Hi
I’m going mad here. My HTML file contains this:
<td class=
Home » Forums » Developers, developers, developers » Web design and development » Small caps won’t work
You’re in the correct forum… it’s CSS, and that’s decidedly a web design thing.
It’s possible that your chosen font does not support small caps, although I’ve never heard of such a thing. Have you tried alternate fonts to see if they render properly? And which browser platforms have you tested this in/on?
Hi Mark
Yes, I’m getting the same results. Curiously (apparently) identical code is working in other documents, which proves it’s not the platform and (I think) not the font. But obviously there IS a difference.
During the weekend (it’s nearly 5pm on a Friday here in New Zealand) I’ll try stripping one of the “working” documents down to the bare essentials and see if I can get to the bottom of it.
PS: I just discover that inadvertently clicking the Escape key deletes everything you’ve patiently entered into the WOPR message box. It’s definitely Friday.
Dale
Dale
Late in the day, but time zones have got in the way, you can do it this way:
small caps with css |
small caps without css |
using this as your style sheet:
td{ font-family : “Arial, Helvetica, sans-serif”;}
td.caps {
font-variant: small-caps
Obviously use the names you prefer but these are my preferred shortened descriptors.
Notifications
