When I try to save a jpeg off the net I can only save it as “all files”. I don’t get a choice anymore.
What happened??
Lennymay
saving problem
Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » saving problem
- This topic has 7 replies, 2 voices, and was last updated 23 years, 4 months ago.
AuthorTopicWSLennymay
AskWoody LoungerDecember 6, 2001 at 5:54 pm #363838Viewing 0 reply threadsAuthorReplies-
WSLeif
WSLennymay
WSLeif
WSLennymay
WSLeif
AskWoody LoungerDecember 10, 2001 at 11:13 am #557141Are you selecting Save As or Save Image ?????
With the example above, I get the choice shown below.
Yes – it does describe the type as ‘All Files’, but it does save it as a .jpg.I went through the process and it saved the example as ‘aktivlogo.jpg’
Are you saying that even with ‘Save Image’ you end up with a file with no extension?
Or are you saying it saves the image as ‘filename.jpg’ and you THEN have to select which program will open the .jpg? -
WSLennymay
WSLeif
AskWoody LoungerDecember 11, 2001 at 11:19 am #557431
Viewing 0 reply threads -
Windows 11 Insider Preview build 26200.5562 released to DEV
1 hour, 49 minutes ago -
Windows 11 Insider Preview build 26120.3872 (24H2) released to BETA
1 hour, 50 minutes ago -
Unable to eject external hard drives
Robertos42
1 hour, 27 minutes ago -
Saying goodbye to not-so-great technology
5 hours ago -
Tech I don’t miss, and some I do
1 hour, 56 minutes ago -
Synology limits hard drives
Links from Microsoft 365 and from WhatsApp not working
rog7
8 hours, 28 minutes ago -
WhatsApp Security Advisories CVE-2025-30401
Upgrade Sequence
doneager
Chrome extensions with 6 million installs have hidden tracking code
Uninstall “New Outlook” before installing 2024 Home & Business?
4 hours, 16 minutes ago -
The incredible shrinking desktop icons
Thumper
2 days, 9 hours ago -
Windows 11 Insider Preview Build 22635.520 (23H2) released to BETA
2 days, 10 hours ago -
Connecting hard drive on USB 3.2 freezes File Explorer & Disk Management
WSJMGatehouse
Shellbag Analyser & Cleaner Update
19 hours, 50 minutes ago -
CISA warns of increased breach risks following Oracle Cloud leak
2 days, 19 hours ago -
Outlook 2024 two sent from email addresses
2 days ago -
Speeding up 11’s search
8 hours, 18 minutes ago -
HP Pavilion Will Not Wake Up After Being Idle for Longer Period
WSwalterwood44
20 hours, 15 minutes ago -
Make a Windows 11 Local Account Passwordless
Drcard:))
3 days, 10 hours ago -
Ubuntu 25.04 (Plucky Puffin)
3 days, 17 hours ago -
24H2 fixed??
Uninstalr Updates
jv16
3 days, 22 hours ago -
Apple zero days for April
3 days, 3 hours ago -
CVE program gets last-minute funding from CISA – and maybe a new home
2 days, 20 hours ago -
Whistleblower describes DOGE IT dept rumpus at America’s labor watchdog
4 days, 21 hours ago -
Seeing BSOD’s on 24H2?
4 days, 4 hours ago -
TUT For Private Llama LLM, Local Installation and Isolated from the Internet.
4 days, 11 hours ago -
Upgrade from Windows 10 to 11
Holdsworth8
5 days, 6 hours ago -
Microsoft : AI-powered deception: Emerging fraud threats and countermeasures
5 days, 8 hours ago
