One of my customers want, to save place, a switch to connect 2 PC to 1 monitor, 1 mouse and 1 keyboard and switch from one to the other PC with a key combination.
Have somebody experience with such a device ?
Thanks for your time.
Switch for Keyboard Mous and Monitor
Home » Forums » AskWoody support » PC hardware » Questions: How to troubleshoot hardware problems » Switch for Keyboard Mous and Monitor
- This topic has 5 replies, 6 voices, and was last updated 23 years, 2 months ago.
AuthorTopicWSFrancois
AskWoody LoungerJanuary 24, 2002 at 6:39 pm #365913Viewing 2 reply threadsAuthorReplies-
WSkaplinb
WSi4004
AskWoody LoungerFebruary 2, 2002 at 6:00 am #567890I have a Linksys 4-port that does this (there’s also a button on the case). The one I have works well, but it’s designed to be placed out of sight as the jacks are on three sides.
You may wish for a model that has the jacks on the back.
Most KVM switches do not come with cables; some do. When checking prices factor in how much it will cost for the cable sets in addition to the cost of the KVM switch compared to one that inclused cables.
KVM switches are often rated by the maximum resolution they will support. This is generally a function of the quality of the conntions and internal switch circuit.
One more is to determine what connectors the keyboard and mouse use. If you only need PS/2 connections you can save a few by getting one that only supports PS/2 ports.
John Hilpp
MemberFebruary 10, 2002 at 4:26 am #569374Hey Friends, I just set-up a KVM, Win 98 and Win XP, and the Win XP won’t accept my cordless wheelmouse because it uses a serial port. Does this mean I have to use a PS/2 mouse? What can I do so I don’t have to buy a new mouse? Although It does work but without all of its functions, its seems to be affecting my Win 98 in some strange monitor quarks, or would maybe that be caused by some electrical mojo between these two units? I know the Win 98 pretty well and it doesn’t usually act that way without some kind of influence.
WSetherboy2000
AskWoody LoungerFebruary 14, 2002 at 3:48 pm #570350
WSzymurgy
AskWoody LoungerMarch 14, 2002 at 7:57 pm #576339I’ve used two different KVMs, one unfortunately with unsatisfactory results pertaining to the mouse.
{I use a Logitech Trackman Marble +, which has a track ball, two buttons and a wheel for the middle button. The wheel performs both the scrolling and double-click functions.}
The Linksys model kvm100sk, which is a two-port model worked perfectly.
The Belkin Omniview four-port model f1db104p worked fine when I only had one computer running. However, after switching computers, I lost the scrolling functionality of the wheel until the computer was re-booted. The response of Belkin’s tech support was to stop using the Logitech mouse driver, thereby giving up the wheel functions.
Since I’ve also been in the market for a new KVM, I’ve been checking the online manuals for the different units, and they all have troubleshooting segments dealing with non-responsive mice. The universal answer is to use a plain two-button mouse with the standard Windows mouse driver.
Viewing 2 reply threads -
1 hour, 25 minutes ago -
2 hours, 19 minutes ago -
Auto Time Zone Adjustment
wadeer
5 hours, 54 minutes ago -
Eddieloh
3 hours, 34 minutes ago -
Mary Branscombe
2 hours, 46 minutes ago -
26 minutes ago -
2 hours, 44 minutes ago -
Apps included with macOS
3 hours, 35 minutes ago -
Xfinity home internet
MrJimPhelps
2 hours, 39 minutes ago -
1 hour, 5 minutes ago -
Debian 12.11 released
10 hours, 10 minutes ago -
Deo
2 hours, 34 minutes ago -
1 day, 23 hours ago -
healeyinpa
2 days, 2 hours ago -
Rick Corbett
LHiggins
NO POWER IN KEYBOARD OR MOUSE
HE48AEEXX77WEN4Edbtm
4 hours, 5 minutes ago -
2 days, 11 hours ago -
2 days, 8 hours ago -
Mike Cross
1 day, 22 hours ago -
3 days, 1 hour ago -
1 day, 9 hours ago -
22 hours, 21 minutes ago -
3 days, 4 hours ago -
2 days, 17 hours ago -
3 days, 12 hours ago
