• Using Numbers in Code (VBA / VB)
    Good Morning,
    I work in a department that shares VBA and VB applications (who doesn’t). There is one particular programer here who uses #’s and &’s when using constants, for example:
    dim lnArray(1& to 10&) as integer
    Why the ‘1&’ instead of just using ‘1’?
    Where can I get a listing of all of these codes and what they mean?
    Have you tried searching the help file for ‘&’?
    Cheers
    • #547655
      You should have found something in VBA help searching for “&” etc. These characters are used as Type descriptors for variables. Try searching for Data Types in help. You can use
          Dim a$
      instead of using
          Dim a as String
      but the latter is preferable for clarity. the following is a sample of some others :
          % = Integer
          & = Long
          ! = Single
          # = Double
          @ = Currency
          $ = String
      Andrew C
    • #547657
      As Andrew says, it looks like your programmer is taking shortcuts by using type declaration characters and not explicitly declaring his variables. It’s important for maintenance and to avoid problems that *all* variables be explicitly declared, so turn on the Option Explicit in your modules by checking Require Variable Declaration in Tools–>Options–>Module.
    • #547681
      You and your fellow programmers need to get this guy into a room and bash him exclamation
      Seriously, you should get together as a group and decide on programming standards. Variable naming conventions, programming styles, use of comments, …
      http://www.devx.com/upload/free/features/v…ul98/bc0798.pdf
      http://www.devx.com/upload/free/features/v…pr98/bc0498.pdf
      http://www.devx.com/free/newsletters/ent/ented013101.asp
      cheers
      • #547683
        hang on, hang on, hang on … shocked
        now that is just getting carried away. Who said that he didn’t declare his variables. He does, and he follows the naming convension too.
        However, he does put things like
        dim i as integer
        for i = 1% to 5%
        in his code instead of
        dim i as integer
        for i = 1 to 5
        Therefore, I was asking what the ‘%’s meant and wondering if there was any difference between the two.
        • #547686
          Tim,
          Dim a$ is the exact same a Dim a As String, and hence is an explicit declaration, though the latter is preferable as it is more readable. There is no point in Dim a$ As String.
          There is nothing to be gained from using 1% to 5% in place of 1 to 5, as i is an integer type and so any value it holds will be an integer. It’s use in this instance is superfluous.
          Andrew C
          • #547690
            Excellent. Thanks Andrew.
            How about when you reference or dimension an array. For example …
            dim lsArray(1% to 10%) as string
            lsArray(1%) = "Hello World!"
            as opposed to …
            dim lsArray(1 to 10) as string
            lsArray(1) = "Hello World!"
            • #547691
              Tim,
              As the numbers in dim lsArray(1% to 10%) are indices, they must be integer so I suggest there is no point in declaring them as such. I would setlle for the latter syntax.
              Andrew
        • #547692
          As a member of a team, you are having difficulty reading his code. Shouldn’t the team decide on coding conventions? Shouldn’t you all be on the same playing field? It’s not good to have rouge programmers doin’ their own thing, and others having trouble figuring out what they are doing. What if he leaves, and you get stuck supporting his code? Good code is code that another developer/programmer can look at and easily determine what it’s doing. Using arcane ancient syntax (% and &) that’s long been abandoned for more descriptive syntax isn’t good code.
          In your examples of his code, I believe the %, $, and & are unnecessary and should be removed for clarity. They only serve to confuse.
          All I’m saying is as a group, you should decide on coding standards so issues like the one you brought to the lounge don’t come up.
          shrug
          Take care,
          • #547733
            Especially true in VBA where “&” is also used to concatate strings and other symbols have their own meaning.
            Ewan
    Reply To: Using Numbers in Code (VBA / VB)
