I tried using Macrium Reflect to backup in preparation for the upcoming Windows 10. Currently have Windows 7 Professional. The backup was to go to my Toshiba 2TB external hard drive. During the preliminary steps, there was a warning box that said something like “This will overwrite the data on the drive” , but I stupidly clicked “Procede” anyway. Now when I open “Computer” from the desktop or the Start Menu, it shows Local Disk (C:), but no External Disk (F:). I have tried unplugging the Toshiba external drive and replugging it into all 6 USB plugin spots on my Dell Optiplex 780, but it still will not show the external hard drive. Anyone know what went wrong, and more importantly, how to fix it? I tried System Restore but that didn’t work.Thanks in advance.
Toshiba external hard drive detection problem.
Home » Forums » AskWoody support » PC hardware » Questions – Maintenance and backups » Toshiba external hard drive detection problem.
- This topic has 22 replies, 14 voices, and was last updated 9 years, 10 months ago.
AuthorTopicWSisandman02
AskWoody LoungerJune 26, 2015 at 2:33 pm #500660Viewing 14 reply threadsAuthorReplies-
Paul T
AskWoody MVPJune 27, 2015 at 2:39 am #1512261You attempted (succeeded) to clone your internal disk to the external disk instead of performing a backup. There is no way to recover the old data because it will have been overwritten.
To use the drive again, open Disk Manager, delete any existing partitions on the external disk, create one new one and format it as FAT32.
To open Disk Manager click Start > Run and type: diskmgmt.msccheers, Paul
Coochin
WSCalimanco
AskWoody LoungerJune 27, 2015 at 3:39 am #1512266Your problem is probably that your external drive has lost the drive letter associated with it, a problem which I have occasionally encountered when cloning. The solution is to open Disk Manager, right click on the drive and allocate a free drive letter to it. It will then appear in explorer.
Paul T
AskWoody MVP -
Coochin
AskWoody_MVPJune 27, 2015 at 7:42 pm #1512358FAT32 supports up to 2TB and anything will be able to read it. If you are only ever going to use it in Windows you could use NTFS…
Correct, FAT32 supports up to 2TB partition size but has a file-size limit of slightly less that 2GB, which is likely to cause problems if the drive is used for storing backup images.
WSisandman02
AskWoody LoungerJune 29, 2015 at 11:48 am #1512633Thank you Paul T. and everyone else who replied. I opened Disk Manager but it did not show any F drive where the Toshiba external drive is plugged into, so that didn’t work. Looks like the Toshiba external drive is now trash and years worth of data gone. Rest assured that I will never go near Macrium ever again. I am also ready to give up on backups. Anyone know any free backup software that is simple and easy to use and that won’t cause any more damage?
Paul T
AskWoody MVP -
martins2
AskWoody LoungerJuly 2, 2015 at 5:48 pm #1513243Macrium Reflect free is very good and doesn’t damage your hardware.
I have to agree. Have been using it for years, writing image backups to an external HDD, and it has always worked flawlessly. On more than one occasion I have needed to restore from a disk image backup, and that has always worked flawlessly as well. I’m more than happy with the new version 6, because it offers better restore options and now includes auto verify of an image. Give it another go.
WSDoc Matrix
AskWoody LoungerJuly 2, 2015 at 12:25 pm #1513183FAT32 supports up to 2TB and anything will be able to read it. If you are only ever going to use it in Windows you could use NTFS.
Windows Vista (and up) will not allow you to create a FAT32 partition bigger than 32GB. You’ll need some sort of tool (like a bootable CD that supports USB drives) to format the disk.
WSRolandJS
AskWoody PlusJune 27, 2015 at 2:47 pm #1512333If you meant to create an image of your internal HD OS partition, something went wrong. I’m not sure if MiniTool Power Data Recover will work or not; the previous FAT and DIR tables probably are non-existant.
WSFascist Nation
AskWoody LoungerJune 27, 2015 at 5:43 pm #1512353I tried using Macrium Reflect to backup…The backup was to go to my Toshiba 2TB external hard drive. During the preliminary steps, there was a warning box that said something like “This will overwrite the data on the drive” , but I stupidly clicked “Procede” anyway. Now when I open “Computer” from the desktop or the Start Menu, it shows Local Disk (C:), but no External Disk (F:). I have tried unplugging the Toshiba external drive and replugging it ….Anyone know what went wrong, and more importantly, how to fix it? ….
