USB ports at the back, are on the mobo.
      2 USB ports at the back are old school, that I got from another pc and put in and connected to mobo (that has the keyboard and mouse Logitech K120 combo)
      2 Ports at the front which came with PC.
      The BOTTOM usb port at front is dead. The TOP works. How do I know this? I plugged keyboard in bottom one, booted up "No keyboard installed" I plugged it in the top one, and it told me I had a keyboard.
      If I plug mouse into the old as usb that I connected, and it goes to 2.0, why doesn't the keyboard right next to it?
      Yet I plug a external drive into front port… it straight away tells me it can perform faster, and to attached it to a spare bold port, on the enhanced USB host controller?
      How can I manually get it to do that? To use… the "bold" ports it tells me to connect the drive to (image in previous post).
      And with USDBevice… with the ones "not there" anymore, is it safe to delete/ remove them?
      Please, cos I don't know how to diagnose if it is the drive itself, or the controller (It is on the MAIN mobo ports with the other two, and they are fine… so maybe its the drive itself? But again, I see no probs at all, and can transfer at normal speeds.
      36999-xEnBG0FL
      It says the version is 2.0 BUT it runs slooowwwwww
      Why? *pulls hair out"
      It is plugged into the FRONT top usb port.
    • #1452679
      From your screenshot it appears that all mass storage devices (external hard drives) are now connecting using USB 2.
      Unusually, your mouse also appears to be connecting using USB 2 (so that’s a plus… although IMHO this may be a fault of USBDeview, ‘cos I’ve never known USB mice connect at anything other than USB 1.1… but I could be wrong).
      I understand that the front lower USB port (BOTTOM usb port at front) on your PC appears to be dead but the front upper USB port seems OK.
      I’m having trouble understanding your latest info, i.e.:
      Does this mean:
      4 USB ports at the back are directly connected to the mainboard?
      2 USB ports at the back are connected via a PCI card?
      2 ports at the front of the PC are connected internally (within the PC) to a USB header (one of which appears dead)?
    • #1452688
      Yeah… the 4 usb slots are up near the mobo ethernet, onboard gfx etc.
      The two I put in myself… not connected at all via card as such…. I not think…
      37001-LTFGl4O2
      The highlighted yellow bit. Its just in a slot, and then connected via usb header (I think thats the word you used)
      So WHY, is it saying “can perform faster by plugging it into the enhanced controller” if it is 2.0? Something is messed there yeah?
      37000-ZheQfIZb
      Alright, as soon as I USE that mass storage device in the front (that shows as 2.0 in USBDeview, but actually comes up as 1.1), it disconnects mouse, and keyboard, and I have to reboot every time.
      Grrrrr…. now im getting drive dropping, then saying unknown, yet I can use ALL drives attached to the pc?
      37002-xVjG3MjH
      Seems to have gotten WORSE 🙁
    • #1452707
      Umm… why, in a post about USB problems, did it take until post #15 for you to tell us about the PCI card (with 2 additional USB ports) you had installed?
      We’ve (I’ve) been working with wrong/incomplete information all along. My fault completely… I should have asked better questions.
      I suggest you look into the USB 2 specification and, in particular, about available bandwith (see How USB Ports Work, i.e. what happens when multiple mass storage devices are connected to a low-power bus). Here’s the info:
      “As devices are enumerated, the host is keeping track of the total bandwidth that all of the isochronous and interrupt devices are requesting. They can consume up to 90 percent of the 480 Mbps of bandwidth that’s available (USB 3.0 increases that speed to 4.8 gigabits per second). After 90 percent is used up, the host denies access (my emphasis) to any other isochronous or interrupt devices. Control packets and packets for bulk transfers use any bandwidth left over (at least 10 percent).”
      You may also find these posts about General Fix for USB Driver Problems and Troubleshoot: Windows won’t recognize USB hard drive / fix unassigned drive letter useful.
      I also suggest, if you continue to use USBDeview, that you download and install the USB ID’s list. Read the documentation of USBDeview, particularly the bit about ‘Vendor Name’ And ‘Product Name’ Columns.
    • #1452815
      http://prntscr.com/3ir4lu <=– now getting this constantly.
      Okay, well I never knew about the bit you were just saying… about "bandwidth" etc.
      But please take note of this…
      I NEVER had a problem- EVER. I have always had three permanently attached externals, and have had my phone attached, a little 320gb attached, have had an extra 1tb external attached and a 4tb attached etc… and I cannot state this clearly enough.
      I have NEVER been told "device can perform faster" it has only been, since I removed everything.
      General Fix for USB Driver Problems <=– have done that, didn't help.
      Troubleshoot: Windows won't recognize USB hard drive / fix unassigned drive letter <=– will have a read of that… tho it has no problem identifying any of my drives or assigning any letters.
      Apart from the upgraded bios (thank you). I am now in a WORSE position than I was before I come here 🙁
      That thing that is always popping up now- had also never happened before… so yeah, my problems are worse since I came here..
      So thanx for the bios update- but also, thanx for the BIGGER headache.
      I have removed ALL of my drives… and this msg is STILL popping up constantly. . Thanx a whole heap for nothing 🙁 Gone from annoying and hair pulling, to smashin it up. Thanx.
    • #1452843
      You appear to have a problem in the Windows registry. Why do I think this? Because one of your previous posts shows a screenshot showing ’10 ports’.
      My understanding is that you have 8 USB ports:
      4 USB ports on the rear panel, directly connected to the mainboard
      2 USB ports on the PC’s front fascia, connected to a USB header on the mainboard by a cable
      2 USB ports on a PCI card, connected via the PCI bus on the mainboard
      Q1. Is this correct that you only have 8 physical USB ports in current use?
      Q2. Are you/have you been using a USB hub? (which would explain the discrepancy)
      Q3. Are you using the latest version of Speccy? (i.e. v1.26.698)
      Q4. Have you downloaded the USB ID‘s list? (If not, please right-click on the link, choose Save As (or Save link as…) and save the usb.ids file to the same location at Speccy64.exe.)
      Q5. Are you happy/confident about editing the Windows registry directly? (Note: This is a particularly difficult area… ‘cos any mistakes could result in your PC not booting.)
      For info, the 4 USB ports on the rear panel, directly connected to the mainboard, are the only USB ports that should be used for diagnostics/testing of USB peripherals. The USB ports on the front fascia introduce a microscopic ‘power reduction’ effect due to the wiring used between the USB header on the mainboard and the ports themselves. The effect is minimal (in terms of milliamps) but is still an effect. Likewise, the USB PCI card introduces a change to the ‘standard’ USB environment, i.e. that of using an additional system driver (.sys file) to recognise the device itself.
      If you are happy to continue with diagnostics then, please, only use the 4 USB ports at the rear of the PC which are directly connected to the mainboard.
      Also, as bus-connection speed (i.e. USB 2.0 v 1.10) is an issue, please make sure that your USB mouse and USB keyboard are connected to the 2 USB ports provided by the PCI card (so the 4 ports on the back of the PC that are directly connected to the mainboard are kept free for speed/power-sensitive peripherals). Once you have done this, please carry out a Start > Shutdown cycle twice. (Please do not use Start > Shutdown > Restart) I know it sounds stupid but you/I need the results written to HKEY_LOCAL_MACHINESYSTEMCurrentControlSet and its copies, i.e. HKEY_LOCAL_MACHINESYSTEMCurrentControlSet001, etc.
    • #1452850
      You have:
      1) a software problem
      2) a configuration problem
      3) a driver problem
      4) a malware problem
      5) a hardware problem
      6) a firmware problem
      Firmware: If your computer ever worked, it’s unlikely that you have a firmware problem. In addition to the BIOS, some of the PCI cards also have firmware that can be updated, but if they worked that is also unlikely.
      Hardware: Since you have three different USB hardware controllers, this seems unlikely.
      Malware: This may be more promising, but usually malware does not affect USB ports. If you haven’t used at least 5 different malware scanners, you haven’t really scanned for malware. One of the things that malware scanners are known for is that none of them will catch everything, but if you use several of them, your chances are much improved.
      Driver: You have the most recent driver, but have you tried uninstalling the driver, and then reinstalling it? Sometimes that will do it.
      Configuration: Device Manager, Registry, etc., you have pretty well exhausted this one.
      Software: Reinstalling Windows 7 is the kind of Best Buy Rookie Tech move that you should keep in reserve until you have tried everything else, and just want to get the thing working. You will have to decide if you are there yet.
      • #1452857
        @Prescott, is it OK if I ask a few questions to clarify your post?
        Q. Please clarify. Do you mean USB Host Controllers? If not, what USB-connected hardware controllers are you referring to? (The OP has many hardware controllers in the multiple external devices he has available.)
        Q. Which driver are you referring to? Do you mean a driver for a particular piece of hardware (in which case, which hardware) or do you mean the multiple drivers for the USB protocol components implemented in Windows 7 (i.e. usbd.sys, usbhub.sys, usbport.sys, usbuhci.sys, usbstor.sys, etc.) and how did you determine that, whatever it was, was the most recent? (Whilst I broadly agree with what you say, using sfc /scannow to check Win 7’s built-in USB protocol drivers (which appear to be working) seems a bit extreme at this point.)
        Malware:
        Q. Umm… what’s your evidence to introduce this as a possible issue?
        Q. Given that the Windows registry is dynamic, how did you arrive at this conclusion? (‘cos – sorry – I really have to disagree… in fact, I think it’s fundamental to the OP’s problem.)
        This is the only proposed action I possibly agree with (despite the disparaging “Best Buy Rookie Tech” description) but, given the disruption involved, think the OP is not there yet. Just my opinion though…
    • #1452950
      37008-E7UghM2O
      USBDeview has “identified” what is constantly not being recognized, and what is constantly popping up and such, as a “Standard USB Host Controller”
      I have gone through and seen my options (not letting windows download, but choosing from list) and I get this warning…
      37009-N0zTAv9N
      on any of the usb host controllers, generic controller etc… I haven’t pressed yes, cos not sure of the outcome LOL
      (about that usbdeview image. the keyboard and mouse are a logitech mk120 combo… you would think that it would be both “logitech” as “device mfg”, not a “standard usb host controller”)
      I reinstall won’t help, cos I have already done that. I have cleared the history a few times (driveclean) and have removed ALL usb from pc, leaving only a ps2 mouse connected.
      On reboot, “searching for drivers” etc, and all are good. and then after 5 minutes or so, boom, this msg keeps popping up
      37011-V7mGM8BQ
      I click it and it shows this….
      37010-Iq5eyXb3
      OR, the window is completely blank, cos it not anywhere LMAO
      On the “USB Root Hub” properties “on Standard OpenHCD USB Host Controller”, it has the mouse and keyboard and the unknown device.
      If I click properties on the unknown device in device manger, and then click the driver info… it tells me none a needed or loaded.
      Yes, I only have 8 physical ports.
      4 on mobo. 2 at front, 2 at the back (which is only connected to mobo via usb cable plugged into pc)
      The BOTTOM us at front is dead (no keyboard found” on bootup when one is plugged in there.
      The TOP lets me know a keyboard is there.
      Maybe it IS hardware… that front one is finally dead?
      Something interesting to note.
      Using one REAR mobo ports.
      If I copy something to external toshiba (which is usb 3 usb powered) it takes half an hr or so (1mb/s). and extracting something to it, and it goes quick, and then goes not responding.
      If using the SAME port, I plug in a usb 3.0 dc powered external, it transfers in 2 minutes or so (16mb/s), and extracting is done in quick time aswell.
      Could be a mix of dead front usb ports, AND my 500w psu not enough power to run a USB powered external?
      But I must state, in all my time with this pc… I have NEVER been told “device can perform faster” no matter how many externals have been plugged into pc.
      So in my eyes, something pretty major has happened… and a windows reinstall, bios upgrade, hasn’t fixed the situation.
      Well not sure if it is a card or not, cos it only attached to mobo but a cable (much like the front 2 usb slots), but both mouse and keyboard are there.
    • #1452958
      I’m still struggling to understand your setup. I get that you have 4 USB ports at the back of the PC and 2 on the front fascia. It’s the “2 at the back (which is only connected to mobo via usb cable plugged into pc)” that I don’t understand. Most 2-port adapters are cards that plug into a PCI slot, e.g. like this:
      37014-images
      It sounds like yours is just the plate with 2 ports with a cable running from the 2 ports and connected to a USB header on the mainboard.
      Your registry is definitely messed up.
      37015-screwed
      Click to enlarge
      For example, at position 1 in the picture it shows Hub #0001 yet at position 2 the same device shows as Hub 0. Positions 3 and 4 show as ports 9 and 10… on an 8 port system.
      As another example, this one root hub shows as having 10 ports connected to it.
      37016-10ports
      Click to enlarge
      This hub has the mouse and keyboard attached to it… so I’m beginning to suspect this 2-port adapter itself is faulty (as it’s showing 10 ports instead of just 2). Are you OK with removing this 2-port adapter for the time being whilst we continue troubleshooting?
      This could be down to different spin/bus translation speeds. For example, if the USB powered external Toshiba is a small (2.5″) drive then it’s likely to be a 5400 rpm SATA 1 drive whilst the mains powered external drive could be a 3.5″ SATA 3 drive running at 7200 rpm or even 10000 rpm, i.e. only the USB 3.0 interface would be comparable.
      • #1453006
        when I first posted it kept telling me “ticket expired” or something, so I just copied and posted. Edited and done the images again.
    • #1453003
      Just to trip you out some more than….
      37022-LR5Ngy4S
      If looking at that, says I have a total of 17 available to use.
      9 on enhanced, 8 on standard.
      Not the greatest image I could find… but, to explain the one at the back that I put in…
      37019-YvCwfqVU
      but it only has ONE side…. its only got 2, of a possible 4. Make sense now?
      USB 10 USB 2.0 ports /1.1 ports <=– my mobo has 10 ports available… what THAT breakdown is, I don't know, how many .2.0 and 1.1, not sure, unless its 20 in total? Which would then make sense.
      Would mean putting the mouse and keyboard into the mobo USB, but im fine with that.
      I just wanna get it back so I not see "can perform faster" again, and to stop this window popping up LOL
      So nothing to do with dc powered vs usb powered… well thats good news.
      I have a mate from the UK sending me one of these…
      37020-V261-1004_chiclet01_aa_mn_3526248
      Won't actually give me usb 3 tho, cos mobo is only 2.0 that I can see)
    • #1453004
      I’m not able to open any of the attachments… all 3 come up as ‘invalid attachment’.
      37021-ouch
      Click to enlarge
    • #1453010
      OK, not a great image but you’ve confirmed that it’s what some people call a ‘flying lead adapter’, i.e. it connects to a USB header on the mainboard instead of plugging into a PCI slot.
      The 4-port adapter your friend in the UK is sending you should operate at USB 3 ‘cos it will use the USB 3 controller on the card itself then direct the data through the PCI (Express) bus it’s plugged into.
      How best to progress this situation?
      I suggest you remove the ‘flying lead adapter’. You don’t have to physically remove it, just disconnect it from the mainboard. Here’s what I would do:
      1. Shutdown PC.
      2. Unplug all USB devices from your PC, including mouse and keyboard.
      3. Disconnect the ‘flying lead adapter’ from the mainboard.
      4. Optional – use a PS/2 mouse and PS/2 keyboard until the registry is cleared of stored info about USB devices. If you don’t want to do this, it’s fine.
