Hello.
I’m working on a template for use cases. This template includes a revision number on the front cover as well as in the headers and in a revision table. (Each time someone updates the doc, they change the revision number and add information about the types of changes they made.) Up to this point, the user has had to go in to each header/table cell/cover and manually enter the revision number (such as 0.3) or do a find/replace. This isn’t very user-friendly. (understatement)
We already use the Properties dialog box for most of our repeated information in the template. Is there a way you could use one of the fields in the Properties dialog box and manipulate it for this use?
Otherwise, I’ve thought of using field codes and bookmarks, but I just can’t seem to get it to work right. Does anyone have any ideas (particularly involving thorough steps since I can’t seem to make anything work correctly in this darn template)???
Thanks a bunch! I eagerly await the solution.
Dina
