I recently upgraded to Win 10 from Win 7. All seemed to go well. However, now, each time I log in, I get a message that “Smart Audio Failed to Initialize”. I think this is a remnant of Win 7 and probably isn’t needed. I’ve searched the web for Smart Audio and it appears to be related to Win 7 & 8. Any suggestions on what to do to end the error message; or, if needed, how to get it re-installed?
Smart Audio Won’t Initialize
Home » Forums » AskWoody support » Windows » Windows 10 » Questions: Win10 » Smart Audio Won’t Initialize
- This topic has 6 replies, 3 voices, and was last updated 8 years, 7 months ago.
Viewing 5 reply threadsAuthorReplies-
AskWoody MVP -
WSYobil
AskWoody LoungerJuly 20, 2016 at 11:39 am #1570873That did the job. Thanks. Actually, there are two listings of it in the Task Manager. I disabled both; one wouldn’t do it. It is curious, however, that deleting it from the list of installed programs didn’t do it. Perhaps I need to find the executable file and delete those directories? I’m assuming that Win 10 doesn’t need it for anything. I just noticed that my ear phones don’t work. Maybe that is a separate issue.
WSCalimanco
WSYobil
AskWoody LoungerJuly 21, 2016 at 9:54 am #1570991As you’ve updated from W7, you should check for updated drivers. Some of the old ones may not be compatible with W10.
I was able to fix the earphone problem by deleting the driver and letting Win10 re-install it during re-boot. I selected “update” for another and it came back with the message that the installed driver was the best one. So, Is it best to check drivers one by one or is one of the driver managers available on the internet a good tool.
Actually, I am tempted to do a clean install of Win 10 due largely to unneeded win7 remnants. However, if I understand what I’m reading, a clean install would lack dvd/cd play and read/write ability. I have it now because of it being a win7 remnant, I think.
WSCalimanco
AskWoody LoungerJuly 21, 2016 at 11:37 am #1571049Driver Managers are a two edged sword – they can do more harm than good. They have been known to install the wrong version of a driver which can then brick the system. If you want to try one, SlimDrivers is one of the better ones and its free. The best way is to download drivers from from the manufacturers websites as then you know you are getting the correct version.
The ability to play DVDs was removed in W8, but installing the KLite Codec Pack will allow you to play them and a lot of other formats in WMP.
W10 will still burn disks. That hasn’t changedhttps://www.slimwareutilities.com/slimdrivers.php (Do not use the big green download button. You will get PUPs if you do.)
https://www.codecguide.com/download_kl.htm
Always check for bundled unwanted extras when downloading and installing any new software and be sure to decline them. Use custom install when it’s available.
WSYobil
AskWoody LoungerJuly 21, 2016 at 12:37 pm #1571052Calimanco,
Thanks for the tips and links. I’ve been suspicious of the driver managers anyway. Think I’ll avoid them unless I get into a real bind. I did read some stuff yesterday about the KLite Codec Pack, but wasn’t sure enough to pull the trigger on it. If I proceed with a clean install, I’ll certainly make use of that.Man! I hate those big green download arrows. These days you’ve got to read the sites very carefully in order to find the correct download button.
Thanks again.
Viewing 5 reply threads -
Finding Microsoft Office 2021 product key
35 minutes ago -
Over-the-Top solves it!
8 hours, 47 minutes ago -
To Susan – Woody Leonhard, the “Lionhearted”
Myst
15 hours, 48 minutes ago -
Extracting Data From All Sheets
WSJon5
17 hours, 24 minutes ago -
Use wushowhide in Windows 11 24H2?
17 hours, 32 minutes ago -
Hacktool:Win32/Winring0
Marvel Wars
4 hours, 13 minutes ago -
Microsoft Defender as Primary Security Question
blueboy714
1 hour, 53 minutes ago -
USB printers might print random text with the January 2025 preview update
20 hours, 2 minutes ago -
Google’s 10-year-old Chromecast is busted, but a fix is coming
Expand the taskbar?
Gregory Forrest “Woody” Leonhard (1951-2025)
26 minutes ago -
March 2025 updates are out
6 hours, 41 minutes ago -
Windows 11 Insider Preview build 26120.3380 released to DEV and BETA
1 day, 23 hours ago -
Update Firefox to prevent add-ons issues from root certificate expiration
Latest Firefox requires Password on start up
Gordski
2 days ago -
Resolved : AutoCAD 2022 might not open after updating to 24H2
2 days, 19 hours ago -
Missing api-ms-win-core-libraryloader-11-2-1.dll
IreneLinda
1 day, 17 hours ago -
How Much Daylight have YOU Saved?
A brief history of Windows Settings
Simon Bisson
Thunderbolt is not just for monitors
Ben Myers
Password Generators — Your first line of defense
AskWoody at the computer museum
18 hours, 28 minutes ago -
Planning for the unexpected
Which printer type is the better one to buy?
Bob99
2 days, 20 hours ago -
Upgrading the web server
New Windows 11 24H2 Setup – Initial Win Update prevention settings?
3 days, 14 hours ago -
Creating a Google account
DavidofIN
3 days, 13 hours ago -
Undocumented “backdoor” found in Bluetooth chip used by a billion devices
3 days, 19 hours ago -
Microsoft Considering AI Models to Replace OpenAI’s in Copilot
4 days, 6 hours ago -
AI *emergent misalignment*
4 days, 7 hours ago
