• Strange sound on shutdown
    I am running Windows 98SE and recently a strange sound has been occurring on shutdown. As soon as the monitor goes black, the PC emits beep-beep-beep-beep, pause, beep-beep-beep-beep, just the two phrases. This is a sound and tone I have never heard from the PC before. It is more like that of a small battery-operated alarm clock. This morning, for the first time, the same sound occurred when I switched the PC on for the day. Otherwise my computer seems to be behaving normally. Any clues as to what this might mean?
    • #987823
      What is the make and model of the computer? What you’re describing sounds very much like the system mainboard/BIOS giving you an alarm, but the beep codes vary by manufacturer and BIOS revision.
      Have you had any other symptoms that would give a clue as to what is going on?
      • #987867
        The PC was manufactured by TLSystems in New Zealand in February 1998. It has an ASUS LX PentiumII motherboard. There are no other symptoms. As I said in my earlier posting, “Otherwise my computer seems to be behaving normally.”
        • #987868
          I would then start researching here.
        • #988109
          What’s the model number & revision on the board? Asus made lots of different LX boards.
          • #988449
            All I can find printed printed on the motherboard is P2L97 and Rev. 1.05.
            • #991544
              I had this problem on an old P3 machine, it began when i altered the graphics card aperture, perhaps it is a DRAM error? it has never really effected the performance though so i just forget about it
    Reply To: Strange sound on shutdown