      5. If not using a PS/2 mouse and PS/2 keyboard then plug USB mouse and USB keyboard into lower 2 USB ports at back of the PC.
      6. Power on PC and wait for USB mouse and USB keyboard to be recognised and become operational.
      7. Remove the settings history of your USB connected devices from the registry using DriveCleanup. (i.e. page 1 of this Techspot article and carry out steps 1-6.) (Why? ‘cos we need to prune your registry of extraneous USB info and make it forget the last known settings/info about USB devices.)
      8. Run Device Manager, click on View in the menubar and select Show hidden devices.
      37023-hidden_devices
      Click to enlarge
      If any devices show an error or issue, post a screenshot showing the error/issue.
      9. Run USBDeview-x64.exe as administrator and post a screenshot showing every device, connected or disconnected. (Why? ‘cos we need to see what’s left in the registry and USBDeview provides a quick, visual record.)
      10. Run Speccy64.exe as administrator, click on File in the menubar and select Save as Text file….
      37024-speccy64
      Click to enlarge
      Post the text file. (Why? ‘cos whilst USBDeview is good, if there IS an issue then we need Speccy’s more comprehensive reporting abilities. Even if there doesn’t appear to be an issue, the Speccy report is worth having as a check that there aren’t any other potential issues.)
      Please try not to attach any other USB devices at this point. I realise you may be impatient to see whether disconnecting the ‘flying lead adapter’ has had any effect on the problems you have been having but I think the approach I’ve described has the best chance of fixing what I believe is down to corruption in your registry.
    • #1453019
      I removed the flying lead… have ps/2 mouse, but can’t get ps/2 keyboard working… and device manager says “This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)”
      I do have a usb/ps/2 adapter, but yeah, if its not working, it can’t be used.
      So I shut down, removed the flying lead from pc.
      Ran driveclean (but I cannot run it link says to.. because of “not internal or external command” or whatever it was, it IS in system32, cos when I try to drag and drop, it says it is there (but, cannot physically see it.))
      So I run it with a right click and run as admin (remember, no keyboard also at the moment) from desktop folder…
      Screenshot below.
      37025-UcOun2Vj
      Device manager showing hidden, and then a right click and properties of the unknown (here you can also see that ps/2 keyboard is ” ! ” which explains why I had to put on USB keyboard to type this msg.
      37026-6ARwn4RK
      This is also USBDeview screen aswell
      37027-cv7lLFy
      Speccy report (from BEFORE I attached the usb keyboard.)
      Summary
      Operating System
      Windows 7 Ultimate 64-bit SP1
      CPU
      AMD Athlon 64 X2 3800+ 32 °C
      Windsor 90nm Technology
      RAM
      6.00GB Single-Channel DDR2 @ 334MHz (5-5-5-15)
      Motherboard
      ASUSTeK Computer INC. M2N-MX (CPU 1) 35 °C
      Graphics
      Acer P241W (1920×1200@60Hz)
      ATI Radeon HD 5450 (Gigabyte) 50 °C
      Storage
      149GB MAXTOR S TM3160215AS SCSI Disk Device (SATA) 41 °C
      931GB Seagate ST1000DM 003-9YN162 SCSI Disk Device (SATA) 36 °C
      Optical Drives
      Philips DVD+RW DVD8601 ATA Device
      PIONEER DVD-RW DVR-110D ATA Device
      Audio
      SB 5.1 VX
      Operating System
      Computer type: Desktop
      Installation Date: 1/05/2014 3:00:55 PM
      Windows Security Center
      User Account Control (UAC) Enabled
      Notify level 2 – Default
      Firewall Enabled
      Antivirus Disabled
      Windows Update
      AutoUpdate Download Automatically and Notify Prior to Install
      Windows Defender
      Windows Defender Enabled
      .NET Frameworks installed
      v4.5 Full
      v4.5 Client
      v3.5 SP1
      v3.0 SP2
      v2.0 SP2
      Internet Explorer
      Version 11.0.9600.17107
      PowerShell
      Version 2.0
      Java
      Java Runtime Environment
      Path C:Program Files (x86)Javajre7binjava.exe
      Version 7.0
      Update 55
      Build 14
      Environment Variables
      USERPROFILE C:Usersr3b3lw0lf
      SystemRoot C:Windows
      User Variables
      TEMP C:Usersr3b3lw0lfAppDataLocalTemp
      TMP C:Usersr3b3lw0lfAppDataLocalTemp
      Machine Variables
      ComSpec C:Windowssystem32cmd.exe
      devmgr_show_nonpresent_devices 1
      FP_NO_HOST_CHECK NO
      NUMBER_OF_PROCESSORS 2
      OS Windows_NT
      Path C:Windowssystem32
      C:Windows
      C:WindowsSystem32Wbem
      C:WindowsSystem32WindowsPowerShellv1.0
      PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
      PROCESSOR_ARCHITECTURE AMD64
      PROCESSOR_IDENTIFIER AMD64 Family 15 Model 75 Stepping 2, AuthenticAMD
      PROCESSOR_LEVEL 15
      PROCESSOR_REVISION 4b02
      PSModulePath C:Windowssystem32WindowsPowerShellv1.0Modules
      TEMP C:WindowsTEMP
      TMP C:WindowsTEMP
      USERNAME SYSTEM
      windir C:Windows
      windows_tracing_flags 3
      windows_tracing_logfile C:BVTBinTestsinstallpackagecsilogfile.log
      Power Profile
      Active power scheme Balanced
      Hibernation Enabled
      Turn Off Monitor after: (On AC Power) Never
      Turn Off Hard Disk after: (On AC Power) Never
      Suspend after: (On AC Power) Never
      Screen saver Disabled
      Uptime
      Current Session
      Current Time 15/05/2014 1:30:01 PM
      Current Uptime 592 sec (0 d, 00 h, 09 m, 52 s)
      Last Boot Time 15/05/2014 1:20:09 PM
      Services
      Running AMD External Events Utility
      Running Application Experience
      Running Application Information
      Running Background Intelligent Transfer Service
      Running Base Filtering Engine
      Running CNG Key Isolation
      Running COM+ Event System
      Running Computer Browser
      Running Creative Audio Service
      Running Cryptographic Services
      Running DCOM Server Process Launcher
      Running Desktop Window Manager Session Manager
      Running DHCP Client
      Running Diagnostic Policy Service
      Running Diagnostic Service Host
      Running Diagnostic System Host
      Running Distributed Link Tracking Client
      Running DNS Client
      Running ForceWare Intelligent Application Manager (IAM)
      Running ForceWare IP service
      Running Function Discovery Provider Host
      Running Function Discovery Resource Publication
      Running Group Policy Client
      Running HomeGroup Listener
      Running HomeGroup Provider
      Running IP Helper
      Running Microsoft .NET Framework NGEN v4.0.30319_X64
      Running Microsoft .NET Framework NGEN v4.0.30319_X86
      Running Multimedia Class Scheduler
      Running Network Connections
      Running Network List Service
      Running Network Location Awareness
      Running Network Store Interface Service
      Running Offline Files
      Running Peer Name Resolution Protocol
      Running Peer Networking Grouping
      Running Peer Networking Identity Manager
      Running Plug and Play
      Running Power
      Running Print Spooler
      Running Program Compatibility Assistant Service
      Running Remote Procedure Call (RPC)
      Running RPC Endpoint Mapper
      Running Security Accounts Manager
      Running Security Center
      Running Server
      Running Shell Hardware Detection
      Running SSDP Discovery
      Running Superfetch
      Running System Event Notification Service
      Running Tablet PC Input Service
      Running Task Scheduler
      Running TCP/IP NetBIOS Helper
      Running TeamViewer 9
      Running Themes
      Running UPnP Device Host
      Running User Profile Service
      Running Windows Audio
      Running Windows Audio Endpoint Builder
      Running Windows Defender
      Running Windows Event Log
      Running Windows Firewall
      Running Windows Font Cache Service
      Running Windows Image Acquisition (WIA)
      Running Windows Management Instrumentation
      Running Windows Media Player Network Sharing Service
      Running Windows Modules Installer
      Running Windows Search
      Running Windows Update
      Running WinHTTP Web Proxy Auto-Discovery Service
      Running Workstation
      Stopped ActiveX Installer (AxInstSV)
      Stopped Adaptive Brightness
      Stopped Application Identity
      Stopped Application Layer Gateway Service
      Stopped Application Management
      Stopped ASP.NET State Service
      Stopped BitLocker Drive Encryption Service
      Stopped Block Level Backup Engine Service
      Stopped Bluetooth Support Service
      Stopped BranchCache
      Stopped Certificate Propagation
      Stopped COM+ System Application
      Stopped Creative Audio Engine Licensing Service
      Stopped Credential Manager
      Stopped Disk Defragmenter
      Stopped Distributed Transaction Coordinator
      Stopped Encrypting File System (EFS)
      Stopped Extensible Authentication Protocol
      Stopped Fax
      Stopped Health Key and Certificate Management
      Stopped Human Interface Device Access
      Stopped IKE and AuthIP IPsec Keying Modules
      Stopped Interactive Services Detection
      Stopped Internet Connection Sharing (ICS)
      Stopped Internet Explorer ETW Collector Service
      Stopped IPsec Policy Agent
      Stopped KtmRm for Distributed Transaction Coordinator
      Stopped Link-Layer Topology Discovery Mapper
      Stopped Logitech Bluetooth Service
      Stopped Media Center Extender Service
      Stopped Microsoft .NET Framework NGEN v2.0.50727_X64
      Stopped Microsoft .NET Framework NGEN v2.0.50727_X86
      Stopped Microsoft iSCSI Initiator Service
      Stopped Microsoft Software Shadow Copy Provider
      Stopped Mozilla Maintenance Service
      Stopped Net.Msmq Listener Adapter
      Stopped Net.Pipe Listener Adapter
      Stopped Net.Tcp Listener Adapter
      Stopped Net.Tcp Port Sharing Service
      Stopped Netlogon
      Stopped Network Access Protection Agent
      Stopped Parental Controls
      Stopped Performance Counter DLL Host
      Stopped Performance Logs & Alerts
      Stopped PnP-X IP Bus Enumerator
      Stopped PNRP Machine Name Publication Service
      Stopped Portable Device Enumerator Service
      Stopped Problem Reports and Solutions Control Panel Support
      Stopped Protected Storage
      Stopped Quality Windows Audio Video Experience
      Stopped Remote Access Auto Connection Manager
      Stopped Remote Access Connection Manager
      Stopped Remote Desktop Configuration
      Stopped Remote Desktop Services
      Stopped Remote Desktop Services UserMode Port Redirector
      Stopped Remote Procedure Call (RPC) Locator
      Stopped Remote Registry
      Stopped Routing and Remote Access
      Stopped Secondary Logon
      Stopped Secure Socket Tunneling Protocol Service
      Stopped Skype Updater
      Stopped Smart Card
      Stopped Smart Card Removal Policy
      Stopped SNMP Trap
      Stopped Software Protection
      Stopped SPP Notification Service
      Stopped Telephony
      Stopped Thread Ordering Server
      Stopped TPM Base Services
      Stopped Virtual Disk
      Stopped Volume Shadow Copy
      Stopped WebClient
      Stopped Windows Activation Technologies Service
      Stopped Windows Backup
      Stopped Windows Biometric Service
      Stopped Windows CardSpace
      Stopped Windows Color System
      Stopped Windows Connect Now – Config Registrar
      Stopped Windows Driver Foundation – User-mode Driver Framework
      Stopped Windows Error Reporting Service
      Stopped Windows Event Collector
      Stopped Windows Installer
      Stopped Windows Media Center Receiver Service
      Stopped Windows Media Center Scheduler Service
      Stopped Windows Presentation Foundation Font Cache 3.0.0.0
      Stopped Windows Remote Management (WS-Management)
      Stopped Windows Time
      Stopped Wired AutoConfig
      Stopped WLAN AutoConfig
      Stopped WMI Performance Adapter
      Stopped WWAN AutoConfig
      TimeZone
      TimeZone GMT +10:00 Hours
      Language English (Australia)
      Location Australia
      Format English (Australia)
      Currency $
      Date Format d/MM/yyyy
      Time Format h:mm:ss tt
      Scheduler
      15/05/2014 3:43 PM; update-S-1-5-21-1446195657-538869315-47644463-1001
      15/05/2014 4:32 PM; update-sys
      CCleanerSkipUAC
      Clean System Memory
      Hotfixes
      15/05/2014 Security Update for Windows 7 for x64-based Systems (KB2926765)
      A security issue has been identified in a Microsoft software
      product that could affect your system. You can help protect your
      system by installing this update from Microsoft. For a complete
      listing of the issues that are included in this update, see the
      associated Microsoft Knowledge Base article. After you install
      this update, you may have to restart your system.
      15/05/2014 Update for Windows 7 for x64-based Systems (KB2952664)
      Install this update to resolve issues in Windows. For a complete
      associated Microsoft Knowledge Base article for more information.
      After you install this item, you may have to restart your computer.
      15/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2931356)
      15/05/2014 Security Update for Internet Explorer 11 for Windows 7 for x64-based Systems (KB2953522)
      15/05/2014 Security Update for Windows 7 for x64-based Systems (KB2871997)
      15/05/2014 Windows Malicious Software Removal Tool x64 – May 2014 (KB890830)
      After the download, this tool runs one time to check your computer
      for infection by specific, prevalent malicious software (including
      Blaster, Sasser, and Mydoom) and helps remove any infection that
      is found. If an infection is found, the tool will display a status
      report the next time that you start your computer. A new version
      of the tool will be offered every month. If you want to manually
      run the tool on your computer, you can download a copy from the
      Microsoft Download Center, or you can run an online version from
      microsoft.com. This tool is not a replacement for an antivirus
      product. To help protect your computer, you should use an antivirus
      product.
      15/05/2014 Security Update for Microsoft .NET Framework 4.5 and 4.5.1 on Windows 7, Vista, Server 2008, Server 2008 R2 x64 (KB2931368)
      13/05/2014 Definition Update for Windows Defender – KB915597 (Definition 1.173.1985.0)
      Install this update to revise the definition files used to detect
      spyware and other potentially unwanted software. Once you have
      installed this item, it cannot be removed.
      11/05/2014 Security Update for Internet Explorer 11 for Windows 7 for x64-based Systems (KB2964358)
      11/05/2014 nVidia – Network – NVIDIA nForce Networking Controller
      nVidia Network software update released in August, 2010
      10/05/2014 Cumulative Security Update for Internet Explorer 11 for Windows 7 for x64-based Systems (KB2929437)
      10/05/2014 Update for Windows 7 for x64-based Systems (KB2952664)
      10/05/2014 Definition Update for Windows Defender – KB915597 (Definition 1.173.1690.0)
      3/05/2014 Definition Update for Windows Defender – KB915597 (Definition 1.173.1100.0)
      3/05/2014 Update for Windows 7 for x64-based Systems (KB2515325)
      This is a reliability update. This update resolves some performance
      and reliability issues in Windows. By applying this update, you
      can achieve better performance and responsiveness in various
      scenarios. For more information please see the Knowledge Base
      article. After you install this item, you may have to restart
      your computer.
