• Web page links do not work
    Links within a web page no longer work (I am using Windows Internet Explorer, Version 8.0.76 in Win7, 32-bit). Links at the top of a page associated with the site as a whole work, just the in-page links do not.
    I loaded several programs that I purcharsed recently, a couple worked, one is erratic and I am not using, and the other did not work at all (turned out it was not useable on Win 7).
    Appreciate any thoughts on what to try.
    Decisioneer
    Viewing 4 reply threads
    • #1269226
      Are the programs Windows 7 compatible?
      You could try uninstalling them one at a time and see if that fixes the issue.
      • #1269230
        Joe.
        I have that lined up to do if I don’t find something that will fix it otherwise. Definitely will remove the nonworking one(s). I’m afraid a file in windows has been corrupted and removing a program will not fix it.
        Thanks for your thoughts.
    • #1269236
      You could try running “SFC /SCANNOW” from an elevated command line.
    • #1269240
      I’m not sure whether you are saying this happens on all web sites, or just some web sites. Could the links in one part of the page be done with Flash? It might help to have a URL to a site that has the problem.
    • #1269260
      Have you checked to ensure you have not been infected by the apps you loaded? I would judt double check by running av and am scans with your favorite tools. Malwarebytes seems to get some good press.
    • #1269722
      Thanks for the replies. I am sorry I have not been available to give a more timely replies. I will look into the new suggestions and get back to you all. Also, going to look into doing a System Restore, should have done that immediately.
    Reply To: Web page links do not work
