• Sum values between two dates by VBA code
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Sum values between two dates by VBA code
    I hope someone will guide me to write the VBA code without showing formulas in the result cell to get the below answer
    In the below dropbox linked file:
    Column A8:A1000 I have production date (1-1-2015 to 31-12-2017)Column B8:B1000 I have Sales date (1-1-2015 to 31-12-2017)Column C8:C1000 I have Production QuantityColumn D8:D1000 I have Sales Quantity In cell E2 Start date is 3-3-2015In cell E3 End date is 9-9-2017In cell E4 i need a total of column C, in between the D2 and D3 dates of Column A (Production quantity between those dates)In cell E5 i need a total of column D, in between the D2 and D3 dates of Column B (Sales quantity between those dates)
    https://www.dropbox.com/s/ifdak1vx82xgb5w/Sum%20Between%20two%20dates.xlsx?dl=0
    Edit to remove HTML. Please use the “Text” tab in the entry box when you copy/paste.
    Viewing 15 reply threads
    • #1368705
      I don’t profess to be a VBA expert, but I think this does what you want:
      Code:
      Sub SumBetween()
      Sheets("Sheet1").Range("E4").Formula = "=SUMPRODUCT((A8:A15000>E2)*(A8:A15000<E3)*(C8:C15000))"
      Sheets("Sheet1").Range("E4") = Sheets("Sheet1").Range("E4").Value
      Sheets("Sheet1").Range("E5").Formula = "=SUMPRODUCT((B8:B15000>E2)*(B8:B15000<E3)*(D8:D15000))"
      Sheets("Sheet1").Range("E5") = Sheets("Sheet1").Range("E5").Value
    • #1371255
      This is not meant to dissuade your pursuit of a solution in VBA but for my simpler needs I tend to rely upon the Julian calendar where each day in the year had a number, 1 to 365 or 1 to 366, an example would be rather simple to use current day of 126 and subtract a previous day such as 85 to get the difference from March 26.  The US Government and Military always had the Julian date included on their calendars, don’t know if they ever stopped that practice since I retired 25 years ago.
    • #1375333
      Or if you’re interested in a non VBA solution these formulas will do the trick.
      e4:=SUMIFS(C8:C5187,A8:A5187,">="&E2,A8:A5187,"<="&E3)
      e5:=SUMIFS(D8:D5187,B8:B5187,">="&E2,B8:B5187,"<="&E3)
      Note: Your sample file had dates way past row 1000 so I used the rows that contained dates. I'd recommend using dynamic range names so that when you add rows the ranges are automatically adjusted. I'd also assign range names to the beginning & ending dates.
      HTH :cool:
      • #1375795
        Hey, RG…glad to see you’re logging in!!
        BTW: if the OP still wanted VBA, SUMIFS doesn’t work there, does it? I didn’t think so, which is why I used SUMPRODUCT.  I guess you can use Application.WorksheetFunction.SUMIFS…right?
        Oh, and I took him literally when he said “between” and didn’t include the =.
    • #1397880
      Kevin.
      You know I love VBA but it isn’t always the best solution. If the OP doesn’t want the formulas to show he could protect those cells then protect the sheet uncheck the option allowing the selection of protected cells thereby hiding the formulas.
      HTH 😎
    • #1475715
      FWIW, you could use SUMIFS equally as well as you used SUMPRODUCT there. It’s just a formula.
    • #1534710
      Dear All
      The below code is working fine except when I select (“EN6”) value in the cell (“P1”) dropdown list because it is an index match formula and all others are sumproduct. The sumproduct I got results after many website searching.
      Just go through the code and give me a solution to get the results when I select EN6 value in the cell P1.
      Thanks in advance
      Option Explicit
      Private Sub Worksheet_Change(ByVal Target As Range)
      Dim J As Range, G As Range, Where As Range
      Dim Low As Date, High As Date
      Dim Dates, Types, Values
      Dim i As Long
      Dim Sum As Double, Sum1 As Double, Sum2 As Double
      'Only if P1 changes
      If Intersect(Target, Range("P1")) Is Nothing Then Exit Sub
      'Get the dates
      Low = Range("EO1").Value
      High = Range("EN1").Value
      'Refer to the used cells in column J
      Set J = Range("J8", Range("J" & Rows.Count).End(xlUp))
      'Same size in column G
      Set G = Intersect(Columns("G"), J.EntireRow)
      'Read in all data
      Dates = J.Value
      Types = G.Value
      Select Case Target.Value
      Case Range("EN2").Value
      'Same size in column CF
      Set Where = Intersect(Columns("CF"), J.EntireRow)
      'Read in all values
      Values = Where.Value
      'Process the SUMPRODUCT
      For i = 1 To UBound(Dates)
      If Dates(i, 1) >= Low And Dates(i, 1) <= High And Types(i, 1) = "Sales" Then
      Sum = Sum + Values(i, 1)
      Next
      Case Range("EN3").Value
      Set Where = Intersect(Columns("T"), J.EntireRow)
      Next
      Case Range("EN4").Value
      Set Where = Intersect(Columns("B"), J.EntireRow)
      Dates = Where.Value
      If Dates(i, 1) <= High Then
      Sum1 = Sum1 + Values(i, 1)
      Next
      Set Where = Intersect(Columns("CA"), J.EntireRow)
      Dates = J.Value
      Sum2 = Sum2 + Values(i, 1)
      Next
      Sum = Sum1 - Sum2
      Case Range("EN5").Value
      Set Where = Intersect(Columns("BY"), J.EntireRow)
      Next
      Case Range("EN6").Value
      Dim CG4EF4
      CG4EF4 = Range("CG4:EF4").Value
      With Worksheets("RM Price")
      'Note the . in front of Range:
      Set Where = .Range("A2", .Range("A" & .Rows.Count).End(xlUp))
