I am having a very weird problem. We just switched to MS2000 server for about 10 days without problems, but I am now having intermittent problems. We have a front end on local machines and a back end. 15 people max use the database. People will have errors when trying to input dates that have a form property or table -level format function. Sometimes they can click on the field and it will give an error saying “Function is not available in expressions in table-level expression”, which I take to mean the DB can’t validate something – but there are no validations except formatting the date. Strangely, if the person clicks in a different field and then tabs into the date field the date can be entered normally.
Also in a certain case an update query (with criteria) will not run, so a report cannot be generated (although the form being used is populated by several other queries putting info into a temporary table).
Another error people are getting is that a “project or library” is not available.
Some compters have the problem and some don’t. One did not have a problem and then later showed some of these problems. All are using the same front and back end.
Any ideas suggestions I go the the LAN people?
