• Speed of custom animations and transitions
    • This topic has 4 replies, 4 voices, and was last updated 24 years ago.
    This is a two-part questions.
    1. For a custom animation of an object, is there a way I can adjust the speed at which it happens. For example, if I wanted an object to spiral in, could I make it really slow.
    2. For slide transitions, the options are slow, medium and fast. Is there any way I can make the transition any speed I want.
    • #524114
      An answer to both questions:
      No, you cannot manualy set the speed buy a number
      • #524143
        Thanks for the reply. I thought not. I was just hoping that somebody knew a little trick I haven’t discovered. Would be nice to be able to do this, wouldn’t it?
    • #524254
      The other unfortunate part of this dilema is that the faster your processor and the more video memory you have (Read: The newer your computer) the worse this problem is. The above listed allows your PC to better handle graphics and therefor it can draw/display them more quickly.
      I wish you could set the time for the transition to last like you can set the time between auto-animation.
    Reply To: Speed of custom animations and transitions