      3/05/2014 Update for Windows 7 for x64-based Systems (KB2913152)
      3/05/2014 Security Update for Microsoft .NET Framework 4.5.1 on Windows 7, Vista, Server 2008, and Server 2008 R2 for x64 (KB2898869)
      3/05/2014 Security Update for Microsoft .NET Framework 4.5.1 on Windows 7, Vista, Server 2008, and Server 2008 R2 for x64 (KB2901126)
      3/05/2014 Update for Windows 7 for x64-based Systems (KB2923545)
      3/05/2014 Security Update for Windows 7 for x64-based Systems (KB2912390)
      3/05/2014 Cumulative Security Update for Internet Explorer 11 for Windows 7 for x64-based Systems (KB2925418)
      3/05/2014 Update for Windows 7 for x64-based Systems (KB2732487)
      3/05/2014 Security Update for Windows 7 for x64-based Systems (KB2532531)
      A security issue has been identified that could allow an unauthenticated
      remote attacker to compromise your system and gain control over
      it. You can help protect your system by installing this update
      from Microsoft. After you install this update, you may have to
      3/05/2014 Update for Windows 7 for x64-based Systems (KB982018)
      your computer.
      3/05/2014 Update for Windows 7 for x64-based Systems (KB2929755)
      3/05/2014 Update for Windows 7 for x64-based Systems (KB2647753)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2656356)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2847077)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2563227)
      Install this update to resolve performance and reliability issues
      in Windows. By applying this update, you can achieve better performance
      and responsiveness in various scenarios. For a complete listing
      of the issues that are included in this update, see the associated
      Microsoft Knowledge Base article for more information. After
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2789645)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2891804)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2560656)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2918077)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2800095)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2552343)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2864058)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2756921)
      1/05/2014 Microsoft .NET Framework 4.5.1 for Windows 7 x64-based Systems (KB2858725)
      The Microsoft .NET Framework 4.5.1 is a highly compatible, in-place
      update to the .NET Framework 4 and 4.5. By using the .NET Framework
      4.5.1 together with the C# or Visual Basic programming languages,
      you can write Windows Store apps. The .NET Framework 4.5.1 delivers
      better performance, reliability, and security than previous versions.
      After you install this update, you may have to restart your computer.
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2620704)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2533552)
      Install this update to enable future updates to install successfully
      on all editions of Windows 7 or Windows Server 2008 R2. This
      update may be required before selected future updates can be
      installed. After you install this item, it cannot be removed.
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2763523)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2813347)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2862966)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2718704)
      Install this update to resolve an issue which requires an update
      to the certificate revocation list on Windows systems and to
      keep your systems certificate list up to date. After you install
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2479943)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2820331)
      Install this update to resolve a set of known application compatibility
      issues with Windows. For a complete listing of the issues that
      are included in this update, see the associated Microsoft Knowledge
      Base article for more information. After you install this item,
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2840631)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2631813)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2640148)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2547666)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2798162)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2536276)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2585542)
      remote attacker to compromise your system and gain access to
      information. You can help protect your system by installing this
      update from Microsoft. After you install this update, you may
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2901112)
      1/05/2014 Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2836942)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2919469)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2840149)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2868626)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2929733)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2893294)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2904266)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2884256)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2916036)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2660075)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2844286)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2898857)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2875783)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2570947)
      1/05/2014 Cumulative Security Update for ActiveX Killbits for Windows 7 for x64-based Systems (KB2900986)
      1/05/2014 Update for Kernel-Mode Driver Framework version 1.11 for Windows 7 for x64-based Systems (KB2685811)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2887069)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2545698)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2676562)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2930275)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2853952)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2847927)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2893519)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2847311)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2506212)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2868725)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2843630)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2691442)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2862330)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2834140)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2719857)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2603229)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2872339)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2803821)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2807986)
      A security issue has been identified that could allow an authenticated
      local attacker to compromise your system and gain control over
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2667402)
      remote attacker to cause the affected system to stop responding.
      You can help protect your system by installing this update from
      Microsoft. After you install this update, you may have to restart
      your system.
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2864202)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2849470)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2868038)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2757638)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2750841)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2862335)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2709630)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2509553)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2758857)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2846960)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2770660)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2862973)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2785220)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2732059)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2604115)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2536275)
      your system.
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2786400)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2911501)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2861855)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2773072)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2579686)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2685939)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2791765)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2729452)
      1/05/2014 ATK – system – ATK0110 ACPI UTILITY
      Driver update provided by ATK for support of ATK0110 ACPI UTILITY
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2742599)
      1/05/2014 Update for User-Mode Driver Framework version 1.11 for Windows 7 for x64-based Systems (KB2685813)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2913431)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2690533)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2743555)
      your system.
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2699779)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2726535)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2621440)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2863240)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2908783)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2727528)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2506014)
      An issue has been identified that could allow a user with administrative
      permissions to load an unsigned driver. This update resolves
      that issue. You can help protect your system by installing this
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2868116)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2861698)
      1/05/2014 Windows Malicious Software Removal Tool x64 – April 2014 (KB890830)
      product.
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2839894)
      1/05/2014 Definition Update for Windows Defender – KB915597 (Definition 1.173.822.0)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2876331)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2929961)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2761217)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2808679)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2532531)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2835364)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2653956)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 for x64-based Systems (KB2861191)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2868623)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2705219)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2922229)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2506928)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2799926)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2732500)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2491683)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2544893)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2654428)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2928562)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2813430)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2892074)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2712808)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2511455)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2564958)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2619339)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2876284)
      1/05/2014 Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2836943)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 for x64-based Systems (KB2832414)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2834886)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2835361)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2698365)
      1/05/2014 Security Update for Microsoft .NET Framework 3.5.1 on Windows 7 and Windows Server 2008 R2 SP1 for x64-based Systems (KB2736422)
      remote attacker to cause the affected application to stop responding.
      your system.
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2862152)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2852386)
      1/05/2014 Security Update for Windows 7 for x64-based Systems (KB2584146)
      1/05/2014 Internet Explorer 11 for Windows 7 for x64-based Systems
      Download the fast and fluid browser recommended for Windows 7.
      Internet Explorer 11. Fast and fluid for Windows 7.
      • Fast.
      Fast at loading sites and fluid as you navigate through them.
      • Easy. Seamless with Windows, it just works the way you want.
      • Safer. Better protection from threats and increased privacy
      online.
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2709981)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2830477)
      1/05/2014 Acer Inc. – Display – Acer P241W (HDMI)
      Acer Inc. Display software update released in September, 2007
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2592687)
      The Remote Desktop Protocol 8.0 update enables you to use the
      new Remote Desktop Services features. These features are introduced
      in Windows 8 and in Windows Server 2012 and are available for
      computers that are running Windows 7 Service Pack 1 or Windows
      Server 2008 R2 Service Pack 1. After you install this item, you
      1/05/2014 Update for Windows 7 for x64-based Systems (KB2574819)
      1/05/2014 ATI Technologies Inc. – Display – ATI Radeon HD 5450
      ATI Technologies Inc. Display software update released in January,
      2011
      1/05/2014 Creative – Other hardware – SB 5.1 VX
      Creative Other hardware software update released in October,
      2009
      1/05/2014 Platform Update for Windows 7 x64-Edition (KB2670838)
      1/05/2014 Update for Windows 7 for x64-based Systems (KB971033)
      This update to Windows Activation Technologies detects activation
      exploits and tampering to key Windows system files. These exploits
      try to bypass regular Windows activation and are sometimes included
      within counterfeit copies of Windows.
      1/05/2014 Windows Update Agent 7.6.7600.256
      The Windows Update Agent enables your computer to search for
      and install updates from an update service. The agent can automatically
      update itself as needed to communicate with the update service
      when Windows searches for new updates.
      System Folders
      Application Data C:ProgramData
      Cookies C:Usersr3b3lw0lfAppDataRoamingMicrosoftWindowsCookies
      Desktop C:Usersr3b3lw0lfDesktop
      Documents C:UsersPublicDocuments
      Fonts C:WindowsFonts
      Global Favorites C:Usersr3b3lw0lfFavorites
      Internet History C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsHistory
      Local Application Data C:Usersr3b3lw0lfAppDataLocal
      Music C:UsersPublicMusic
      Path for burning CD C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsBurnBurn
      Physical Desktop C:Usersr3b3lw0lfDesktop
      Pictures C:UsersPublicPictures
      Program Files C:Program Files
      Public Desktop C:UsersPublicDesktop
      Start Menu C:ProgramDataMicrosoftWindowsStart Menu
      Start Menu Programs C:ProgramDataMicrosoftWindowsStart MenuPrograms
      Startup C:ProgramDataMicrosoftWindowsStart MenuProgramsStartup
      Templates C:ProgramDataMicrosoftWindowsTemplates
      Temporary Internet Files C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsTemporary Internet Files
      User Favorites C:Usersr3b3lw0lfFavorites
      Videos C:UsersPublicVideos
      Windows Directory C:Windows
      Windows/System C:Windowssystem32
      Process List
      atieclxx.exe
      Process ID 1064
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32atieclxx.exe
      Memory Usage 216 KB
      Peak Memory Usage 6.16 MB
      atiesrxx.exe
      Process ID 764
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32atiesrxx.exe
      Memory Usage 160 KB
      Peak Memory Usage 4.06 MB
      audiodg.exe
      Process ID 236
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Memory Usage 16 MB
      Peak Memory Usage 20 MB
      csrss.exe
      Process ID 348
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32csrss.exe
      Memory Usage 1.46 MB
      Peak Memory Usage 4.15 MB
      csrss.exe
      Process ID 432
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 11 MB
      Peak Memory Usage 25 MB
      CTAudSvc.exe
      Process ID 340
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Program Files (x86)CreativeShared FilesCTAudSvc.exe
      Memory Usage 136 KB
      Peak Memory Usage 4.32 MB
      dwm.exe
      Process ID 1916
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Windowssystem32Dwm.exe
      Memory Usage 400 KB
      Peak Memory Usage 9.27 MB
      explorer.exe
      Process ID 2076
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:WindowsExplorer.EXE
      Memory Usage 40 MB
      Peak Memory Usage 59 MB
      firefox.exe
      Process ID 4048
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program Files (x86)Aurorafirefox.exe
      Memory Usage 202 MB
      Peak Memory Usage 377 MB
      HPNetworkCommunicator.exe
      Process ID 3200
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program FilesHPHP Deskjet 3520 seriesBinHPNetworkCommunicator.exe
      Memory Usage 1.07 MB
      Peak Memory Usage 8.16 MB
      HPNetworkCommunicatorCom.exe
      Process ID 3040
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program FilesHPHP Deskjet 3520 seriesBinHPNetworkCommunicatorCom.exe
      Memory Usage 2.57 MB
      Peak Memory Usage 9.41 MB
      hpwuschd2.exe
      Process ID 2656
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program Files (x86)HPHP Software Updatehpwuschd2.exe
      Memory Usage 404 KB
      Peak Memory Usage 3.46 MB
      jusched.exe
      Process ID 2668
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program Files (x86)Common FilesJavaJava Updatejusched.exe
      Memory Usage 140 KB
      Peak Memory Usage 4.18 MB
      KHALMNPR.exe
      Process ID 2736
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program FilesCommon FilesLogiShrdKHAL3KHALMNPR.EXE
      Peak Memory Usage 10 MB
      Lightshot.exe
      Process ID 2456
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Usersr3b3lw0lfAppDataLocalSkillbrainslightshot5.1.0.15Lightshot.exe
      Memory Usage 548 KB
      Peak Memory Usage 6.35 MB
      lsass.exe
      Process ID 484
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32lsass.exe
      Memory Usage 2.99 MB
      Peak Memory Usage 11 MB
      lsm.exe
      Process ID 492
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32lsm.exe
      Memory Usage 1.30 MB
      Peak Memory Usage 4.04 MB
      mscorsvw.exe
      Process ID 3832
      User SYSTEM
      Domain NT AUTHORITY
      Path C:WindowsMicrosoft.NETFrameworkv4.0.30319mscorsvw.exe
      Memory Usage 1.83 MB
      Peak Memory Usage 8.82 MB
      mscorsvw.exe
      Process ID 3964
      User SYSTEM
      Domain NT AUTHORITY
      Path C:WindowsMicrosoft.NETFramework64v4.0.30319mscorsvw.exe
      Memory Usage 4.96 MB
      nSvcAppFlt.exe
      Process ID 1604
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Program FilesNVIDIA CorporationNetworkAccessManagerbin32nSvcAppFlt.exe
      Memory Usage 1.27 MB
      Peak Memory Usage 5.72 MB
      nSvcIp.exe
      Process ID 1640
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Program FilesNVIDIA CorporationNetworkAccessManagerbin32nSvcIp.exe
      Memory Usage 928 KB
