Hi: I recently ran across a backup program called Bvckup2. I thought I would give it a try. After I installed it and made a backup I realized it was not what I was looking for (backs up files and folders, no image.) I uninstalled it found that two items remained in the backup folder. I receive the message “the file name or extension is too long. You can shorten the file name and try again, or try a location with a shorter path.” One is an entry within Firefox favorites for a company called MWave The second is a reference to the WinStore. One was originally in “Users-LG-AppData-Local-Packages-WinStore-etc” (which I deleted) and the other in “Users-Favorites-Shopping” area (which is not in the original location.) I can’t delete, edit, rename, move, take control of, or do anything else with these leftover entries left behind by BVCKUP.
This is not a critical problem as these entries take up virtually no space. I certainly won’t lose sleep if I can’t remove them. That said, I’m just wondering if someone has a suggestion as to how to remove these entries. Thank you.
