I
subform problem (97)
Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » subform problem (97)
- This topic has 13 replies, 4 voices, and was last updated 23 years, 8 months ago.
Viewing 6 reply threadsAuthorReplies-
notbrl
WSMarkLiquorman
AskWoody LoungerAugust 1, 2001 at 9:44 pm #535554I find the best way to maneuver in a subform from a mainform is via the subform recordsetclone. First of all, you need to know the name of the subform control on the mainform. The subform control name may or may not be the same as the name of the subform itself. I’ll just use subformcontrolname.
with Me.subformcontrolname.form.recordsetclone .findfirst "refno=" & txtrefno if .nomatch=true then ' means you didn't find it exit sub end if Me.subformcontrolname.form.bookmark = .bookmark end with
WSarage
WSMarkLiquorman
WSarage
WSMarkLiquorman
AskWoody LoungerAugust 2, 2001 at 4:50 pm #535692I just sort of assumed since you used the phrases “refnum” and “invoicenum” that you were dealing with numbers! You must modify your code to enclose the value of the controls in apostrophes, like this:
invoicenum='" & txtinvoicenum & "'"
And invoicenum is a memo field? Why not a text field?
WScharlotte
WSarage
WSMarkLiquorman
WSMarkLiquorman
WSMarkLiquorman
AskWoody LoungerAugust 27, 2001 at 5:54 pm #539233‘find the record
rst.FindFirst strSearch
Forms!frmL60Tin!sfTin.SetFocus
DoCmd.RunCommand acCmdRecordsGoToNew
Forms!frmL60Tin!sfTin.Form!txtOp.SetFocusAssuming you put together your strSearch, then I think your problem is here. What is rst? I would do this:
set rst = me.recordsetclone
rst.findfirst strSearch
if rst.nomatch=false then
me.bookmark = rst.bookmark
end if
rst.close
set rst = nothing -
WSMarkLiquorman
AskWoody LoungerAugust 27, 2001 at 9:32 pm #539278I’ve gotten confused as to what you were trying to do. Going back, I see it was to move to a record on a subform. Therefore, you need to declare the recordset differently. You can’t use Me.REcordsetClone, as this is for the recordset on the mainform. You need to refer to the recordset in the subform; you do this via the subform control that is on the mainform (and not the actual subform name, although they may be the same). Let’s assume this control name is call subControl. You need this:
set rst = me!subControl.Form.recordsetclone
AFter that, everything is the same as I previously wrote.
WSMarkLiquorman
AskWoody LoungerAugust 28, 2001 at 4:52 pm #539464I think you have a sequencing problem. Your did your rst.FindFirst, which finds a record in the recordsetclone. But then you move focus to the subform, etc. However, positioning yourself in the recordsetclone doesn’t do anything by itself. YOu need to do the Me.book=rst.bookmark at this time, BEFORE you move focus to the subform!
Viewing 6 reply threads -
dmt_3904
8 minutes ago -
Are manuals extinct?
31 minutes ago -
7 hours, 35 minutes ago -
Network Issue
Casey H
14 hours, 7 minutes ago -
19 hours, 34 minutes ago -
20 hours, 1 minute ago -
Steve Bondy
21 hours, 56 minutes ago -
cyraxote
21 hours, 12 minutes ago -
1 day, 7 hours ago -
JP
1 hour, 2 minutes ago -
thymej
18 hours, 17 minutes ago -
Lance Whitney
13 hours, 27 minutes ago -
Spring cleanup — 2025
2 days ago -
Setting up Windows 11
19 hours, 47 minutes ago -
Powershell version?
1 day, 21 hours ago -
SendTom Toys
7 hours, 55 minutes ago -
Add shortcut to taskbar?
2 days, 1 hour ago -
2 days, 17 hours ago -
Help
2 days, 16 hours ago -
1 day, 23 hours ago -
We live in a simulation
3 days, 7 hours ago -
Netplwiz not working
2 days, 18 hours ago -
3 days, 19 hours ago -
21 hours, 47 minutes ago -
Downloads folder location
4 days, 2 hours ago -
2 days, 22 hours ago