      Peak Memory Usage 7.78 MB
      RocketDock.exe
      Process ID 2440
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program Files (x86)RocketDockRocketDock.exe
      Memory Usage 5.52 MB
      Peak Memory Usage 12 MB
      rundll32.exe
      Process ID 676
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:WindowsSystem32rundll32.exe
      Memory Usage 896 KB
      Peak Memory Usage 5.98 MB
      rundll32.exe
      Process ID 2636
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:WindowsSysWOW64rundll32.exe
      Memory Usage 440 KB
      Peak Memory Usage 6.97 MB
      rundll32.exe
      Process ID 2528
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Windowssystem32RunDll32.exe
      Memory Usage 5.14 MB
      Peak Memory Usage 14 MB
      ScanToPCActivationApp.exe
      Process ID 2448
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program FilesHPHP Deskjet 3520 seriesBinScanToPCActivationApp.exe
      SearchFilterHost.exe
      Process ID 2192
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32SearchFilterHost.exe
      Memory Usage 12 MB
      Peak Memory Usage 13 MB
      SearchIndexer.exe
      Process ID 2652
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32SearchIndexer.exe
      Memory Usage 13 MB
      Peak Memory Usage 16 MB
      SearchProtocolHost.exe
      Process ID 3220
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32SearchProtocolHost.exe
      Memory Usage 13 MB
      services.exe
      Process ID 468
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32services.exe
      Memory Usage 3.57 MB
      SetPoint.exe
      Process ID 2392
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program FilesLogitechSetPointPSetPoint.exe
      Memory Usage KB
      Peak Memory Usage 17 MB
      Skype.exe
      Process ID 2428
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program Files (x86)SkypePhoneSkype.exe
      Memory Usage 20 MB
      Peak Memory Usage 80 MB
      smss.exe
      Process ID 256
      User SYSTEM
      Domain NT AUTHORITY
      Path SystemRootSystem32smss.exe
      Memory Usage 80 KB
      Peak Memory Usage 1.10 MB
      Speccy64.exe
      Process ID 3276
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program FilesSpeccySpeccy64.exe
      Memory Usage 25 MB
      Peak Memory Usage 26 MB
      spoolsv.exe
      Process ID 1280
      User SYSTEM
      Domain NT AUTHORITY
      Path C:WindowsSystem32spoolsv.exe
      Memory Usage 2.83 MB
      svchost.exe
      Process ID 1476
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Path C:Windowssystem32svchost.exe
      Memory Usage 1.36 MB
      Peak Memory Usage 9.50 MB
      svchost.exe
      Process ID 1412
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Memory Usage 2.69 MB
      svchost.exe
      Process ID 1316
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Memory Usage 6.36 MB
      Peak Memory Usage 47 MB
      svchost.exe
      Process ID 1108
      User NETWORK SERVICE
      Domain NT AUTHORITY
      Memory Usage 4.62 MB
      svchost.exe
      Process ID 412
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 1.14 MB
      Peak Memory Usage 5.12 MB
      svchost.exe
      Process ID 936
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 110 MB
      Peak Memory Usage 353 MB
      svchost.exe
      Process ID 912
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Memory Usage 3.59 MB
      svchost.exe
      Process ID 848
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Path C:WindowsSystem32svchost.exe
      Memory Usage 7.59 MB
      Peak Memory Usage 21 MB
      svchost.exe
      Process ID 3348
      User LOCAL SERVICE
      Domain NT AUTHORITY
      Memory Usage 4.61 MB
      svchost.exe
      Process ID 720
      Domain NT AUTHORITY
      Memory Usage 3.35 MB
      Peak Memory Usage 7.68 MB
      svchost.exe
      Process ID 644
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 3.28 MB
      Peak Memory Usage 9.43 MB
      svchost.exe
      Process ID 888
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 79 MB
      Peak Memory Usage 112 MB
      svchost.exe
      Process ID 1628
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 21 MB
      Peak Memory Usage 68 MB
      System
      Process ID 4
      Memory Usage 824 KB
      Peak Memory Usage 9.77 MB
      System Idle Process
      Process ID 0
      taskeng.exe
      Process ID 3932
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32taskeng.exe
      Memory Usage 1.11 MB
      Peak Memory Usage 4.72 MB
      taskhost.exe
      Process ID 2340
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Windowssystem32taskhost.exe
      Memory Usage 4.09 MB
      TeamViewer_Service.exe
      Process ID 1516
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Program Files (x86)TeamViewerVersion9TeamViewer_Service.exe
      Memory Usage 1.91 MB
      Peak Memory Usage 15 MB
      TrustedInstaller.exe
      Process ID 2780
      User SYSTEM
      Domain NT AUTHORITY
      Path C:WindowsservicingTrustedInstaller.exe
      Memory Usage 17 MB
      Peak Memory Usage 95 MB
      uTorrent.exe
      Process ID 2464
      User r3b3lw0lf
      Domain r3b3lw0lf-PC
      Path C:Program Files (x86)uTorrentuTorrent.exe
      Memory Usage 4.56 MB
      wininit.exe
      Process ID 416
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32wininit.exe
      Memory Usage 172 KB
      Peak Memory Usage 4.31 MB
      winlogon.exe
      Process ID 584
      User SYSTEM
      Domain NT AUTHORITY
      Path C:Windowssystem32winlogon.exe
      Memory Usage 1.16 MB
      Peak Memory Usage 8.09 MB
      WmiPrvSE.exe
      Process ID 3300
      Domain NT AUTHORITY
      Path C:Windowssystem32wbemwmiprvse.exe
      Memory Usage 11 MB
      WmiPrvSE.exe
      Process ID 3700
      User SYSTEM
      Domain NT AUTHORITY
      Memory Usage 6.09 MB
      Peak Memory Usage 6.09 MB
      wmpnetwk.exe
      Process ID 3096
      Domain NT AUTHORITY
      Path C:Program FilesWindows Media Playerwmpnetwk.exe
      Memory Usage 7.22 MB
      Peak Memory Usage 29 MB
      Security Options
      Accounts: Administrator account status Disabled
      Accounts: Guest account status Disabled
      Accounts: Limit local account use of blank passwords to console logon only Enabled
      Accounts: Rename administrator account Administrator
      Accounts: Rename guest account Guest
      Audit: Audit the access of global system objects Disabled
      Audit: Audit the use of Backup and Restore privilege Disabled
      Audit: Force audit policy subcategory settings (Windows Vista or later) to override audit policy category settings Not Defined
      Audit: Shut down system immediately if unable to log security audits Disabled
      DCOM: Machine Access Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
      DCOM: Machine Launch Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
      Devices: Allow undock without having to log on Enabled
      Devices: Allowed to format and eject removable media Not Defined
      Devices: Prevent users from installing printer drivers Disabled
      Devices: Restrict CD-ROM access to locally logged-on user only Not Defined
      Devices: Restrict floppy access to locally logged-on user only Not Defined
      Domain controller: Allow server operators to schedule tasks Not Defined
      Domain controller: LDAP server signing requirements Not Defined
      Domain controller: Refuse machine account password changes Not Defined
      Domain member: Digitally encrypt or sign secure channel data (always) Enabled
      Domain member: Digitally encrypt secure channel data (when possible) Enabled
      Domain member: Digitally sign secure channel data (when possible) Enabled
      Domain member: Disable machine account password changes Disabled
      Domain member: Maximum machine account password age 30 days
      Domain member: Require strong (Windows 2000 or later) session key Enabled
      Interactive logon: Display user information when the session is locked Not Defined
      Interactive logon: Do not display last user name Disabled
      Interactive logon: Do not require CTRL+ALT+DEL Not Defined
      Interactive logon: Message text for users attempting to log on
      Interactive logon: Message title for users attempting to log on
      Interactive logon: Number of previous logons to cache (in case domain controller is not available) 10 logons
      Interactive logon: Prompt user to change password before expiration 5 days
      Interactive logon: Require Domain Controller authentication to unlock workstation Disabled
      Interactive logon: Require smart card Disabled
      Interactive logon: Smart card removal behavior No Action
      Microsoft network client: Digitally sign communications (always) Disabled
      Microsoft network client: Digitally sign communications (if server agrees) Enabled
      Microsoft network client: Send unencrypted password to third-party SMB servers Disabled
      Microsoft network server: Amount of idle time required before suspending session 15 minutes
      Microsoft network server: Digitally sign communications (always) Disabled
      Microsoft network server: Digitally sign communications (if client agrees) Disabled
      Microsoft network server: Disconnect clients when logon hours expire Enabled
      Microsoft network server: Server SPN target name validation level Not Defined
      Network access: Allow anonymous SID/Name translation Disabled
      Network access: Do not allow anonymous enumeration of SAM accounts Enabled
      Network access: Do not allow anonymous enumeration of SAM accounts and shares Disabled
      Network access: Do not allow storage of passwords and credentials for network authentication Disabled
      Network access: Let Everyone permissions apply to anonymous users Disabled
      Network access: Named Pipes that can be accessed anonymously
      Network access: Remotely accessible registry paths SystemCurrentControlSetControlProductOptions,SystemCurrentControlSetControlServer Applications,SoftwareMicrosoftWindows NTCurrentVersion
      Network access: Remotely accessible registry paths and sub-paths SystemCurrentControlSetControlPrintPrinters,SystemCurrentControlSetServicesEventlog,SoftwareMicrosoftOLAP Server,SoftwareMicrosoftWindows NTCurrentVersionPrint,SoftwareMicrosoftWindows NTCurrentVersionWindows,SystemCurrentControlSetControlContentIndex,SystemCurrentControlSetControlTerminal Server,SystemCurrentControlSetControlTerminal ServerUserConfig,SystemCurrentControlSetControlTerminal ServerDefaultUserConfiguration,SoftwareMicrosoftWindows NTCurrentVersionPerflib,SystemCurrentControlSetServicesSysmonLog
      Network access: Restrict anonymous access to Named Pipes and Shares Enabled
      Network access: Shares that can be accessed anonymously Not Defined
      Network access: Sharing and security model for local accounts Classic – local users authenticate as themselves
      Network security: Allow Local System to use computer identity for NTLM Not Defined
      Network security: Allow LocalSystem NULL session fallback Not Defined
      Network Security: Allow PKU2U authentication requests to this computer to use online identities Not Defined
      Network security: Configure encryption types allowed for Kerberos Not Defined
      Network security: Do not store LAN Manager hash value on next password change Enabled
      Network security: Force logoff when logon hours expire Disabled
      Network security: LAN Manager authentication level Not Defined
      Network security: LDAP client signing requirements Negotiate signing
      Network security: Minimum session security for NTLM SSP based (including secure RPC) clients Require 128-bit encryption
      Network security: Minimum session security for NTLM SSP based (including secure RPC) servers Require 128-bit encryption
      Network security: Restrict NTLM: Add remote server exceptions for NTLM authentication Not Defined
      Network security: Restrict NTLM: Add server exceptions in this domain Not Defined
      Network security: Restrict NTLM: Audit Incoming NTLM Traffic Not Defined
      Network security: Restrict NTLM: Audit NTLM authentication in this domain Not Defined
      Network security: Restrict NTLM: Incoming NTLM traffic Not Defined
      Network security: Restrict NTLM: NTLM authentication in this domain Not Defined
      Network security: Restrict NTLM: Outgoing NTLM traffic to remote servers Not Defined
      Recovery console: Allow automatic administrative logon Disabled
      Recovery console: Allow floppy copy and access to all drives and all folders Disabled
      Shutdown: Allow system to be shut down without having to log on Enabled
      Shutdown: Clear virtual memory pagefile Disabled
      System cryptography: Force strong key protection for user keys stored on the computer Not Defined
      System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing Disabled
      System objects: Require case insensitivity for non-Windows subsystems Enabled
      System objects: Strengthen default permissions of internal system objects (e.g. Symbolic Links) Enabled
      System settings: Optional subsystems Posix
      System settings: Use Certificate Rules on Windows Executables for Software Restriction Policies Disabled
      User Account Control: Admin Approval Mode for the Built-in Administrator account Disabled
      User Account Control: Allow UIAccess applications to prompt for elevation without using the secure desktop Disabled
      User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode Prompt for consent for non-Windows binaries
      User Account Control: Behavior of the elevation prompt for standard users Prompt for credentials
      User Account Control: Detect application installations and prompt for elevation Enabled
      User Account Control: Only elevate executables that are signed and validated Disabled
      User Account Control: Only elevate UIAccess applications that are installed in secure locations Enabled
      User Account Control: Run all administrators in Admin Approval Mode Enabled
      User Account Control: Switch to the secure desktop when prompting for elevation Enabled
      User Account Control: Virtualize file and registry write failures to per-user locations Enabled
      Device Tree
      ACPI x64-based PC
      Microsoft ACPI-Compliant System
      ACPI Fixed Feature Button
      ACPI Power Button
      AMD Athlon 64 X2 Dual Core Processor 3800+
      System board
      PCI bus
      AMD Address Map Configuration
      AMD DRAM and HyperTransport Trace Mode Configuration
      AMD HyperTransport Configuration
      AMD Miscellaneous Configuration
      Motherboard resources
      NVIDIA nForce 10/100/1000 Mbps Ethernet
      NVIDIA nForce PCI System Management
      PCI standard PCI-to-PCI bridge
      PCI standard RAM Controller
      PCI standard ISA bridge
      Communications Port (COM1)
      Direct memory access controller
      High precision event timer
      Microsoft PS/2 Mouse
      Numeric data processor
      Programmable interrupt controller
      Standard PS/2 Keyboard
      System CMOS/real time clock
      System speaker
      System timer
      Standard floppy disk controller
      Floppy disk drive
      Printer Port (LPT1)
      Printer Port Logical Interface
      USB Root Hub
      Unknown Device
      Standard Enhanced PCI to USB Host Controller
      USB Root Hub
      1394 OHCI Compliant Host Controller (Legacy)
      SB 5.1 VX
      High Definition Audio Controller
      High Definition Audio Device
      Standard Dual Channel PCI IDE Controller
      ATA Channel 1
      ATA Channel 0
      NVIDIA nForce Serial ATA Controller
      ATI Radeon HD 5450
      Acer P241W
      CPU
      Cores 2
      Threads 2
      Name AMD Athlon 64 X2 3800+
      Code Name Windsor
      Package Socket AM2 (940)
      Technology 90nm
      Specification AMD Athlon 64 X2 Dual Core Processor 3800+
      Family F
      Extended Family F
      Model B
      Extended Model 4B
      Stepping 2
      Revision BH-F2
      Instructions MMX (+), 3DNow! (+), SSE, SSE2, SSE3, AMD 64, NX, VMX
      Virtualization Supported, Disabled
      Hyperthreading Not supported
      Fan Speed 3515 RPM
      Bus Speed 200.9 MHz
      Rated Bus Speed 1004.4 MHz
      Stock Core Speed 2000 MHz
      Stock Bus Speed 200 MHz
      Average Temperature 32 °C
      Caches
      L1 Data Cache Size 2 x 64 KBytes
      L1 Instructions Cache Size 2 x 64 KBytes
      L2 Unified Cache Size 2 x 512 KBytes
      Cores
      Core 0
      Core Speed 2008.8 MHz
      Multiplier x 10.0
      Bus Speed 200.9 MHz
      Temperature 28 °C
      Threads APIC ID: 0
      Core 1
      Multiplier x 10.0
      Bus Speed 200.9 MHz
      Temperature 35 °C
      Threads APIC ID: 1
      RAM
      Memory slots
      Total memory slots 4
      Used memory slots 4
      Free memory slots 0
      Memory
      Type DDR2
      Size 6144 MBytes
      Channels # Single
      DRAM Frequency 334.8 MHz
      CAS# Latency (CL) 5 clocks
      RAS# to CAS# Delay (tRCD) 5 clocks
      RAS# Precharge (tRP) 5 clocks
      Cycle Time (tRAS) 15 clocks
      Bank Cycle Time (tRC) 21 clocks
      Command Rate (CR) 2T
      Physical Memory
      Memory Usage 27 %
      Total Physical 6.00 GB
      Available Physical 4.34 GB
      Total Virtual 12 GB
      Available Virtual 10 GB
      SPD
      Number Of SPD Modules 4
      Slot #1
      Type DDR2
      Size 1024 MBytes
      Manufacturer Nanya Technology
      Max Bandwidth PC2-5300 (333 MHz)
      Part Number M2Y1G64TU8HB0B-3C
      Serial Number D9642911
      Week/year 08 / 07
      Timing table
      JEDEC #1
      Frequency 200.0 MHz
      CAS# Latency 3.0
      RAS# To CAS# 3
      RAS# Precharge 3
      tRAS 9
      tRC 12
      Voltage 1.800 V
      JEDEC #2
      Frequency 266.7 MHz
      CAS# Latency 4.0
      RAS# To CAS# 4
      RAS# Precharge 4
      tRAS 12
      tRC 16
      Voltage 1.800 V
      JEDEC #3
      Frequency 333.3 MHz
      CAS# Latency 5.0
      RAS# To CAS# 5
      RAS# Precharge 5
      tRAS 15
      tRC 20
      Voltage 1.800 V
      Slot #2
      Type DDR2
      Size 2048 MBytes
      Manufacturer Kingston
      Part Number 2G-UDIMM
      Serial Number D0293D3A
      Week/year 26 / 08
      Timing table
      JEDEC #1
      Frequency 200.0 MHz
      CAS# Latency 3.0
      RAS# To CAS# 3
      RAS# Precharge 3
      tRAS 9
      tRC 12
      Voltage 1.800 V
      JEDEC #2
      Frequency 266.7 MHz
      CAS# Latency 4.0
      RAS# To CAS# 4
      RAS# Precharge 4
      tRAS 12
      tRC 16
      Voltage 1.800 V
      JEDEC #3
      Frequency 333.3 MHz
      CAS# Latency 5.0
      RAS# To CAS# 5
      RAS# Precharge 5
      tRAS 15
      tRC 20
      Voltage 1.800 V
      Slot #3
      Type DDR2
      Size 1024 MBytes
      Manufacturer Hyundai Electronics
      Part Number HYMP512U64CP8-Y5
      Serial Number 00002017
      Week/year 17 / 07
      Timing table
      JEDEC #1
      Frequency 200.0 MHz
      CAS# Latency 3.0
      RAS# To CAS# 3
      RAS# Precharge 3
      tRAS 9
      tRC 12
      Voltage 1.800 V
      JEDEC #2
      Frequency 266.7 MHz
      CAS# Latency 4.0
      RAS# To CAS# 4
      RAS# Precharge 4
      tRAS 12
      tRC 16
      Voltage 1.800 V
      JEDEC #3
      Frequency 333.3 MHz
      CAS# Latency 5.0
      RAS# To CAS# 5
      RAS# Precharge 5
      tRAS 15
      tRC 20
      Voltage 1.800 V
      Slot #4
      Type DDR2
      Size 2048 MBytes
      Serial Number B528AFE3
      Week/year 26 / 08
      Timing table
      JEDEC #1
      Frequency 200.0 MHz
      CAS# Latency 3.0
      RAS# To CAS# 3
      RAS# Precharge 3
      tRAS 9
      tRC 12
      Voltage 1.800 V
      JEDEC #2
      Frequency 266.7 MHz
      CAS# Latency 4.0
      RAS# To CAS# 4
      RAS# Precharge 4
      tRAS 12
      tRC 16
      Voltage 1.800 V
      JEDEC #3
      Frequency 333.3 MHz
      CAS# Latency 5.0
      RAS# To CAS# 5
      RAS# Precharge 5
      tRAS 15
      tRC 20
      Voltage 1.800 V
      Motherboard
      Manufacturer ASUSTeK Computer INC.
