I thought I had this figured out somewhere on Page Setup, but it’s not in the document now and I can’t find out how I did it before. There’s a line at the bottom of the header (I don’t know how it got there because this isn’t my original) so if I just add a blank line at the bottom of the header it moves the line down and it’s still jammed up against the first line of text.
Also, how do I attach a template so it goes along with the document into someone else’s computer? I’m creating a .dot file for them. I see where I should tell them to “click Templates and Add-Ins on the Tools menu, and then clear the Automatically update document styles check box”. I found that in the Help, but I’m not sure WHEN they’re supposed to do that? Before they even try to open the document??
Hmm, maybe this is now a different question, but after I saved the .dot in a My Documents subfolder, I was NOT able to open a new document based on it. Even after I went to Tools/Templates and Add-ins to (try to) attach the template from that location. I don’t want to have to have it in the Word Templates folder because I want to send it to someone else to use on new documents. ???