I do not know. I can guess sudo is correct you cloned your C: drive image rather than saving your data. Plug it into another system: is ti recognized there?
Was anything on your 2TB external that was not on your PC?
[*]If no, then I would save an image of your C drive to the 2TB disk. If you cannot see the drive them I would use Disk Management to delete all partitions and repartition and format the drive.
[*]If yes, then sudo is correct that anything overwritten by Macrium Reflect (MR) is lost for good, but because the default of MR is to do a “Intelligent Sector” clone rather than a sector by sector clone only the space needed would have been overwritten. Anything outside the area is recoverable. I would use photorec and testdisk booted up on system rescue CD or other suitable boot disk and see if it sees the external drive and can recover files. Copy recovered files to a PC drive.I am unsure why your external drive is unviewable by Windows. It would be a external Win7 boot drive and Win7 doesn’t like that at all but it should see the drive. Testdisk may allow you to “fix” the drive. Be very careful. Copying files is fine. But making (writing) changes to the external drive may lose more or all data, or make things worse requiring more tech help $$$ in unwinding whatever is left.
If you cannot see the external drive with system rescue booted something is fundamentally wrong. If this is the case I would go into Disk Manager in Windows and try to see what it reports for the drive. If it does not see it then I wonder if the drive has coincidentally failed.
WSCalimanco
AskWoody LoungerJune 29, 2015 at 1:27 pm #1512650I opened Disk Manager but it did not show any F drive where the Toshiba external drive is plugged into
That was the point. It should show the drive, but with no drive letter.
If the drive has failed, as all drives do eventually, its unlikely that the software itself caused it.
As for the warning message, all cloning software reformats the drive its cloning to before writing the clone. You cant clone to a drive if it already has data on it.
If you have data you don’t want to lose, its always a wise precaution to have multiple backups. -
WSisandman02
AskWoody LoungerJune 30, 2015 at 2:49 pm #1512856I opened Disk Manager but it did not show any F drive where the Toshiba external drive is plugged into
If you have data you don’t want to lose, its always a wise precaution to have multiple backups.When I click “Computer” it does not show the drive or the drive letter(“F”) for the external drive now, only the local “C” drive. As for multiple backups, I would like to have one that works and is easy to use. After what happened, Macrium is out of the question. Anyone familiar with and able to recommend any other free backup programs?
WSCalimanco
AskWoody LoungerJune 30, 2015 at 7:45 pm #1512901Now I’m confused and it sounds as though you may be also. You said you opened Disk Manager, then you say you clicked on Computer, which is in Explorer, a completely different utility. Look in Disk Manager. The drive wont show in Explorer if it doesn’t have a drive letter allocated to it in Disk Manager. Open a Command Prompt and type diskmgmt.msc to access Disk Manager
Paul T
AskWoody MVPJuly 1, 2015 at 2:56 am #1512934 -
WSChris Cooper
AskWoody LoungerJuly 2, 2015 at 7:45 am #1513143My personal experience is that Toshiba drives are amongst the least reliable but, unless it has committed harakiri, you may well be able to recover your data.
Before you bin the Toshiba drive I suggest you try to recover the original, overwritten partition – if that is indeed what has happened. The best tool I know to achieve this is the excellent Partition Wizard (free).
Download Partition Wizard v9 free:
http://filehippo.com/download_minitool_partition_wizard_home_edition/Download Partition Wizard Bootable CD v9 free (runs in RAM at boot)
http://www.minitool.com/C3883AF0-D8F8-4CAB-83D8-DA6497F1C8CC/pwfree9.isoYou may be able to recover keeping the Tosh drive in its USB case but I’ve never done this myself and the last thing you need to do at this stage is muddy the waters even further.
So I recommend you open the Tosh external drive and remove the ordinary HD drive that’s in there.
If you are dealing with a Desktop (or have access to one) connect the Tosh drive to a spare SATA port. Note that, if you have actually cloned you main drive to it, you may need to go into the BIOS/UEFI and make sure the Desktop doesn’t try to boot from the cloned Tosh drive.Install Partition Wizard v9 free on the Desktop, run it. Find the Tosh drive and choose the Partition Recovery Wizard Option. Sit back and keep your fingers crossed – I’ve seen PW magically save the day on numerous occasions. If the Tosh has been cloned to multiple partitions you may need to choose the ‘Recover all partitions’ options.