      Model M2N-MX (CPU 1)
      Chipset Vendor NVIDIA
      Chipset Model MCP61
      Chipset Revision A2
      Southbridge Vendor NVIDIA
      Southbridge Model MCP61
      Southbridge Revision A2
      System Temperature 35 °C
      BIOS
      Brand American Megatrends Inc.
      Version 0907
      Date 27/09/2007
      Voltage
      CPU CORE 1.312 V
      +3.3V 3.408 V
      +5V 4.892 V
      +12V 12.608 V
      CMOS BATTERY 3.184 V
      PCI Data
      Slot PCI-E
      Slot Type PCI-E
      Slot Usage In Use
      Data lanes x16
      Slot Designation PCIEX16
      Characteristics 3.3V, Shared
      Slot Number 0
      Slot PCI-E
      Slot Type PCI-E
      Slot Usage Available
      Data lanes x1
      Characteristics 3.3V, Shared, PME
      Slot Number 1
      Slot PCI
      Slot Type PCI
      Slot Usage In Use
      Bus Width 32 bit
      Slot Designation PCI1
      Slot Number 2
      Slot PCI
      Slot Type PCI
      Slot Usage In Use
      Bus Width 32 bit
      Slot Designation PCI2
      Slot Number 3
      Graphics
      Monitor
      Name Acer P241W on ATI Radeon HD 5450
      Current Resolution 1920×1200 pixels
      Work Resolution 1795×1200 pixels
      State Enabled, Primary, Output devices support
      Monitor Width 1920
      Monitor Height 1200
      Monitor BPP 32 bits per pixel
      Monitor Frequency 60 Hz
      Device \.DISPLAY1Monitor0
      ATI Radeon HD 5450
      Manufacturer ATI
      Model Radeon HD 5450
      GPU Cedar
      Device ID 1002-68F9
      Subvendor Gigabyte (1458)
      Current Performance Level Level 0
      Voltage 0.900 V
      Die Size 59 mm²
      Release Date Feb 4, 2010
      DirectX Support 11.0
      DirectX Shader Model 5.0
      OpenGL Support 4.2
      GPU Clock 650.0 MHz
      Temperature 49 °C
      Core Voltage 0.900 V
      Driver version 8.821.0.0
      BIOS Version xxx-xxx-xxx
      ROPs 4
      Shaders 80 unified
      Memory Type DDR2
      Bus Width 32×2 (64 bit)
      Pixel Fillrate 2.6 GPixels/s
      Noise Level Quiet
      Max Power Draw 20 Watts
      Count of performance levels : 3
      Level 1
      GPU Clock 157 MHz
      Memory Clock 200 MHz
      Level 2
      GPU Clock 650 MHz
      Memory Clock 500 MHz
      Level 3
      GPU Clock 650 MHz
      Storage
      Hard drives
      Manufacturer Maxtor
      Heads 16
      Cylinders 19,457
      Tracks 4,961,535
      Sectors 312,576,705
      SATA type SATA-I 1.5Gb/s
      Device type Fixed
      ATA Standard ATA/ATAPI-7
      Serial Number 5RA539J5
      Firmware Version Number 4.AAB
      LBA Size 48-bit LBA
      Power On Count 5316 times
      Power On Time 8.5 days
      Features S.M.A.R.T., NCQ
      Max. Transfer Mode SATA I 1.5Gb/s
      Used Transfer Mode SATA I 1.5Gb/s
      Interface SATA
      Capacity 149 GB
      Real size 160,041,885,696 bytes
      RAID Type None
      S.M.A.R.T
      Status Good
      Temperature 41 °C
      Temperature Range OK (less than 50 °C)
      S.M.A.R.T attributes
      01
      Attribute*name Read Error Rate
      Real value 0
      Current 100
      Worst 253
      Threshold 6
      Raw Value 0000000000
      Status Good
      03
      Attribute*name Spin-Up Time
      Real value 0 ms
      Current 98
      Worst 97
      Threshold 0
      Status Good
      04
      Attribute*name Start/Stop Count
      Real value 5,329
      Current 95
      Worst 95
      Threshold 20
      Raw Value 00000014D1
      Status Good
      05
      Attribute*name Reallocated Sectors Count
      Real value 0
      Current 100
      Worst 100
      Threshold 36
      Status Good
      07
      Attribute*name Seek Error Rate
      Real value 0
      Current 87
      Worst 60
      Threshold 30
      Raw Value 001F7479A4
      Status Good
      09
      Attribute*name Power-On Hours (POH)
      Real value 8d 13h
      Current 86
      Worst 86
      Threshold 0
      Raw Value 0000003027
      Status Good
      0A
      Attribute*name Spin Retry Count
      Real value 0
      Current 100
      Worst 100
      Threshold 97
      Status Good
      0C
      Attribute*name Device Power Cycle Count
      Real value 5,316
      Current 95
      Worst 95
      Threshold 20
      Raw Value 00000014C4
      Status Good
      BB
      Attribute*name Reported Uncorrectable Errors
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      BD
      Attribute*name High Fly Writes (WDC)
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      BE
      Attribute*name Temperature Difference from 100
      Real value 41 °C
      Current 59
      Worst 47
      Threshold 45
      Raw Value 0029290029
      Status Good
      C2
      Real value 41 °C
      Current 41
      Worst 53
      Threshold 0
      Raw Value 0000000029
      Status Good
      C3
      Attribute*name Hardware ECC Recovered
      Real value 0
      Current 86
      Worst 68
      Threshold 0
      Raw Value 0009885C26
      Status Good
      C5
      Attribute*name Current Pending Sector Count
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      C6
      Attribute*name Uncorrectable Sector Count
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      C7
      Attribute*name UltraDMA CRC Error Count
      Real value 0
      Current 200
      Worst 200
      Threshold 0
      Status Good
      C8
      Attribute*name Write Error Rate / Multi-Zone Error Rate
      Real value 0
      Current 100
      Worst 253
      Threshold 0
      Status Good
      CA
      Attribute*name Data Address Mark errors
      Real value 0
      Current 100
      Worst 253
      Threshold 0
      Status Good
      Partition 0
      Partition ID Disk #0, Partition #0
      Disk Letter C:
      File System NTFS
      Volume Serial Number 6865BBA9
      Size 149 GB
      Used Space 32.3 GB (21%)
      Free Space 116 GB (79%)
      Manufacturer Seagate
      Heads 16
      Cylinders 626,933
      Tracks 102,817,012
      Sectors 1,953,523,228
      SATA type SATA-III 6.0Gb/s
      Device type Fixed
      ATA Standard ATA8-ACS
      Serial Number Z1D1KJDT
      Firmware Version Number CC4B
      LBA Size 48-bit LBA
      Power On Count 244 times
      Power On Time 652.8 days
      Speed 7200 RPM
      Features S.M.A.R.T., APM, NCQ
      Max. Transfer Mode SATA III 6.0Gb/s
      Used Transfer Mode SATA II 3.0Gb/s
      Interface SATA
      Capacity 931 GB
      Real size 1,000,204,886,016 bytes
      RAID Type None
      S.M.A.R.T
      Status Good
      Temperature 36 °C
      01
      Real value 0
      Current 106
      Worst 99
      Threshold 6
      Raw Value 0000A9EFD8
      Status Good
      03
      Real value 0 ms
      Current 98
      Worst 97
      Threshold 0
      Status Good
      04
      Real value 246
      Current 100
      Worst 100
      Threshold 20
      Raw Value 00000000F6
      Status Good
      05
      Real value 0
      Current 100
      Worst 100
      Threshold 36
      Status Good
      07
      Real value 0
      Current 82
      Worst 60
      Threshold 30
      Raw Value 000BB8C5BC
      Status Good
      09
      Real value 652d 20h
      Current 83
      Worst 83
      Threshold 0
      Raw Value 0000003D34
      Status Good
      0A
      Real value 0
      Current 100
      Worst 100
      Threshold 97
      Status Good
      0C
      Real value 244
      Current 100
      Worst 100
      Threshold 20
      Raw Value 00000000F4
      Status Good
      B7
      Attribute*name SATA Downshift Error Count
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      B8
      Attribute*name End-to-End error / IOEDC
      Real value 0
      Current 100
      Worst 100
      Threshold 99
      Status Good
      BB
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      BC
      Attribute*name Command Timeout
      Real value 6
      Current 100
      Worst 99
      Threshold 0
      Raw Value 0000000006
      Status Good
      BD
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      BE
      Attribute*name Airflow Temperature
      Real value 36 °C
      Current 64
      Worst 47
      Threshold 45
      Raw Value 0024230024
      Status Good
      BF
      Attribute*name G-sense error rate
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      C0
      Attribute*name Power-off Retract Count
      Real value 78
      Current 100
      Worst 100
      Threshold 0
      Raw Value 000000004E
      Status Good
      C1
      Attribute*name Load/Unload Cycle Count
      Real value 18,017
      Current 91
      Worst 91
      Threshold 0
      Raw Value 0000004661
      Status Good
      C2
      Real value 36 °C
      Current 36
      Worst 53
      Threshold 0
      Raw Value 0000000024
      Status Good
      C5
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      C6
      Real value 0
      Current 100
      Worst 100
      Threshold 0
      Status Good
      C7
      Real value 0
      Current 200
      Worst 200
      Threshold 0
      Status Good
      F0
      Attribute*name Head Flying Hours
      Real value 634d 13h
      Current 100
      Worst 253
      Threshold 0
      Raw Value 0000003B7D
      Status Good
      F1
      Attribute*name Total LBAs Written
      Real value 1,246,848,481,272
      Current 100
      Worst 253
      Threshold 0
      Raw Value 004DF5F7F8
      Status Good
      F2
      Attribute*name Total LBAs Read
      Real value 2,565,196,396,183
      Current 100
      Worst 253
      Threshold 0
      Raw Value 00419EB697
      Status Good
      Partition 0
      Partition ID Disk #1, Partition #0
      Disk Letter D:
      File System NTFS
      Volume Serial Number 10FC486E
      Size 931 GB
      Used Space 646 GB (69%)
      Free Space 284 GB (31%)
      Optical Drives
      Media Type DVD Writer
      Name Philips DVD+RW DVD8601 ATA Device
      Availability Running/Full Power
      Capabilities Random Access, Supports Writing, Supports Removable Media
      Read capabilities CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD+R, DVD+RW, DVD+R DL
      Write capabilities CD-R, CD-RW, DVD+R, DVD+RW, DVD+R DL
      Config Manager Error Code Device is working properly
      Config Manager User Config FALSE
      Drive E:
      Media Loaded FALSE
      SCSI Bus 0
      SCSI Logical Unit 0
      SCSI Port 0
      SCSI Target Id 0
      Status OK
      Name PIONEER DVD-RW DVR-110D ATA Device
      Read capabilities CD-R, CD-RW, CD-ROM, DVD-RAM, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
      Write capabilities CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
      Drive F:
      Media Loaded FALSE
      SCSI Bus 0
      SCSI Logical Unit 0
      SCSI Port 0
      SCSI Target Id 1
      Status OK
      Audio
      Sound Cards
      SB 5.1 VX
      Playback Devices
      Digital Audio (S/PDIF) (High Definition Audio Device)
      Digital Audio (HDMI) (2- High Definition Audio Device)
      Speakers (SB 5.1 VX) (default)
      Recording Devices
      Microphone (SB 5.1 VX)
      Line-In (SB 5.1 VX)
      Microphone (High Definition Audio Device) (default)
      Peripherals
      Device Kind Keyboard
      Device Name Standard PS/2 Keyboard
      Vendor (Standard keyboards)
      Location plugged into keyboard port
      Driver
      Date 6-21-2006
      Version 6.1.7601.17514
      File C:Windowssystem32DRIVERSi8042prt.sys
      File C:Windowssystem32DRIVERSkbdclass.sys
      Device Kind Mouse
      Device Name Microsoft PS/2 Mouse
      Vendor Microsoft
      Location plugged into PS/2 mouse port
      Driver
      Date 6-21-2006
      Version 6.1.7600.16385
      File C:Windowssystem32DRIVERSmouclass.sys
      Device Kind Printer
      Device Name HP Deskjet 3520 series
      Vendor HP
      Driver
      Date 9-6-2012
      Version 9.84.0.1189
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpdj_3520.gpd
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}HPMACRONAMES.gpd
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpvpl09.ini
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpvpldrv09.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpvplui09.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpfime51.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpvplres09.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}copyright.txt
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpinkstsB011LM.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpinkstsB011.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}unidrv.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}unidrvui.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}unires.dll
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}unidrv.hlp
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}locale.gpd
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}stdnames.gpd
      File C:Windowssystem32spoolDRIVERSx64{F510EE19-F859-4847-9AAA-9862957F1B80}hpdj_3520_n.inx
      File C:Windowssystem32hpinkcoiB011.dll
      File C:Windowssystem32hpinkinsB011.exe
      File C:Windowssystem32hpinkstsB011LM.dll
      HP Deskjet 3520 series (NET)
      Device Kind Camera/scanner
      Device Name HP Deskjet 3520 series (NET)
      Vendor Hewlett-Packard
      Driver
      Date 7-19-2011
      Version 26.0.0.0
      File C:Windowssystem32HPWia2_DJ3520.dll
      File C:Windowssystem32HPScanTRDrv_DJ3520.dll
      File C:Windowssystem32driversserscan.sys
      Printers
      Fax
      Printer Port SHRFAX:
      Print Processor winprint
      Availability Always
      Priority 1
      Duplex None
      Print Quality 200 * 200 dpi Monochrome
      Status Unknown
      Driver
      Driver Name Microsoft Shared Fax Driver (v4.00)
      Driver Path C:Windowssystem32spoolDRIVERSx643FXSDRV.DLL
      HP Deskjet 3520 series (Network) (Default Printer)
      Printer Port CN36M1C2RY05SY
      Availability Always
      Priority 1
      Duplex None
      Print Quality 600 * 600 dpi Color
      Status Unknown
      Driver
      Driver Name HP Deskjet 3520 series (v6.00)
      Driver Path C:Windowssystem32spoolDRIVERSx643UNIDRV.DLL
      Microsoft XPS Document Writer
      Printer Port XPSPort:
      Availability Always
      Priority 1
      Duplex None
      Status Unknown
      Driver
      Driver Name Microsoft XPS Document Writer (v6.00)
      Driver Path C:Windowssystem32spoolDRIVERSx643mxdwdrv.dll
      Network
      You are connected to the internet
      Connected through NVIDIA nForce 10/100/1000 Mbps Ethernet
      IP Address 192.168.0.21
      Subnet mask 255.255.255.0
      Gateway server 192.168.0.1
      Preferred DNS server 198.142.0.51
      Alternate DNS server 211.29.132.12
      Alternate DNS server 198.142.235.14
      DHCP Enabled
      DHCP server 192.168.0.1
      External IP Address 211.28.155.203
      Adapter Type Ethernet
      NetBIOS over TCP/IP Enabled via DHCP
