• Too Few Parameters, for an SQL String?? (Access 2K)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Too Few Parameters, for an SQL String?? (Access 2K)
    Dear All
    I’m trying to use a simple SQL string in VBA to validate an option, here’s the SQL and the line I get the error on. I’m thinking that maybe I need to define the strCurrentUser Variable? It is currently set to the CurrentUser from the Access Security log in.
    strCurrentUser = CurrentUser
    SQLInfo = “SELECT * FROM ConcessionNamesTbl WHERE ConcessionAwardee LIKE ” & strCurrentUser
    Set RstUserInfo = DbS.OpenRecordset(SQLInfo)
    I’ve checked that the variable strCurrentUser has been assigned a value, I’ve modified the SQL string to contain the value and everything works fine then, so, how do I persuade Access that the variable is what it needs? I’ve also tried using the = symbol, switching to LIKE as I’d heard this might allow Access to match different types of variable more easily.
    Ian
    • #797644
      strCurrentUser is a string; string values must be enclosed in quotes: “Admin”. You can’t just embed quotes within the quoted string SQLInfo, because that would confuse VBA. There are three possible workarounds:
      – Double the double quotes within the string
      – Use single quotes around the value
      – Concatenate with Chr(34)
      For this situation, I prefer the latter option:
      SQLInfo = “SELECT * FROM ConcessionNamesTbl WHERE ConcessionAwardee = ” & Chr(34) & strCurrentUser & Chr(34)
      • #797672
        Hans
        Thanks, problem solved
        Now, while I’m learning something new…… I’ve looked up the Chr bit in the help file (I’d not come across them before) and it lists quite a few characters. Are these the things I can use to ‘format’ sections of VBA code that will be output as text?
        For example, I’ve got some Docmd.SendObject code and want to include a longish length of text in the body section. Could I use Chr 10 (a line feed characater) to make the body text look more presentable? Along with say Chr 13 (carriage return)?.
        I think you might have revealed yet another corner of the Pandora’s Box that is Access
        Thanks again
        Ian
        • #797684
          Hi Ian,
          Each ‘character’ has a numeric code, but in most cases you don’t need to know it, you just use the character. But special characters, such as quotes, but also the ‘tab’ character and ‘line feed’, sometimes can’t be entered directly. For some of those, there are built-in symbolic constants:
          Constant Characters
          vbTab Chr(9)
          vbLf Chr(10)
          vbCr Chr(13)
          vbCrLf Chr(13)+Chr(10)
          vbNewLine idem
          So if you want to insert a line break in a string, concatenate with vbCrLf:
          strBody = “Hello Ian,” & vbCrLf & “Here is your file.” & vbCrLf & “Cheers, Hans”
          If necessary, concatenate multiple vbCrLf’s.
          • #797700
            cheers clapping cheers thankyou and the nearest I can find to an ‘I worship at your feet’ smilie woops .
            Thanks Hans. You keep revealing those little tricks that make Access so much more friendly [thumbsup]
            Ian
            • #798043
              To make your like a little easier, you might want to create some public functions that you can stick in a module. Since the vb constants won’t work within SQL, it gives you tools to use anywhere. For example, here are a couple I use:
              Public Function Qu( )
              ‘Returns the double quote character
              Qu = chr(34)
              End Function
              Public Function nl( )
              ‘ Returns a carriage return & linefeed
              nl = vbcrlf
              End Function
            • #798044
              Qu = chr(34)
              End Function
              nl = vbcrlf
              End Function
          • #797701
            Ian
        • #797685
          Hi Ian,
          Constant Characters
          vbTab Chr(9)
          vbLf Chr(10)
          vbCr Chr(13)
          vbNewLine idem
      • #797673
        Hans
        Thanks again
        Ian
    • #797645
    Reply To: Too Few Parameters, for an SQL String?? (Access 2K)
