• SendObject Problem – Help! (MSAccess 2000 (SR1))
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » SendObject Problem – Help! (MSAccess 2000 (SR1))
    I am using SendObject to generate an email based on the contents of the current record. This works fine for the first email generated. However, when trying to generate an additional email from either the same or different record it fails to do anything. I have to close the database then reopen before the SendObject command will work again … any suggestions.
    Reply To: SendObject Problem – Help! (MSAccess 2000 (SR1))
