Wife, forgetting my advice to not, updated to win 11 on her Desktop Cistco PC. Now is past date to revert to Win 10. Although plugged in to Xfinity modem, the OS is using the wireless from the router modem, Unclear to me how to simply change this. And many important websites are blocked, e.g. bank bill pay, utilities, etc. The email provider is not. I made her call Microsoft Support. They wanted lots of info about the computer, e,g serial number, etc, The support person told her there was no wireless on her computer! And then hung up. Is there a website Where some of these issues are addressed? I’m supposed to be tech support here, but my limited expetise is with Win 10. Anyone here have any advice foe me? Will be gratefully appreciated.
Win 11 not connecting to LAN. using wireless and unable to change
Home » Forums » AskWoody support » Windows » Windows 11 » Hardware questions relating to Windows 11 » Win 11 not connecting to LAN. using wireless and unable to change
- This topic has 9 replies, 6 voices, and was last updated 2 years, 9 months ago.
Viewing 5 reply threadsAuthorReplies-
cyberSAR
AskWoody PlusAugust 5, 2022 at 6:29 pm #2467907I had a Win10 machine that was stubbornly connecting to wifi rather than lan. I wanted to keep both available but had to change priority a few times to make it “stick”. Had to disconnect from wireless and I think forget it to finally get it right. Sorry foggy memory and it was a couple years ago.
1st, make sure in control panel your wired lan connection is available. It could be a driver issue. Then see if this may help you through.
https://www.thewindowsclub.com/change-network-adapter-connection-priority-windows -
Just another Forum Poster
AskWoody LoungerAugust 5, 2022 at 8:16 pm #2467922 -
Rick Corbett
AskWoody MVPAugust 6, 2022 at 3:16 am #2467962Have a look at this post here on AskWoody which describes how to change the network connection priority order so ethernet comes before Wi-Fi.
IMO it’s a much better method than ‘forgetting’ a Wi-Fi connection (i.e. deleting a Wi-Fi profile) or disabling Wi-Fi completely as it means Wi-Fi connectivity is still automatically available if ethernet is disconnected.
AskWoody_MVPAugust 6, 2022 at 9:37 am #2468020Rick,
Nice post!
Here’s a little PowerShell script to simplify the listing and give instructions on making the changes.
Clear-Host $GNIFArgs = @{Expression={$_.InterfaceMetric};Label="IFM"}, @{Expression={$_.InterfaceIndex};Label="IFX"}, @{Expression={$_.InterfaceAlias};Label="Caption"} Get-NetIPInterface | Sort-object InterfaceMetric | Format-Table -Property $GNIFArgs "To change priority of any of the above:" 'Set-NetIPInterface -InterfaceIndex "IFX" -InterfaceMetric "New IFM"' "Where:" " IFX : THe InterfaceIndex (IFX) of the adapter to change." " New IFM: InterfaceMetric (IFM) is the priority of the connection," " lower number higher priority!"
cyberSAR
AskWoody PlusAugust 6, 2022 at 10:20 am #2468025On that machine I was referencing above, I had done that multiple times. Would never stick. After forgetting the wifi and connecting to the lan for a day I re-enabled and connected to wifi then back to lan. It has stayed as lan top priority since. Not sure why I had to jump through hoops with that machine as I didn’t have issues with the other 7 in same office????
Rick Corbett
AskWoody MVPAugust 7, 2022 at 5:47 pm #2468328Here’s a little PowerShell script to simplify the listing and give instructions on making the changes.
Excellent! But, come on RG, you can do better than that.
How about just showing the interface metrics for ‘Ethernet’ and ‘Wi-Fi’ and asking ‘Want to swap priority?’. I’m sure you can pipe and manipulate the Get-NetIPInterface results to show just these two network interfaces.
Go on… you know you really want to…
(I’m kidding, very gently. Even after nearly 3 years of tinkering with PowerShell, I still can’t get a handle on it. I can fight my way through AutoHotkey [usually] ‘cos it’s basically English… but PowerShell does my head in, even though I know it’s far more powerful for what I want to achieve delving into Windows’ innards. I’m a ‘Quick’n’Dirty kludger’, not a ‘geek’.
AskWoody_MVPAugust 7, 2022 at 8:06 pm #2468345Rick,
I’ll give is some thought but initial impression is it will take some work.
- Have to figure which IFM’s are not in use.
- Have to figure which items are the Ethernet & Wi-Fi as the captions are set by the user.
Example of the second bullet point:
IFM IFX Caption --- --- ------- 2 19 Computer Mentor Wired 2 19 Computer Mentor Wired 3 15 Computer Mentor Wi-Fi 3 15 Computer Mentor Wi-Fi 25 8 Local Area Connection* 11 25 18 Local Area Connection* 2 25 8 Local Area Connection* 11 25 18 Local Area Connection* 2 65 6 Bluetooth Network Connection 3 65 6 Bluetooth Network Connection 3 75 1 Loopback Pseudo-Interface 1 75 1 Loopback Pseudo-Interface 1
To paraphrase Kahn in “The Wrath of Kahn”
“He Tasks Me. He Tasks Me, And I Shall Have Him! I’ll Chase Him ‘Round The Syntax Of PowerShell, And ‘Round The Windows Maelstrom, And ‘Round Perdition’s Flames Before I Give Up!”
Rick Corbett
AskWoody MVPAugust 7, 2022 at 6:12 pm #2468330I’m supposed to be tech support here, but my limited expertise is with Win 10. Anyone here have any advice foe me? Will be gratefully appreciated.
Have you considered a clean install with Windows 10? The digital license for Windows 10 has already been stored on Microsoft’s activation servers so there’s no issue about activation… it’ll be automatic.
It’ll put you back into an OS environment that you are familiar with. If that’s something you would like to pursue then post back.
windbg
AskWoody PlusAugust 8, 2022 at 6:03 pm #2468609My PC has both WiFi & Ethernet connections. I only enable one at a time.
I go into “Network Connections” and disable the current one and enable the other when switching, with right menu clicks and selecting from the context menu: Enable or Disable.
The shortcut I use to get to the Adapters aka “Network Connections” settings on Windows 10 is:
C:\Windows\explorer.exe “::{7007ACC7-3202-11D1-AAD2-00805FC1270E}”
Otherwise available in Network Settings as “Change Adapter Options”.For some weird network situations, I have needed to toggle the network connection: disable, wait a bit, and then re-enable.
Viewing 5 reply threads -
Office gets current release
4 hours, 34 minutes ago -
21 hours, 6 minutes ago -
5 hours, 37 minutes ago -
Stop the OneDrive defaults
21 hours, 55 minutes ago -
1 day, 7 hours ago -
X Suspends Encrypted DMs
1 day, 11 hours ago -
M W Leijendekker
23 hours, 45 minutes ago -
Enabling Secureboot
ITguy
No more rounded corners??
Android 15 and IPV6
2 days, 7 hours ago -
2 days, 10 hours ago -
2 days, 5 hours ago -
2 days, 17 hours ago -
May preview updates
crown
jkitc
1 day, 9 hours ago -
Botswana12
3 days, 9 hours ago -
7 hours, 6 minutes ago -
3 days, 21 hours ago -
Dave Easley
gtd12345
4 days, 10 hours ago -
Another test post
gtd12345
4 days, 11 hours ago -
wadeer
12 hours, 26 minutes ago
