Hi
I have a Satellite A200, Model PSAF3A-0QH01N, running Vista Basic, It was bought new, in New Zealand, in 2008 and it has worked well.
It has now developed a problem that can only be seen when it is dead cold. At this time it will not boot.
When the power button is pressed the power supply connected, power on and charging lights are all on. The hard disk light flashes very briefly, the screen does not show anything at all. The laptop then fails to do anything else.
– Tried with and without the battery installed
– Tried with another power supply
– Reseated and tested the RAM
– Installed a new hard disk
– Clean install of the O/S
If I power on (but it doesnt boot of course) and leave it for maybe 5 minutes, push and hold the power button until it turns off, then push the power button to power on, the laptop will usually start ok, show BIOS screen and Vista will start. It will operate normally while it remains powered up.
I’ve put this in the Hardware forum because:
– RAM has been tested
– Hard disk has been replaced
– OS has been re-installed
– Nothing shows on screen
Therefore I assume it is not a RAM, not a hard disk and not a Windows problem. It could be a BIOS issue but I have no idea how to prove it.
Can anyone suggest something I have missed, or suggest something I can try to fix this somewhat annoying problem, please?
Cheers
Colin