      NETBIOS Node Type Hybrid node
      Link Speed 91.9 KBps
      Computer Name
      NetBIOS Name R3B3LW0LF-PC
      DNS Name r3b3lw0lf-PC
      Membership Part of workgroup
      Workgroup WORKGROUP
      Remote Desktop
      Disabled
      Console
      State Active
      Domain r3b3lw0lf-PC
      WinInet Info
      LAN Connection
      Local system uses a local area network to connect to the Internet
      Local system has RAS to connect to the Internet
      Wi-Fi Info
      Wi-Fi not enabled
      WinHTTPInfo
      WinHTTPSessionProxyType No proxy
      Session Proxy
      Session Proxy Bypass
      Connect Retries 5
      Connect Timeout (ms) 60,000
      HTTP Version HTTP 1.1
      Max Connects Per 1.0 Servers INFINITE
      Max Connects Per Servers INFINITE
      Max HTTP automatic redirects 10
      Max HTTP status continue 10
      Send Timeout (ms) 30,000
      IEProxy Auto Detect No
      IEProxy Auto Config
      IEProxy
      IEProxy Bypass
      Default Proxy Config Access Type No proxy
      Default Config Proxy
      Default Config Proxy Bypass
      Sharing and Discovery
      Network Discovery Enabled
      File and Printer Sharing Enabled
      File and printer sharing service Enabled
      Simple File Sharing Enabled
      Administrative Shares Enabled
      Adapters List
      Enabled
      Connection Name Local Area Connection
      NetBIOS over TCPIP Yes
      DHCP enabled Yes
      MAC Address 00-1A-92-75-BF-2D
      DHCP 192.168.0.1
      DNS Server 198.142.0.51
      211.29.132.12
      198.142.235.14
      TeamViewer VPN Adapter
      Connection Name Local Area Connection 2
      DHCP enabled Yes
      MAC Address 00-FF-24-3B-21-6B
      Network Shares
      Users C:Users
      Current TCP Connections
      C:Program Files (x86)Aurorafirefox.exe (4048)
      Local 127.0.0.1:49245 ESTABLISHED Remote 127.0.0.1:49244 (Querying… )
      Local 127.0.0.1:49244 ESTABLISHED Remote 127.0.0.1:49245 (Querying… )
      C:Program Files (x86)SkypePhoneSkype.exe (2428)
      Local 0.0.0.0:443 (HTTPS) LISTEN
      Local 192.168.0.21:49215 ESTABLISHED Remote 134.170.0.215:443 (Querying… ) (HTTPS)
      Local 0.0.0.0:29488 LISTEN
      Local 192.168.0.21:49181 ESTABLISHED Remote 65.54.184.36:443 (Querying… ) (HTTPS)
      Local 192.168.0.21:49169 ESTABLISHED Remote 91.190.218.59:12350 (Querying… )
      Local 192.168.0.21:49165 ESTABLISHED Remote 111.221.77.142:40002 (Querying… )
      Local 0.0.0.0:80 (HTTP) LISTEN
      C:Program Files (x86)uTorrentuTorrent.exe (2464)
      Local 192.168.0.21:49883 SYN-SENT Remote 50.12.69.242:48426 (Querying… )
      Local 192.168.0.21:49884 LAST-ACK Remote 124.176.168.196:24874 (Querying… )
      Local 192.168.0.21:49885 ESTABLISHED Remote 141.237.151.13:45696 (Querying… )
      Local 192.168.0.21:49887 SYN-SENT Remote 14.202.33.111:64620 (Querying… )
      Local 192.168.0.21:49890 ESTABLISHED Remote 123.243.118.199:28212 (Querying… )
      Local 192.168.0.21:49892 ESTABLISHED Remote 27.33.253.190:41571 (Querying… )
      Local 192.168.0.21:49893 SYN-SENT Remote 201.86.0.147:60935 (Querying… )
      Local 192.168.0.21:49894 SYN-SENT Remote 98.196.80.76:32051 (Querying… )
      Local 192.168.0.21:49895 SYN-SENT Remote 93.189.40.230:54000 (Querying… )
      Local 192.168.0.21:49896 SYN-SENT Remote 75.19.117.131:11469 (Querying… )
      Local 192.168.0.21:49897 SYN-SENT Remote 50.126.55.54:12170 (Querying… )
      Local 192.168.0.21:49898 SYN-SENT Remote 23.30.24.33:42646 (Querying… )
      Local 192.168.0.21:49805 LAST-ACK Remote 203.217.79.13:43611 (Querying… )
      Local 192.168.0.21:49721 LAST-ACK Remote 197.237.196.163:27177 (Querying… )
      Local 192.168.0.21:54000 ESTABLISHED Remote 41.135.144.51:53733 (Querying… )
      Local 192.168.0.21:49441 ESTABLISHED Remote 5.68.179.131:26727 (Querying… )
      Local 192.168.0.21:49428 ESTABLISHED Remote 60.240.144.95:50002 (Querying… )
      Local 192.168.0.21:49405 ESTABLISHED Remote 106.69.159.13:24079 (Querying… )
      Local 192.168.0.21:49359 ESTABLISHED Remote 184.4.108.121:13907 (Querying… )
      Local 192.168.0.21:49345 ESTABLISHED Remote 184.4.108.121:13907 (Querying… )
      Local 192.168.0.21:49412 ESTABLISHED Remote 87.58.123.141:42074 (Querying… )
      Local 192.168.0.21:49852 SYN-SENT Remote 74.44.83.102:54276 (Querying… )
      Local 192.168.0.21:49859 LAST-ACK Remote 189.156.226.56:6882 (Querying… )
      Local 192.168.0.21:49875 SYN-SENT Remote 181.188.81.65:6346 (Querying… )
      Local 0.0.0.0:54000 LISTEN
      Local 192.168.0.21:49876 ESTABLISHED Remote 92.21.228.172:46248 (Querying… )
      Local 192.168.0.21:49878 CLOSE-WAIT Remote 108.175.224.139:30763 (Querying… )
      C:Program FilesHPHP Deskjet 3520 seriesBinHPNetworkCommunicator.exe (3200)
      Local 192.168.0.21:49222 ESTABLISHED Remote 192.168.0.11:8080 (Querying… )
      C:Program FilesHPHP Deskjet 3520 seriesBinHPNetworkCommunicatorCom.exe (3040)
      Local 192.168.0.21:49158 ESTABLISHED Remote 192.168.0.11:8080 (Querying… )
      lsass.exe (484)
      Local 0.0.0.0:49154 LISTEN
      services.exe (468)
      Local 0.0.0.0:49156 LISTEN
      svchost.exe (720)
      Local 0.0.0.0:135 (DCE) LISTEN
      svchost.exe (848)
      Local 0.0.0.0:49153 LISTEN
      svchost.exe (936)
      Local 0.0.0.0:49155 LISTEN
      System Process
      Local 192.168.0.21:54000 TIME-WAIT Remote 58.167.89.254:51439 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 58.87.137.6:63339 (Querying… )
      Local 192.168.0.21:49596 TIME-WAIT Remote 91.190.218.17:80 (Querying… ) (HTTP)
      Local 192.168.0.21:54000 TIME-WAIT Remote 24.29.229.185:57826 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 93.137.194.28:59771 (Querying… )
      Local 192.168.0.21:49728 TIME-WAIT Remote 63.245.215.56:80 (Querying… ) (HTTP)
      Local 192.168.0.21:49729 TIME-WAIT Remote 63.245.215.46:80 (Querying… ) (HTTP)
      Local 192.168.0.21:54000 TIME-WAIT Remote 5.9.58.173:54855 (Querying… )
      Local 192.168.0.21:49811 TIME-WAIT Remote 63.245.215.46:80 (Querying… ) (HTTP)
      Local 192.168.0.21:54000 TIME-WAIT Remote 172.56.15.70:20727 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 159.0.100.90:54171 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 159.0.100.90:53904 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 159.0.100.90:53652 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 109.247.193.236:39275 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 109.247.140.42:64829 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 108.53.4.214:49639 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 108.53.4.214:49557 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 93.137.194.28:59988 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 93.137.194.28:59497 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 93.137.194.28:59257 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 76.94.222.188:55675 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 74.195.40.68:53671 (Querying… )
      Local 192.168.0.21:54000 TIME-WAIT Remote 62.14.186.180:59855 (Querying… )
      Local 192.168.0.21:49832 TIME-WAIT Remote 63.245.215.46:80 (Querying… ) (HTTP)
      System Process
      Local 192.168.0.21:139 (NetBIOS session service) LISTEN
      Local 0.0.0.0:445 (Windows shares) LISTEN
      Local 0.0.0.0:2869 LISTEN
      Local 0.0.0.0:5357 LISTEN
      Local 0.0.0.0:10243 LISTEN
      TeamViewer_Service.exe (1516)
      Local 127.0.0.1:5939 LISTEN
      wininit.exe (416)
      Local 0.0.0.0:49152 LISTEN
      wmpnetwk.exe (3096)
      Local 0.0.0.0:554 LISTEN
      Generated with Speccy v1.26.698
    • #1453133
      You have a USB plug-in card that is USB 1.1 (“old school”). Most external drives now are USB 3.0, which is much faster than USB 2. I would replace the old card with one that has USB 3.0, particularly if I intended to use a USB 3.0 external drive. I’m not sure what your existing external drives are, maybe they are only USB 2.0. When I plug a USB 3.0 external into a USB 2 port (I have a mix of USB 2 and 3 ports), I get the “you could do better” message.
      Since you are having a rather persistent issue (tried lots of things, long thread already), I would recommend that you check your RAM with Memtest86 or Memtest86+, which are free downloads that you can find using Google. They are much more thorough than the Windows Memory Diagnostic Test that is built into Windows 7 (it reported that my RAM was okay when it wasn’t). You burn a downloaded .iso file onto a DVD and boot from that. Bad memory can result in all kinds of odd symptoms and just about any error message under the sun.
    • #1453162
      My apologies… I should have made it clear to attach the Speccy report, not just paste it in. Anyway, it was useful. You may wish to edit your previous post (line 25 of the Speccy report) to remove the Win 7 serial no. It should be OK, it’s a just in case.
      In my experience the exclamation mark against PS/2 devices in Device Manager (with ‘hidden’ devices showing) is quite normal. My PC shows the same when I don’t have a PS/2 mouse attached. The only reason I asked you to use PS/2 devices if possible is to clean the USB ENUM keys in the registry as much as possible without having to use the registry editor directly.
      1. Using Device Manager, un-install the Unknown Device then close Device Manager.
      2. Using USBDeview (running as administrator), un-install the top 4 HID devices (which I’m surprised DriveCleanup didn’t do). (The Unknown Device should have disappeared but, if not, un-install it.)
      37030-remove
      Click to enlarge
      Close USBDeview.
      3. Optional – Enter eventvwr.msc in Start > Search programs and files then, when it appears in the Search results, right-click and choose Run as administrator. (Why? Because you need to see clearly what’s happening when you reboot and start re-attaching USB devices.)
      3a. Expand Windows Logs and click on System to select it.
      3b. Click on Action in the menubar then select Clear log….
      3c. Click on Clear (or Save and Clear – your choice).
      3d. Close Event Viewer.
      4. Shutdown completely.
      5. Start PC again.
      6. Check Device Manager/USBDeview for any Unknown device that’s re-installed.
      7. If an unknown device is added, check System in Event Viewer for any details of the device, i.e. error messages. (I don’t actually use Event Viewer as I find errors don’t usually provided any useful results. Instead I use Nir Sofer’s MyEventViewer as this allows showing different logs in a single pane.)
      8. Report back.
      • #1453178
        Hi guys, first time poster. I just have a few things to add.
        First, you should be more careful when plugging/unplugging PS/2 devices. They weren’t designed to be hot-pluggable like USB devices, and if you’re unlucky, you could ruin your PS/2 mouse, keyboard, the port itself, or the motherboard as a whole. Only plug or unplug them with the computer’s power completely off (meaning sleep mode may not be good enough.)
        Second, it’s common for a motherboard to have more USB ports available than what are physically available on the machine. To save on costs or provide for future expansion, available USB headers on the motherboard may not be plugged into anything externally, or there may be a soldered header with no socket to plug into, or the microchip controller may simply support more ports and not have had such support programmatically disabled. So don’t worry about the mismatch between 10 ports showing in Windows and 8 ports being physically available.
        Third, malware infections cause all kinds of problems, including driver issues. As an IT professional, I spend around half of every work day cleaning up after that stuff. I’ve run across some particular Potentially Unwanted Programs (PUPs) that do exactly that on purpose, with the intention of trying to get you to pay for their driver update or maintenance program (which you shouldn’t do, of course. They’re the cause of the problem in the first place. Never give in to extortion, it only encourages the bad actors to do it more.)
        While looking through your speccy log, I saw two running processes that I thought were suspicious:
        C:Usersr3b3lw0lfAppDataLocalSkillbrainslight shot5.1.0.15Lightshot.exe
        The first one is running from your user profile, which is a giant red flag to me, though I’m not familiar with it enough to know up front if it’s OK. The second one I think I’ve seen before on other infected computers, but I’m not sure about it, either. If you don’t know what either of those are, try uninstalling them from Control Panel and seriously consider some deeper anti-malware scans. It looked to me like you didn’t have any anti-virus software running other than Windows Defender, so a stealthy rootkit infection may have a higher probability of being an issue here than usual.
        After deciding what to do about those processes, and taking care of that Unknown Device that Rick covered, if you’re still having issues with your USB devices, there’s more that can be done.
    • #1453181
      Hi JonCS, welcome to the forum.
      You’re quite right about PS/2 devices and I should have made it clear to the OP that his PC should be completely shutdown before connecting/disconnecting. Sometimes it’s just too easy to forget these basics when replying to a post.
      The OP is using Lightshot for some of his screenshots. Rocketdock‘s just an application launcher and quite well-known not to be malware (although ‘stable’ is a different matter, IMHO :)).
      I, too, wondered about malware… but only ‘cos OP is using uTorrent (and, like you, I couldn’t see any evidence of any anti-malware programs except for Windows Defender). I know the two don’t go hand-in-hand but it’s always a warning sign. I thought I would assist the OP with initial hardware stuff before looking for other causes (e.g. twolery’s suggestion in post #28 to check RAM. It’s a valid point but may throw OP through too many hoops at the moment.)
      Thanks for the info about the mismatch between 10 ports showing in Windows and 8 ports being physically available. I wasn’t aware of this (given I almost always work on ‘standard’ business class PC’s rather than on third-party USB peripherals) but the bit about “the microchip controller may simply support more ports and not have had such support programmatically disabled” makes complete sense. At first I thought that this might have meant my assertion in post #18 about having a problem in the Windows registry could be wrong but a later post by the OP (post #27) shows that there is indeed a problem with the OP’s registry. Hopefully my advice in post #29 will sort this.
