• Top 3 Formula Help (Excel 97)
    I need some more assistance with a survey results spreadsheet I am working on. Companies were polled and ranked their top 3 choices. I need a way to determine what the top 3 results were. I would like the results to appear something like this:
    #1 – Experience
    #2 – Service
    #3 – Relationship
    I figured out a way to count how many times each answer appears. But I don’t know where to go from there. Any ideas would be greatly appreciated.
    • #956555
      You can use the RANK function to find the 3 highest scores; I used a modified version to construct unique ranks from Ranking Data In Lists.
      Next, you can combine this with MATCH and INDEX to find the corresponding choices. See attached.
    • #956812
      The problem you want to solve belongs to the class of Top N problems, where N = 1, 2,…
      What follows is a formula system I devised to tackle with such problems. The system results agree with the results one would obtain with a pivot table.
      The data in C4:AA4 consists of multiple items (considerations like Service, Knowledge, Experience) per cell obtained by means of surveys. (See the attachment for references.)
      Note that the data is a bit altered to better illustrate the point of the formula system.
      The problem: Create a Top 3 list of considerations, based on their occurrence frequencies.
      C5:C11 lists the ‘conisderations’ of interest.
      D5, copied down:
      =COUNTIF($C$4:$AA$4,”*”&C5&”*”)
      calculates the frequency of occurrence per consideration.
      E5, copied down:
      =RANK(D5,$D$5:$D$11)+COUNTIF($D$5:D5,D5)-1
      assigns a ranking per consideration.
      D13: 3
      indicates N of Top N you want.
      D14:
      =MAX(IF(INDEX(D5:D11,MATCH(D13,E5:E11,0))=D5:D11,E5:E11))-D13
      which must be confirmed with control+shift+enter, not just with enter.
      This “kernel” formula calculates the ties of the Nth value (frequency of occurrence).
      D16, copied down:
      =IF(ROW()-ROW($D$16)+1<=$D$13+$D$14,INDEX($C$5:$C$11,MATCH(ROW()-ROW($D$16)+1,$E$5:$E$11,0)),"")
      creates the correct Top 3 list of considerations you are after.
    Reply To: Top 3 Formula Help (Excel 97)