If you are trying to do this on a laptop, burn the bootable CD iso version and then temporarily replace your the laptop’s internal drive with the Tosh drive (I’m assuming the Tosh is a 2.5). Then boot from the CD drive and proceed as above.
To be honest, most people will find the CD version the most reliable to use as it’s Linux based and runs in RAM before Windows has a chance to boot.
If it all works, reassemble the Tosh external and off you go.
Good luck!
And take my tip: Do NOT ‘upgrade’ to Win10 until it’s at least 12 months old – we’ve all been here before and, from how Win10 performs at the moment, it sure ain’t looking any better this time!
satrow
AskWoody MVPJuly 2, 2015 at 2:32 pm #1513206@isandman02:
11. Document any critiques of specific companies
If your post mentions a problem with a specific company’s products or services, be sure to include solid and reproducible documentation of your remarks, such as a detailed description, screen shot, or photo of the problem. You, not the Lounge, will be responsible for defending your statements.I see no proof that MR is involved with your problem, I’m altering the Topic title.
WSstarvinmarvin
AskWoody LoungerJuly 2, 2015 at 4:36 pm #1513222Check out this video. Turn up the volume as the narrator doesn’t speak very clearly:
WSSudo
AskWoody LoungerJuly 2, 2015 at 4:55 pm #1513229I have system images of four different laptops on a Seagate external HDD just using Windows own Create a system image.
It will overwrite an existing image for that computer but doesn’t interfere with anything else on the HDD.
BTW – I recently formatted a new 1TB external HDD to NTFS and it took ~12hrs.
WSstarvinmarvin
AskWoody LoungerJuly 2, 2015 at 9:14 pm #1513261Windows’ own backup program allows you to create a system image very easily. If you’re saving your system images on an internal or external drive, or on CDs or DVDs, you can keep several versions of system images. On internal and external hard drives, older system images will be deleted when the drive runs out of space. If you’re saving your system images in a network location, you can only keep the most current system image for each computer. To save more/older system images, create the new system image in a different location such as a different partition or drive. My only grumble is that, unlike some third-party backup programs, Windows doesn’t compress the image to save space.
WScosmlou
Lugh
AskWoody_MVPJuly 17, 2015 at 7:04 am #1515588Fred Langa uses and recommends Win7’s built in backup tools, so try those–they’re free and straightforward.
I agree with everyone else, Macrium Reflect is not the problem, you made a mistake while using it, like we all do from time to time.
I use Macrium Reflect for system disk images, and I use either normal copying or Karen’s Replicator for file backup of my data disk.
I got burned twice 10-20 years ago by file backup software which wouldn’t restore properly when needed, so ever since I’ve kept it as simple as possible.
Lugh.
Viewing 14 reply threads -
n0ads
3 hours, 1 minute ago -
You can’t handle me
1 hour, 17 minutes ago -
1 hour, 35 minutes ago -
10 hours, 35 minutes ago -
10 hours, 47 minutes ago -
10 hours, 59 minutes ago -
11 hours, 4 minutes ago -
Lumma malware takedown
EyesOnWindows
40 minutes ago -
19 hours, 52 minutes ago -
19 hours, 46 minutes ago -
Meet Gemini in Chrome
23 hours, 52 minutes ago -
Trump signs Take It Down Act
1 day, 7 hours ago -
52 minutes ago -
10 hours, 11 minutes ago -
not so anon
1 day, 11 hours ago -
10 minutes ago -
hibernate activation
e_belmont
2 days ago -
2 days, 3 hours ago -
23 hours, 12 minutes ago -
Out of band for Windows 10
2 days, 7 hours ago -
Giving UniGetUi a test run.
2 days, 14 hours ago -
2 days, 22 hours ago -
18 hours, 12 minutes ago -
Auto Time Zone Adjustment
wadeer
3 days, 2 hours ago -
Eddieloh
3 days ago -
Mary Branscombe
28 minutes ago -
2 hours, 42 minutes ago
