• Security problem driving me crazy (97 SR-1)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Security problem driving me crazy (97 SR-1)
    Hi All
    the application has tables named tblPalmUserSubscriptions in the frontend and backend. Owner of both tables is Admin. Permissions set wide-open for all users. I can browse either frontend or backend table by double-clicking in the Database Window. But the following code returns Error 3112 – No Read permissions.
    Sub test()
    Dim rs As DAO.Recordset
    Set rs = CurrentDb.OpenRecordset(“tblPalmUserSubscriptions”, , dbOpenDynaset)
    I can replace the tablename with any of the three tables in the backend and get the same result. Try the same experiment with linked tables from other backend databases, and they work properly.
    I have triple-checked the permission, rebuilt the tables and database numerous times, checked and changed ownership of the database and objects. At one point, I tried to rename the table and was warned that I didn’t have sufficient permission, yet 10 seconds later I was able to alter the database design.
    What am I overlooking?
    Any help gratefully accepted.
    • #567352
      You have misplaced dbOpenDynaset in your OpenRecordset stmt. It should be the 2nd parameter. dbOpenDynaset is a constant with a value of 2, which is also the value of dbDenyRead. Hence, no read permission.
      • #567473
        Thanks for the tip — getting it correct did not fix the problem. Deleting the frontend links and rebuilding them got it working properly. Copy the frontend from one computer to another, and the links needed to be rebuilt. Strange…
    Reply To: Security problem driving me crazy (97 SR-1)