      Set Where = Intersect(.Columns("B:BA"), Where.EntireRow)
      End With
      Case Range("EN7").Value
      Dates = Where.Value
      Set Where = Intersect(Columns("CE"), J.EntireRow)
      Next
      Set Where = Intersect(Columns("BZ"), J.EntireRow)
      Dates = J.Value
      Next
      Sum = Sum1 - Sum2
      End Select
      'Events off, otherwise we call ourself
      Application.EnableEvents = False
      'Write the sum into the sheet
      Range("EL7") = Sum
      'Events on
      Application.EnableEvents = True
    • #1826220
      How about something like this:
      Public Sub SumProdSales()
      Dim I As Long
      Range("E4") = ""
      Range("E5") = ""
      LR1 = ActiveSheet.Cells(Rows.Count, 1).End(xlUp).Row
      LR2 = ActiveSheet.Cells(Rows.Count, 2).End(xlUp).Row
      If LR1 >= LR2 Then LR = LR1 Else LR = LR2
      For I = 8 To LR
      If Cells(I, 1) >= Range("E2") And Cells(I, 1) <= Range("E3") Then
      Range("E4") = Range("E4") + Cells(I, 3)
      If Cells(I, 2) >= Range("E2") And Cells(I, 1) <= Range("E3") Then
      Range("E5") = Range("E5") + Cells(I, 4)
      Next I
      HTH,
      Maud
    • #1832089
      See attached file
      zeddy
    • #1832095
      In my attached file in the previous post, ignore the .pdf file extension, it’s really an excel .xlsb file. But you can’t post .xlsb file types here, so apologies for tricking the system.
      In the posted file, I used the worksheet change event to detect if the Start Date or End Date was changed. If a date is changed, the result is then re-calculated using vba.
      My calc formula uses the entire columns. It is simple, and effective.
      zeddy
      • #1832100
        #zeddy
        I don’t believe the attachment of the file was successful.
        I’m not seeing any attachment.
    • #1832220
      Ignore my previous 2 posts – seems like I didn’t trick the system after all!
      So I will now try and work out how to post the block of vba code I used.
      I tried to wrap it using
      Code:
       and
      but the system here didn’t like that.
      zeddy
    • #1832221
      Ok I’ll try this:
      Code:
      If Not Intersect(Target, [e2:e3]) Is Nothing Then       'changed date cell detected
      zProductionQty = [=SUMIFS(C:C,A:A,">="&E2,A:A,"<="&E3)] 'calculate value
      zSalesQty = [=SUMIFS(D:D,B:B,">="&E2,B:B,"<="&E3)]      'calculate value
      [e4] = zProductionQty                                   'put value in cell
      [e5] = zSalesQty                                        'put value in cell
      zeddy
    • #1832222
      In my previous post, put that into the sheet-code-module.
      zeddy
      • #1832225
        Try using:
        < pre >
        < /pre >
        without the spaces.
        • This reply was modified 5 years, 10 months ago by PKCano.
    • #1832226
      Ok, trying to post a copy of the .xlsx file without the sheet code.
      Sum-Between-two-dates-rz1
    • #1832231
      OK, trying again
      to attach the camouflaged .xlsb file as a “pdf” file..
      zeddy
    • #1834795
      It seems we can’t post any excel .xlsm files.
      This is a pity, it would be more convenient. And if the reasoning is because people are worried about macro viruses, then I would say get yourself a virus protection program. They are available. Just saying. It is tedious to have to post code that has to be then copied into files.
      I liked Kevin’s method of putting a formula into the cells via vba, then converting the formulas to values, as the OP didn’t want to see any formulas. A nice touch to use 15000 in the formulas to allow for plenty of extra record rows. But since you can now refer to entire columns in formulas, without incurring unwanted calc overhead (only used-range-rows are actually used), you can effectively allow for over 1 million record rows.
      I liked RG’s suggestion about using dynamic range names, but using entire-column references in the SUMIFS formulas means you don’t need to. Using sheet protection to lock and hide the formula cells is a really great suggestion – it would stop anyone just overtyping the results-cells to put whatever values they ‘wanted to see’.
      Maudibe’s nice vba routine is easy to follow, and you can understand what’s going on.
      zeddy
      • This reply was modified 5 years, 10 months ago by zeddy.
      • #1835712
        Zeddy,
        Thanks for the heads up on using whole column references in SUMIF, I was unaware of that change. Guess it’s time to hit the documentation and see what other changes I have missed…LOL. 😎
    • #1836358
      Hi RG
      I’m hitting the documentation too!
      I’m only now getting used to the term “spill” for Excel. The <b>spill range</b> relates to the new output ranges of Dynamic Array formulas, which are replacing Ctrl+Shift+Enter (CSE) formulas. If something is blocking the output spill range, you will see a new #error type: #SPILL!
      And we can refer to these spill ranges e.g. when defining the Source range for a Data Validation list, e.g. Source: =F2#
      F2# refers to the entire range of spill data. F2 is the first cell in the spill range. Adding the # to the cell ref turns it into a reference for the entire spill range.
      These new functions are not yet available on general release, but you can read up on them to get a step ahead.
      zeddy
      Carp Diem
      (Fish of the day)
    Reply To: Sum values between two dates by VBA code
