Under Win XP I could record any sound played on my PC using Adobe Audition 1.5. After I upgraded to Win 7 64-bit Prof, I keep getting this error message: “Can not find the mixer program “sndvol32 /r”. I have received the same (or similar) message using other audio / video programs like Camstudio and Audacity. Is there a setting I need to change? I don’t find that file on my PC. Please help.
Win 7 and Adobe Audition – audio problem
Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Win 7 and Adobe Audition – audio problem
- This topic has 12 replies, 5 voices, and was last updated 12 years, 7 months ago.
Viewing 7 reply threadsAuthorReplies-
WSInfinicore
AskWoody_MVPFebruary 15, 2012 at 9:18 pm #1319740In particular, Adobe Audition 1.5 is 7 years old; only versions 3, 4 and 5 are compatible with Windows 7.
Have you tried the Windows 7 Sound Recorder under Accessories?: Record audio with Sound Recorder
Bruce
WSLeon1
AskWoody LoungerFebruary 16, 2012 at 12:30 am #1319755Thanks Infinicore and BruceR. I can appreciate that Audition 1.5 is old, but I have a similar ppoblem with other, new programs.
Although Sound Recorder will not solve my problem to record audio from a file played on the PC, it might help find the solution. When I try to record from the mic, using Sound Recorder, I get no sound. This same mic (and same settings) works fine in Skype.
In XP I used to use the Stereo Mix option. This is not available in my Win 7 Sound control panel.
Both “Show Disabled Devices” and “Show Disconnected Devices” are checked.
Can this problem be due to a missing file in Windows?
AskWoody_MVPFebruary 16, 2012 at 2:29 am #1319765That file doesn’t exist in Windows 7, but there’s a link in this answer that shows how to edit an Adobe Audition .xml file to point to sndvol.exe which replaced it:
Audition V2 under Windows 7 asks for SNDVOL32 /r which under Windows 7 is changed to SNDVOL.EXE
The Windows Sound Recorder can record from other programs as well as from a microphone.
I don’t understand why a new installation of Audacity would not be able to record.
Bruce
WSLeon1
AskWoody LoungerFebruary 16, 2012 at 6:45 am #1319813BruceR. Thanks for the link. Unfortunately I get and Error 404 – Page not found. Available anywhere else?
How do I change Sound Recorder settings to record steaming audio? Someone suggested a link for the speaker output to the line-in, but that sound rather brute force to me!
All I actually want is to record streaming audio and / or video + audio for later use. Seems like Free Hi-Q Recorder can manage the audio, but Camstudio does not capture any audio with the video. Any suggestions.
Leon
AskWoody_MVPFebruary 16, 2012 at 10:08 am #1319878Sorry, the forum ate my link and won’t let me edit it properly. It should have been http://forums.adobe.com/thread/613794
Bruce
AskWoody_MVPFebruary 16, 2012 at 10:55 am #1319892Perhaps Control Panel, Troubleshooting, Hardware and Sound, Troubleshoot audio recording would be worth a try?
Or this Troubleshoot audio-recording problems Microsoft Fix it?
Bruce
WSLeon1
AskWoody LoungerFebruary 16, 2012 at 2:49 pm #1319994BruceR: Thanks for the new link. I checked it out, but it only works for Audition 2. I have 1.5 and the files are not the same. I looked for something similar, but no luck.
The troubleshooting wasn’t worth the trouble. No joy.
After many hours with Google it seems the lack of a Stereo Mix option is hardware related. Apparently not every version of Win 7 has that option.
I have a sound solution (Free Hi-Q Recorder). Will now concentrate on getting Camstudio to work.
Maybe I sould try an old sound card and see what happens. -
WScafed00d
AskWoody LoungerFebruary 18, 2012 at 1:47 pm #1320348I also have Audition 1.5 installed on my 64-bit Win 7 machine. It refuses to record any sound whatsoever. I also have Audacity installed and use it for sound recording, and then switch to Audition for heavy-duty editing. Not ideal, but then I don’t do all that much recording any more (if I did,I’d probably spend the money to upgrade to the latest Audition – I’ve liked it every since it was CoolEdit 2000!)
WSLeon1
WScafed00d
AskWoody LoungerFebruary 25, 2012 at 12:02 pm #1321846Are you asking how to record the sound coming out of your speakers? That is, record what you hear? There used to be such an input device available with with Creative sound drivers, but the latest drivers don’t have it. When I mentioned recording, I meant with devices, such as a turntable, connected to the line-in port.
WSGrant53787
Viewing 7 reply threads -
Windows 11 Insider Preview build 27871 released to Canary
13 hours, 49 minutes ago -
Windows 11 ad from Campaign Manager in Windows 10
Jim McKenna
11 hours, 10 minutes ago -
Small desktops
4 hours, 2 minutes ago -
Totally disable Bitlocker
12 hours, 11 minutes ago -
Phishers extract Millions from HMRC accounts..
11 hours, 27 minutes ago -
Windows 10 22H2 Update today (5 June) says up-to-date but last was 2025-04
Alan_uk
1 day, 17 hours ago -
Thoughts on Malwarebytes Scam Guard for Mobile?
opti1
56 minutes ago -
Mystical Desktop
1 day, 21 hours ago -
Meta and Yandex secretly tracked billions of Android users
MS-DEFCON 2: Do you need that update?
13 hours ago -
CD/DVD drive is no longer recognized
WSCape Sand
2 days, 12 hours ago -
Windows 11 24H2 Default Apps stuck on Edge and Adobe Photoshop
MikeBravo
2 days, 15 hours ago -
North Face and Cartier customer data stolen in cyber attacks
2 days, 13 hours ago -
What is wrong with simple approach?
WSSpoke36
11 hours, 18 minutes ago -
Microsoft-Backed Builder.ai Set for Bankruptcy After Cash Seized
3 days ago -
Location, location, location
Cannot get a task to run a restore point
3 days, 2 hours ago -
Frustrating search behavior with Outlook
MrJimPhelps
2 days, 16 hours ago -
June 2025 Office non-Security Updates
3 days, 12 hours ago -
Secure Boot Update Fails after KB5058405 Installed
SteveIT
Firefox Red Panda Fun Stuff
Lars220
Davidhs
3 days, 23 hours ago -
3 days, 1 hour ago -
4 days, 7 hours ago -
lmacri
3 days, 21 hours ago -
Firefox 139
Charlie
3 days, 14 hours ago -
Who knows what?
19 hours, 6 minutes ago -
5 hours ago