      I’m trying to work with the OP to get a stable ‘standard’ USB configuration before looking at his USB mass storage devices (see post #10 where a BIOS checksum error occurred whilst booting with his 2 identical 2 Tb Seagate Expansion Desk 2 external drives connected).
      The OP has also had a previous poor experience of being asked to un-install the root hubs and controllers from within Device Manager (post #5) and it made things worse… so we’re taking it one step at a time.
      PS – I note that OP’s Speccy report shows a stopped Logitech Bluetooth service, which suggests that OP may have been using a Logitech wireless keyboard or mouse connected to a USB wireless controller at some point, hence my attempt to create a ‘clean’ and current USB device enumeration in the registry.
      • #1453192
        Rick, thanks for the info and links on Lightshot and Rocketdock. I’ll remember them for the next time I see them on someone’s computer.
        I just wanted to clarify that I didn’t mean to come off as overly critical. I was just trying to contribute what I thought might be some missing info. I agree with your approach and I think you’re doing a pretty good job so far. I’m inclined to stay mostly out of the way as I’m pretty busy with other things and I think that too many cooks can spoil the pot. So, keep up the good work.
        In my opinion, that unknown device remains the next main thing that should be addressed. If it has anything to do with USB controllers or hubs, it could very well be the reason the external harddrive isn’t able to run at full speed. And even if it isn’t the cause, it’s still probably something that should be taken care of, anyway.
        One other thing just occurred to me: the cable being used to connect that one particular drive that was mentioned might be damaged or worn, and the loss of speed right when the drivers were messed with might be just a coincidence. Has a different cable been considered, assuming it’s detachable? This seems like a lower probability cause, but I thought I’d throw it in if the other stuff doesn’t pan out.
        Down the road, I was also considering suggesting to maybe uninstall the HP printer stuff temporarily as their drivers are known to be a bit temperamental, especially if a bit of registry corruption has occurred. The Logitech stuff may also be relevant, but seems even less likely. Or maybe you could try a “safe” registry cleaner like the one that comes with CCleaner, which I believe I saw the OP already had installed. Oh, and it might be a good idea to use System Restore judiciously between steps to create new restore points, in case something makes things worse. You might even consider using System Restore to go back to a time before the problem showed up, but that can sometimes cause new problems. I would only consider it as a second-to-last resort before doing a clean re-install of Windows altogether.
        But I’m not suggesting doing any of those yet – one thing at a time! I only mention them now because I don’t know when I’ll get back to reading this forum. Good luck!
        – Jon
        • #1453197
          Hi Jon,
          I didn’t pick up anything ‘overly critical’ at all… you made very valid and helpful points, especially the one about the potential of a damaged USB cable. I’ve experienced this same issue myself so have kept it at the back of my mind for when OP begins adding USB devices back to his (hopefully now ‘clean’ USB setup). Any more advice/insights are welcome ‘cos my experience is primarily with ‘standard’ business-class PC’s and mainstream apps. Suggest away! 🙂
          PS – I considered System Restore but couldn’t think of a way to determine accurately when was a good point to restore to.
          There’s so many potential factors that I’m trying to take diagnosis at snail’s pace… even though this may try OP’s patience (hopefully not :), but OP’s location appears to be Victoria, Australia… i.e. 10 hours offset to my own time zone [Bristol, UK], so I’m usually asleep when OP replies and vice versa).
          Rick
    • #1453244
      Ok, one… I use utorrent, but I don’t use public and I browse safely.
      I run rkill and mbam once a week, with the occasional SAS run through aswell.
      I use lightshot for screenshots… looking for one that takes the pic but then uploads with a image extension LOL.
      Rocketdock is just another taskbar… yeah not always stable… cos it not stay on top as it should LOL
      Okay. I did all that was said… I didn’t notice anything in system regarding usb errors or devices etc.
      BUT, in application I found these….
      Fault bucket , type 0
      Event Name: PnPRequestAdditionalSoftware
      Response: Not available
      Cab Id: 0
      Problem signature:
      P1: x64
      P2: HIDVID_046D&PID_C31C&REV_6400&MI_01&Col02
      P3: 6.1.1.0
      P4: 0409
      P5: input.inf
      P6: *
      P7:
      P8:
      P9:
      P10:
      These files may be available here:
      C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsWERReportQueueNonCritical_x64_fcd3d224ca8bd461c4dca7e648fef6e125073de_0cb8d567
      Analysis symbol:
      Rechecking for solution: 0
      Report Id: 0b895830-dcd5-11e3-95c9-001a9275bf2d
      Report Status: 4
      Event Name: PnPDeviceProblemCode
      Cab Id: 0
      Problem signature:
      P1: x64
      P2: USBUNKNOWN
      P3: {36fc9e60-c465-11cf-8056-444553540000}
      P4: 0000002B
      P5: unknown
      P6: unknown
      P7: unknown
      P8:
      P9:
      P10:
      C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsWERReportQueueNonCritical_x64_8dd2a6bea57836935d86a299b4735d5c6f632592_0cb8d7b8
      Analysis symbol:
      Report Id: 0b895831-dcd5-11e3-95c9-001a9275bf2d
      Report Status: 4
      Cab Id: 0
      Problem signature:
      P1: x64
      P2: USBVID_046D&PID_C31C&REV_6400&MI_01
      P3: 6.1.1.0
      P4: 0409
      P5: input.inf
      P6: *
      P7:
      P8:
      P9:
      P10:
      C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsWERReportQueueNonCritical_x64_1d35b80a5154488b340fd09f4eb99e773d3392_0cb97232
      Analysis symbol:
      Report Id: 2314d741-dcd5-11e3-95c9-001a9275bf2d
      Report Status: 4
      Cab Id: 0
      Problem signature:
      P1: x64
      P2: USBVID_046D&PID_C31C&REV_6400&MI_00
      P3: 6.1.1.0
      P4: 0409
      P5: input.inf
      P6: *
      P7:
      P8:
      P9:
      P10:
      C:Usersr3b3lw0lfAppDataLocalMicrosoftWindowsWERReportQueueNonCritical_x64_64be87d87c29344c4db448d9287c67e975152d_0cb96e4c
      Analysis symbol:
      Report Id: 2314d740-dcd5-11e3-95c9-001a9275bf2d
      Report Status: 4
      I notice them in “application log” (using that “MyEventViewer”)
      37035-QHUZIb74
      Thats what I see when I restart.
      37036-ijgQoKcW
      USBDeview… with again that unknown device… but the highlighted, im thinking is to do with keyboard maybe?
      Why it installs 2 keyboards… I have no idea.
      Am not sure about bluetooth, or how to activate it.. I have a MK120 logitech combo… keyboard and mouse. Atm, the mouse isn’t plugged in, and the keyboard is plugged in. NORMALLY, I have them both in that “fly lead” attached to mobo.
    • #1453265
      A search on the PCI database for Vendor ID 046D shows that it is indeed your Logitech keyboard that is reporting as Unknown Device. Do you have the driver installation disk? If so, try installing the driver again. I’m not at all conversant with Logitech stuff. Also, you may wish to read the Logitech article about the possibility of interference with USB 3 kit.
      Anyway, now you know that the unknown device refers to the keyboard, it’s time to move on to your drives. Please do the following:
      1. Plug one of your Seagate Expansion Desk 2 external drives into a USB port on the rear.
      2. Check MyEventViewer for any problems and USBDeview that it’s recognised at the correct USB speed (is it USB 3.0 or 3.0?).
      3. If all’s OK, plug the second Seagate Expansion Desk 2 external drive into a USB port on the rear (is it identical to the first one, i.e. same USB speed?).
      4. Once again, check MyEventViewer for any problems and USBDeview that it’s recognised at the correct USB speed.
      5. Report back and also let us know what other external drives you have, whether they are powered or un-powered and what USB speed they are.
    • #1453333
      Windows has stopped this device because it has reported problems. (Code 43)
      Thats the error msg to do with the unknown in device manager.
      My PC has no ability for USB3… even if a drive is attached is USB3.
      The MK120 keyboard and mouse combo is 2.0.
      Why it installed 2 keyboards and such, is stumping me LOL. Why it says unknown device? also stumpin me… cos im using it right now LOL
      I just tried plugging something in the front top usb slot (which was working), it is now completely dead, nothing happening. Not reading it at all.
      3 out of 4 of those quests have the same vid and pid, been identified… why thats happens, no clue. I don’t think I gotta disc with the combo. I have looked in my cds and nothing there (but have the paperwork, but nothing bout a disc), and the only thing I can find, is set point and flow scroll in support from logitech,
      The other is different…
      Problem signature:
      P1: x64
      P2: USBUNKNOWN
      its not known, just “host controller” as manufacturer (as USBDeview shows)
      Maybe it IS the front facia that is getting the unknown? Maybe its completely failed now?
      The seagate plugged in, shows 2.1 (it is a usb3 external hdd), but its always done that.
      This could be interesting….
      37041-8P6exrvH
      Just come back to PC and got “installing drivers” for the drive I had plugged into the TOP front port (took a few hours).
      So just get that and told the drive is unplugged, and it is STILL plugged in.
      Mind boggles LOL
      • #1453358
        1. Please confirm that this error occurs when the Logitech keyboard is plugged in and which USB port it’s plugged into. (From post #26, it should be plugged into one of the lower ports at the back of your PC.
        2. What happens when you follow the MS diagnostic advice for Code 43 errors? Does it resolve the error? If not, what happens when you run the Microsoft Hardware Fixit?
        I know… but USBDeview will show USB 3 devices as USB 2.10, indicating backwards compatibility.
        Problem signature:
        P1: x64
        P2: USBUNKNOWN
        3. {36fc9e60-c465-11cf-8056-444553540000} is the GUID for USB host controllers and hubs. There’s a post that claims to fix this error (see post #24) but it involves manually editing the registry. Are you OK about working in the registry? (Don’t do anything at the moment.)
        4. Another possibility is a corrupt input.inf file (C:Windowsinput.inf) but the check for this (sfc /scannow from an elevated command prompt) takes quite some time.
        I suggest doing just 1 and 2 above for the moment then report back.
    • #1453406
      To do that, I removed everything from PC again to do with usb and went back to using ps/2 mouse (but again to type, I put keyboard back in after seeing what happened when boot up- no cmos checksum error and no keyboard installed)
      Ran driveclean (from desktop, I still have a copy in system32 that just can’t be seen, but IS there, cos I need to overwrite it LOL, when I drag a copy in)
      37047-T5K1iy8V
      Ran it again.
      37048-REoPrwNu
      Didn’t remove anything- all gone
      Went to usbdeview and uninstalled everything there
      37049-pUFjsTlg
      All empty.
      I then looked in device manager.
      37050-IvQudF3b
      ps/2 mouse, no keyboard and enhanced and openchd… no hubs etc, as you can see.
      I then shut down windows. waited a few minutes and then turned PC back on.
      37051-8WBhhLNT
      Straight away the problem came up.
      I then put in keyboard and the following showed up
      (the unknown device was already there, as the screenshot before, but while I was looking in device manager, thought I would screenshot what it exactly says, and show what was installed etc when I put keyboard in.)
      37052-upcLlb7c
      Then followed the prompt and restarted.
      Ran/ looked at both of these…… and also installed silverlight (was the only thing that came up when “allow windows to update drivers” in this next screenshot…)
      37046-X9K4C090
      This is what I got…
      37053-xSE3qV8h
      I am comfortable editing, if it shows me where and what to change to.
      I didn’t change/ edit anything, but I did have a look…
      37054-Pqn8Gdqi
      0004 is that unknown… but as you can see, there are no uppers/lowers… have been told a few times about it… but unless I am looking totally the wrong place… I have never see lowers/uppers, as you can see. Because you said “don’t do anything at the moment” I didn’t delete that file and such yet
      I had a look for the file mpfilt I am meant to delete… (wasn’t going to do it) anyways, I not have it…
      37055-Nta4IVj
      Well that explains that mystery, cheers 🙂
      Went and looked in “hidden devices” on device managers…
      faded grey HID Keyboard device
      solid grey HID Keyboard device
      Yellow triangle ! mark for ps/2 keyboard
      wtf? I woulda posted image, but been told I posted two many (and didn’t want to double post)
    • #1453428
      You’ve done well. You cleaned up with DriveCleanup and USBDeview and shown that the error appears with just a PS/2 mouse attached, no keyboard. This means the problem is with one of the onboard USB devices. You’ve already mentioned that the lower USB port on the front panel isn’t working so it’s most likely this that is the problem. However, to doublecheck, please do the following:
      1. Make a note of the layout of your mainboard, particularly the pin headers I’ve marked as A, B and C in red.
      37057-mainboard
      Click to enlarge
      2. Using DriveCleanup and USBDeview, do the same as before to cleanup the USB info in the registry.
      3. Shutdown the PC and remove the power cord.
      4. Open the PC case and trace the cable from the 2 USB ports on the front to where the cable plugs into the mainboard, most likely either B or C.
      5. Temporarily detach the cable’s connector from the pin header.
      6. Check whether anything is plugged into pin header A. If so, make sure the connection is secure.
      7. Replace the lid and power cord and re-start the PC with only the PS/2 mouse connected.
      8. Wait a minute or two for devices to recognised and check in Device Manager whether the unknown device error appears.
      If it doesn’t appear then this confirms where the problem is. You can, at this point, carry out step 3 again and re-attach the cable to the USB pin header to check whether it was just a poor connection. Either way, re-connect the USB keyboard to one of the lower ports on the back of the PC and let us know how you’ve got on.
      In the meantime, I’m doing some testing in the registry about what happens if you were to remove the {36fc9e60-c465-11cf-8056-444553540000} GUID for USB host controllers and hubs completely. (Don’t do anything in the registry yet.) I’ve checked my own registry settings and where it shows Unknown Device in your screenshot, in my registry it shows Generic USB Hub.
    • #1453493
      Alright… first off.
      “B” was where I had my “on the fly” plugged in.
      “A” I can’t see anything there at all, cos it looks to be “all enclosed box”
      Now… I accidentally pulled out the “C” and the little bits on top of “C” so had no power button etc to turn on. LOL Got that all fixed up.
      Alas, when booted up… same thing “Unknown device” same location.
      I plugged in drive next to keyboard (bottom section of mobo usb) and both got picked up by open hcd controller.
      When I have something plugged into…. the slots on mobo USB
      USB USB
      USB USB NET
      That one, it gets the mxn-mx screen, but goes no further. I unplug from there… and boots straight away (tho the FRONT usb is definitely [problematic], cos I got “no keyboard” error)
    • #1453500
      Just so I understand, are you saying that when you plug any USB device into the lower right-hand rear port (marked below) that the PC won’t start and just displays the initial mainboard logo screen? Is that correct?
      37061-back-panel
      Click to enlarge
      Is there anything plugged into the pin headers marked as D? If so, what?
      37060-mainboard
      Click to enlarge
      1. Download and unzip USB Device Tree Viewer V2.3.6 then run the x64-bit version.
      2. Select My Computer in the left-hand pane.
      3. Please upload a screenshot:
      Example
      37062-usb-tree
      Click to enlarge
      4. Please save a full report (CTRL+S) and attach it (not copy/paste) to the post.
    • #1453502
      Upon closer inspection… A… the last pin is “free” the first two pins have a “blue” connection over it… but think of “slave/master” etc, you know how you took it out and moved it etc? Its like that, doesn’t appear to be attached to anything, just covering the first two pins.
