I bought a new Mecer a few weeks back and all is just great (Mecer agent loaded Win7 Pro) – except for the sound, when listening to a video online. Many of my webinars are streamed online and after a few minutes, the sound starts to deteriorate into, what can only be called, a scramble of squeaks, then silence. A CD seems to be fine – but when a video is being steamed online into my earphones – all sounds goes haywire after a few minutes. I tried toggling the earphone plug in the green slot on the front of the cpu and the sound is restored for a few seconds, as it seems to “connect” but then “disconnects” only to go weird again – then finally, all is silent, no matter what I do to the plug. Last time I toggled the plug, the( YouTube) video stopped and an error message came on stating that an error had occurred and that the settings were not supported by Chrome – which I was using. (New earphones did not help.) The Mecer agent is at a loss – as am I…….and my precious lectures are going un-listened to, which is a mess. Anyone have the same problem? :confused:
Sound scrambles after a while
Home » Forums » AskWoody support » Windows » Windows 7 » Questions: Windows 7 » Sound scrambles after a while
- This topic has 3 replies, 2 voices, and was last updated 8 years, 5 months ago.
Viewing 1 reply threadAuthorReplies-
Lugh
AskWoody_MVPSeptember 22, 2016 at 6:40 am #1578558The Mecer agent is at a loss – as am I
Mecer is a PC brand, right? A link to your specific model might help, so we can check the specs and components.
I have never experienced your problem, or heard of it before, so no wonder you both are at a loss. The symptoms suggest it’s probably a hardware problem, so the solution lies in narrowing it down until you identify the cause.
If you’re comfortable opening the PC’s case, check the cables going to the front panel–usually they’re small thin guys, and the little connectors on them could easily become partially dislodged. Best is if you have a manual which shows where all the cables are supposed to go, usually from the motherboard to the front panel.
You’ve already tried another set of earphones, so that’s not it.
Is there any other sound output on the PC, eg thru speakers or monitor? Does it work?
Any difference using another browser?Is there another green audio-out port on the back of the PC you can try?
The ‘wiggling’ symptoms you describe point to a bad front audio-out port.Confirm that you [or someone else] can hear the webinars without problems on another machine. That eliminates the video stream source as a problem.
What happens when you stream some other video+sound source, eg Netflix or similar?
Can you stream just sound, eg MP3?If last 2 answers are ‘goes bad’ and ‘yes’, that suggests some problem in the video+audio processing hardware. Probably chips on your motherboard–or do you have separate sound and/or graphics cards?
Lugh.
i7-7700; GeForce GTX 1060; 16GB DDR4 2400; 1TB SSD, 256GB SSD, 4TB HD -
Cheryl
AskWoody LoungerOctober 18, 2016 at 7:35 am #1581830Lugh – thanks so much for spending time on my hassle. I ended up taking it to a local technician, only to find the the front audio (green) plug in the cpu was broken. I came home and attached my earphones to the back inlet and so far, all is dandy. Some quality – a new machine is shipped with a broken plug!! But that said, all is well again and my CPD hours are being caught up again!!
Thanks, Lugh!!
Lugh
AskWoody_MVPOctober 23, 2016 at 1:13 am #1582479Great, glad to hear you got it sorted ๐
It happens, PCs are a pretty complex collection of fragile sensitive parts, with many millions of signals flying around every second between them all. I worked for a computer manufacturer for 6 years, so I think it’s great they work as well as they do!
Lugh.
i7-7700; GeForce GTX 1060; 16GB DDR4 2400; 1TB SSD, 256GB SSD, 4TB HDViewing 1 reply thread -
Looking for personal finance software with budgeting capabilities (Awaiting moderation)
cellsee6
2 hours, 32 minutes ago -
ATT/Yahoo Secure Mail Key
Lil88reb
6 hours, 56 minutes ago -
Devices with apps using sprotect.sys driver might stop responding
11 hours, 18 minutes ago -
Neowin – 20 times computers embarrassed themselves with public BSODs and goofups
EP
19 hours, 53 minutes ago -
Slow Down in Windows 10 performance after March 2025 updates ??
arbrich
5 hours, 18 minutes ago -
Mail from certain domains not delivered to my outlook.com address
pumphouse
4 hours, 15 minutes ago -
Is data that is in OneDrive also taking up space on my computer?
WShollis1818
14 hours, 55 minutes ago -
Nvidia just fixed an AMD Linux bug
50 years and counting
3 hours, 30 minutes ago -
Fix Bluetooth Device Failed to Delete in Windows Settings
Drcard:))
Licensing and pricing updates for on-premises server products coming July 2025
2 days, 17 hours ago -
Edge : Deprecating window.external.getHostEnvironmentValue()
Rethinking Extension Data Consent: Clarity, Consistency, and Control
OneNote and MS Word 365
2 days, 19 hours ago -
Ultimate Mac Buyers Guide 2025: Which Mac is Right For You?
Intel Unison support ends on Windows 11 in June
2 days, 20 hours ago -
April 2025 — still issues with AMD + 24H2
Kevin Jones
11 hours, 26 minutes ago -
Windows 11 Insider Preview build 26200.5518 released to DEV
3 days, 7 hours ago -
Windows 11 Insider Preview build 26120.3671 (24H2) released to BETA
Forcing(or trying to) save Local Documents to OneDrive
PateWilliam
3 days, 16 hours ago -
Hotpatch for Windows client now available (Enterprise)
3 days, 4 hours ago -
MS-DEFCON 2: Seven months and counting
2 days, 5 hours ago -
My 3 monitors go black & then the Taskbar is moved to center monitor
saturn2233
4 days, 1 hour ago -
Apple backports fixes
3 days, 8 hours ago -
Win 11 24H2 will not install
Michael1950
Advice to convert MBR to GPT and install Windows 11 Pro on unsupported PC
Andy M
23 hours, 30 minutes ago -
Photos from iPhone to Win 10 duplicating/reformatting to .mov
J9438
2 days, 14 hours ago -
Thunderbird in trouble. Here comes Thundermail
Get back ” Open With” in context menus
4 days, 16 hours ago -
Many AMD Ryzen 9800X3D on ASRock have died
3 days, 8 hours ago