      “D” is completely free of anything.
      Yup. Number 7 (on first diagram) something in there, seems pc don’t get far. I remove usb, and goes straight away.
      37063-UsbTreeView_report
      I hope I have attached right 😛
      Alright… I have just plugged a drive into number 7.
      Boom, works perfect…
      37064-GblrjdLf
      I saved the report for “selected item” (of the mass storage” I just attached.)
      37065-USB-Mass-Storage-Device
      • #1453507
        The reason I asked if there was anything attached to the USB pin header marked D is because the mainboard manual specifically advises that attaching a 1394 (Firewire) cable to any of the USB pin headers will damage the mainboard and I spotted a 1394 OHCI Compliant Host Controller (Legacy) entry in the Speccy report you posted (#27).
        I took a better look at the manual and see that “A” is for USB keyboard wakeup, e.g. to bring the PC out of sleep by pressing the spacebar, if configured. The blue connection is called a jumper. If it’s across the first 2 pins then it means USB wakeup isn’t configured.
        ”D” is completely free of anything.
        Good. Please confirm whether “B” or “C” are connected to anything.
        If you click to expand the manual diagram of the rear panel you’ll see that 7 refers to both upper and lower USB ports on the right at the back. I put a red oblong round the lower port to indicate I was referring only to the lower port. Is this the one you are referring to as the one which now has a drive attached (i.e. shown as port 4 in the USB Device Tree Viewer screenshot you posted)?
        We need to determine which exactly is port 8, i.e. showing in the USB Device Tree Viewer screenshot as an Unknown Device. (I don’t know why the keyboard – which previously has been shown as a USB 2.0 device – is now showing as attached to a port in the OpenHCD Host Controller list, i.e. USB 1.1.)
    • #1453559
      There is a firewire card on the pc…. GFX card, firewire card (already IN pc when I got it), soundcard (and then the not attached on the fly usb)
      But nothing is in D.
      I don’t have, nor do I want usb to wake pc up, I don’t even have pc set to sleep, or hibernate, I just have blank screensaver.
      When I said number 7… I meant the red one you marked.
      Usually is the one next to net I use for the keyboard, this time it went to top one (directly above), and then put the external in the one next to net.
      It showed as a 1.1 speed. and USBDeview didn’t show it as what it should be…
      The TOP is how USBDeview was showing it, the one below, is what it was showing before…
      37071-6FKLskag
      So I ejected it, cleared all my history and such again, shut down. put keyboard next to net, and the drive next to it. pc wouldn’t start up. I removed it, and it started it.
      I didn’t attach the drive again… but used the same able, and put it on the tv external and yeah, showed up on enhanced (as it should), and ran at normal speed (as it should), which is what the other external should do when plugged in.
      The ONLY difference I can think of… is one is usb powered, and the other is dc powered. But that doesn’t explain the unidentified that I get with no usb attached at all LOL
      I would love to this this device thats not working as it should LOL. Thanx for the patience, and coming back to the thread.
      “B” and “C” are completely free.
      keyboard always been showing 1.1 its the mouse that shows 2.0 (tho they are a set, mouse gets logitech brand, keyboard doesn’t LOL)
      37072-X390SH9
      from usb device tree manage about the unknown…
      Problem Code : 43 (CM_PROB_FAILED_POST_START)
      Top link in google…
      http://msdn.microsoft.com/en-us/library/windows/hardware/ff538971%28v=vs.85%29.aspx
      A driver has reported a device failure.
      Error Code
      43
      Display Message (Windows XP and later versions of Windows)
      “Windows has stopped this device because it has reported problems. (Code 43)”
      Recommended Resolution (Windows XP and later versions of Windows)
      Uninstall and reinstall the device.
      One of the drivers controlling the device told the operating system the device failed in some manner in response to IRP_MN_QUERY_PNP_DEVICE_STATE.
    • #1453643
      Usually is the one next to net I use for the keyboard, this time it went to top one (directly above), and then put the external in the one next to net…
      My fault, I’m getting confused. To prevent any further confusion, please refer to the rear USB ports as either a, b, c or d (referring to the revised graphic I’ve attached).
      If you’re still getting the Unknown Device with only the USB keyboard attached then it must refer to a USB port itself, not a device attached to a port. As you have the front USB ports temporarily disconnected from the mainboard then it must be one of the 4 rear ports. USBTreeView shows the error on Port 8 of the Standard OpenHCD USB Host Controller (i.e. USB 1.1), not port 8 of the Standard Enhanced PCI to USB Host Controller (i.e. USB 2.0). Does this make sense?
      I think the best thing to do is to make sure that the only USB device attached to your PC is your keyboard (a USB 1.1 device) then, with USBTreeView running, move the keyboard to each of the 4 rear ports in turn until it stops being recognised as a USB Composite Device – HID, HID device. (Make sure AutoRefresh is turned on in USBTreeView’s Options menu.)
      Which rear USB port (a, b, c or d) doesn’t recognise the USB keyboard as a USB Composite Device – HID, HID device?
      37077-back-panel1
      Click to enlarge
    • #1453747
      A
      37080-Qqcif7rW
      B
      37081-M4IAWrDn
      C
      37082-8wxnZo7y
      D
      37083-YzNnOjKJ
      I plugged in a-d and went 1 through 4… no dramas.
      Error still there, so is not that any of these USB ports, and no other USB ports are there to be used
      Since I do not use firewire at all. I will shut down and remove that firewire card (I never use it)
      I will see what that does.
      *thinking outloud*
      Im getting unknown device with no usb at all attached, and then reboot, and unknown device appears.
      On mobo diagram…
      A: “jumper” covering the first to pins.
      B: Completely free.
      C: Completely free.
      D: Completely free.
      I will remove all history of USB again, and then use USBDeview to uninstall all… I even removed openhcd and enhanced from device manager- so everything well and truly gone… fresh start.
      and then reboot with keyboard in a-d.
      See what happens.
      Alright, a-d let me boot. No dramas whatsoever. have removed the firewire aswell…
      and this is interesting when pc started up. I think I have showed this before… not sure..
      “device unplugged”
      37084-72pYSKR
    • #1453761
      Hi r3b3lw0lf, there’s no need to remove the Firewire port… it’s not doing any harm.
      When you ran the Microsoft Hardware Fixit (post #38) the Driver Software Installation error was Unknown Device – Failed. Now it’s Unidentified Device – Device unplugged after clearing out all the USB info and re-starting. I don’t understand what it’s not ‘seeing’ (enumerating).
      I’m at a bit of a loss what to suggest next. About the only thing left to try is a System File Check to ensure the integrity of the built-in driver files. Unfortunately the System File Check can take quite some time.
      1. Click on Start and enter cmd in the Search programs and files dialog.
      2. When cmd.exe appears in the results list, right-click on the name and choose Run as administrator.
      3. When the command prompt appears, type sfc /scannow and press the Return/Enter key. The System File Check will begin.
      4. Report back the result.
    • #1453770
      Prob has been happening for a while now… how long it takes to do a scannow isn’t much at all… am at 50% no. Cheers
      37089-FGTDfYG
      Do we just put this down to “motherboard must be fooked” LOL.
      Thanx for the patience.
      Well since I don’t use firewire, or have any cables for it…. figured it be just easier to just get rid of it LOL
      • #1454032
        r3b3lw0lf
        Ok this was a long thread and I may have forgotten or mixed up a couple of things.
        Please correct me if i am wrong here:
        1. You do NOT have a front panel USB socket.
        2. When you plug something in a particular M/B USB port you computer does not boot.
        If #2 is true I would examine the port with a flashlight for a misaligned contact or stray matter. Blowing out w/ canned air shouldn’t hurt either.
    • #1454047
      1: I have completely removed the front fascia… it is pulled out of mobo (was connected on “C”), the on the fly lead was in “B” but now removed.
      The ONLY USB active on pc, is mobo 7 and 8
      2: When I had a USB powered drive in number “D” on mobo, pc wouldn’t boot up. I took it out, and it started fine.
      When I plug any of the USB powered devices in, they will ONLY get picked up 1.1 (open hcd), they DO NOT go onto 2.0 (enhanced).
      I am thinking maybe power supply not got enough power to run the USB 3 external drives that are powered by USB only.
      Cos I plugged one of MY USB3 drives in “d”, it booted up fine, keyboard in a-d in all ports responds as it should.
      PC operates fine when I use my drives (usb3 dc powered- they go normal speed) only goes 1.1 speed with friends drive attached (which are usb3 usb powered), where before, anything attached was 1.1.
      So thats progress… something rick and I have done has fixed that (thank you)
      Still got “device unplugged” or what the unknown/ unidentified device is, through it all though… Thats the stumper.
      The following errors occurred with your submission
      Your submission could not be processed because the token has expired.
      Please reload the window.
      Getting that when I tried to post twice LOL
    • #1454117
      I’ve thought of another test.
      1. Download and burn Hiren’s BootCD to CD.
      2. Boot PC from Hiren’s BootCD.
      3. Select Mini Windows XP.
      4. Check Device Manager (Start > Programs > Devices > Device Manager) to see if an Unknown Device shows. (You may need to run Start > Programs > Devices > Device Manager > Install All Hardware (HwPnP) and Start > Programs > Devices > Device Manager > Install USB Hardware first.
      5. Confirm state of USB hubs/ports using SIW. (Double-click the HBCD Menu icon on the desktop then select Programs > System Information > SIW (Sys Info for Win). When SIW opens, select Devices in the left-hand pane then check the USB controllers list in the right-hand pane.
      6. Report back.
    • #1454309
      I checked device manger, and unknown was there, tho the info shown was different, its saying no drivers and such installed (not error 43 like on win7)
      37101-BSVtwszY
      After doing all the usb hardware, hwpnp etc first, I checked SIW and well it showed fine?
      that is, didn’t show anything unknown and such there in USB section…
      37102-4k5H8koQ
      But I had a look at both keyboards it has there… one has a error?
      The top two that says “Human Interface Device” didn’t show a error, was underneath that did…
      37103-wqtpxgVe
      Also did usbdeview on winxp
      37105-jZeEnd3y
      Thats from winXP
      Now back on win7….
      I looked on siw…. it showed unknown in usb
      37104-ClMDMYKi
      and for keyboard… “status”.. “has started” and in “problem” is “0x000000 (0)”
      Sorry if this confuses you, im a bit confused myself now…
      • #1454477
        Hi r3b3lw0lf,
        The reason for using Mini Windows XP from Hiren’s Boot Disk is because, using a different OS, if there still appears to be one or more problems with USB then it confirms that the problem is hardware related and not due to the OS, i.e. corruption of Win 7’s drivers or registry. (The previous result of sfc /scannow showed no corruption of any system files.)
        Both Device Manager and USBDeview show problems in Mini Windows XP with an Unknown Device. It’s a shame you don’t have a PS/2 keyboard to take the USB keyboard out of the tests but I think it shows that the problem is your mainboard. You’ve updated the BIOS so it’s very unlikely to be BIOS corruption. Sorry but everything points to a hardware issue involving one of the USB ports on the back of your mainboard. Have you followed wavy’s advice (post #49) about checking these ports with a flashlight? Other than this, I can’t think of anything else that I can do to help.
        PS – SIW shows the USB keyboard as having a problem in Mini Windows XP but I think this is incorrect. I think SIW realises that ‘wake-up from keyboard’ is available but is not enabled on the mainboard (i.e. pin header A labelled PS2_USB_PWR).
        • #1454621
          @jwitalka Prices are from scorptec.com I am from australia, and wasn’t look to build myself… if I did, I could get a gfx card.
          But the deal was it had to be from australia, and well scorptec is half an hr away (one of the stores anyways).
          After conversion… not sure how much of a different there would be anyway… shocked about the diff in cpu tho LOL
          @rick
          Yeah, thats my thinking, told him I getting new machine and he still insisting I put vista on this machine… “it will fix it” LOL
          Thanx for all your help matey.
    • #1454525
      if there was something in the physical slot… it wouldn’t allow me to put something in and it recognize it, cos something is there.
      Jot it down to a dead mobo, and get a new build (updated one) me thinks LOL
      Thanx for the time and patience.
      Someone is telling me, it is cause mobo is designed for vista, so installing vista should fix everything up. Knowing the history, how pc was working fine for months with win7 sp1 ultimate 64bit, what you think? will it fix?
      Am still going for new build… under 650 if I can LOL
      Thought I hit enter on that before I left this morning. Gyuess not…
      Anyways… just to update… in bout a week and a bit time, this PC is going to the graveyard LOL
      CPU: FD4300WMHKBOX $129.00
      Description: AMD FX-4300 Black Edition, 3.80GHz, 4MB Cache, Quad Core, 95watt
      Mobo: ASROCK – 970-EXTREME3-R2 $113.00
      Description: ASRock 970-EXTREME3 R2.0 MB, AMD 970 + AMD SB950, 4x DDR3, 2x PCI-E 3.0, 5x SATA III, 4x USB 3.0, GBLAN, CrossFireX, ATX
      RAM: G.Skill – F3-12800CL9D-8GBXL $105
      Description: G.Skill 8GB (2x4GB), PC3-12800 (1600MHz) DDR3, Ripjaws X, 9-9-9-24-2N, 1.5V, Dual/ Quad Channel Kit
      HDD: Seagate – ST500DM002 $63
      Description: Seagate 500GB Barracuda, SATA III, 7200RPM, 16MB, NCQ
      Case: Antec – GX500B-W $69
      Description: Antec GX500B-W Dominator ATX Case. Window, NO PSU, Supports 15″ Extra Long VGA Card, 2x Fan Controls,7 Expansion Slot, USB 3.0 x 2, 1x 120mm Rear Fan
      PSU: Zalman – ZM-500LX $55
      Description: Zalman 500W ZM-500LX Power Supply, 120mm Fan, 2x PCI-E, 6x SATA, 4x Molex, 1x Floppy
      CPU Cooling Zalman – ZM-CNPS90F $29
      Description: Zalman ZM-CNPS90F Ultra Quiet CPU Cooler
      Had to get a drive, but don’t need one….
      Total is 678.02 (no freight and not installing software)….
      gonna put this gfx card in it… the HD 5450 cos that mobo has no gfx at all… not even vga… but im fine with it… sata III quicker than anything ive experienced LOL.
      Anyways, when that gets to me… will take the kingston hyperx out of this, put it up on ebay, do same with psu etc… stuff that I can’t use on new one, and yeah.
      Thanx much for the help,.
      What ya think of the new build?
      • #1454545
        If everything was working fine with Windows 7 SP1 Ultimate x64 beforehand then it shows that the mainboard’s compatible, especially as it appears to be just one USB port that’s faulty. Changing to Vista won’t make a difference if you have a hardware fault.
        Sorry but no idea. I stopped building PC’s years ago and I’m not familiar with the current market for components.
    • #1454534
      Don’t know where you got your prices but you can do much better at Microcenter – http://www.microcenter.com
      Example:
      AMD FX-4300 Black Edition 3.8 Mhz your price $129 Microcenter – $68 for a 3.9 Mhz
      ASROCK – 970-EXTREME3-R2 your price $113 Microcenter $89
      Jerry
    Viewing 42 reply threads
    Reply To: Win7 64 USB speed problem
