SAVE AS with help of text box
I
SAVE AS with help of text box (97)
Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » SAVE AS with help of text box (97)
- This topic has 5 replies, 4 voices, and was last updated 22 years, 10 months ago.
AuthorTopicViewing 2 reply threadsAuthorReplies-
WSWassim
AskWoody LoungerJune 4, 2002 at 7:56 pm #592264arage
I like “is this possible” kind of questions.
Yes it is possible. Check the Inputbox in the OLH.
It says that you can have the following parts: InputBox(prompt[, title] [, default] [, xpos] [, ypos] [, helpfile, context])
So you can use the Default section to populate the Inputbox. BUT You should also write some VBA code to move the cursor to the end of the line, so that you can start typing.
I do have an example, but try it first on your own, until I dig out the example. Its going to take me about 3 weeks to dig it out. I am reorganizing my files and now most of them are on Zip disks.
Good luck.
Wassim
WSarage
WSsmerdonk
AskWoody LoungerJune 4, 2002 at 7:57 pm #592261Try this:
Sub Button1_Click()
‘Copies the workbook to a separate file
Dim FileName As String
Dim thePaththePath = “C:YourDirectoryHere” ‘ That last ” is important
FileName = “New File ” & Format(Date, “mm-dd-yyyy”) ‘Suggested FilenameApplication.Dialogs(xlDialogSaveAs).Show thePath & FileName ‘ Save As box
Application.DisplayAlerts = False ‘—–=====—–
ActiveWorkbook.Close ‘ Comment these out to leave the new file open
Application.DisplayAlerts = True ‘—–=====—–
End Sub -
WSarage
WSpieterse
AskWoody LoungerJune 5, 2002 at 4:58 am #592348Saving a copy of the current workbook without changing its name can be done using the savecopyas method:
Sub wkbkSaveAsCopy()
Dim vFilename As Variant ‘will hold the filename entered
Dim sOldDrive As String
Dim sOldDir As String
sOldDrive = Left(CurDir, 1)
sOldDir = CurDir
ChDrive “c”
ChDir “c:data”
vFilename = Application.GetSaveAsFilename(“YourDefaultFileName ” & Format(Now, “dd-mm-yyyy”), , , “Please enter a filename”)
If TypeName(vFilename) = “Boolean” Then GoTo tidyup ‘cancelled
If vFilename = “” Then GoTo tidyup ‘nothing entered
ActiveWorkbook.SaveCopyAs vFilename
tidyup:
ChDrive sOldDrive
ChDir sOldDir
Viewing 2 reply threads -
Download speeds only 0.3Mbps after 24H2 upgrade on WiFi and Ethernet
John
4 hours, 23 minutes ago -
T-Mobile 5G Wireless Internet
WSmmi16
3 hours, 23 minutes ago -
Clock missing above calendar in Windows 10
WSCape Sand
1 hour, 47 minutes ago -
Formula to Calculate Q1, Q2, Q3, or Q4 of the Year?
WSJon5
2 hours, 30 minutes ago -
The time has come for AI-generated art
Catherine Barrett
17 hours, 11 minutes ago -
Hackers are using two-factor authentication to infect you
11 hours, 12 minutes ago -
23 and you
Max Stul Oppenheimer
17 hours, 13 minutes ago -
April’s deluge of patches
3 hours, 40 minutes ago -
Windows 11 Windows Updater question
9 hours, 26 minutes ago -
Key, Key, my kingdom for a Key!
Registry Patches for Windows 10
Drcard:))
Cannot get line length to NOT wrap in Outlining in Word 365
19 hours, 24 minutes ago -
DDU (Display Driver Uninstaller) updates
4 hours, 43 minutes ago -
Align objects on a OneNote page
OneNote Send To button?
WU help needed with “Some settings are managed by your organization”
Peobody
2 days, 3 hours ago -
No Newsletters since 27 January
rog7
8 hours, 10 minutes ago -
Linux Mint Debian Edition 7 gets OEM support, death of Ubuntu-based Mint ?
Windows Update “Areca Technology Corporation – System – 6.20.0.41”
Bruce
Google One Storage Questions
LHiggins
10 hours, 46 minutes ago -
Button Missing for Automatic Apps Updates
pmcjr6142
18 hours, 2 minutes ago -
Ancient SSD thinks it’s new
WSila
Washington State lab testing provider exposed health data of 1.6 million people
2 days, 18 hours ago -
WinRE KB5057589 fake out
4 hours, 59 minutes ago -
The April 2025 Windows RE update might show as unsuccessful in Windows Update
2 days, 2 hours ago -
Firefox 137
Charlie
4 hours, 57 minutes ago -
Whisky, a popular Wine frontend for Mac gamers, is no more
3 days, 6 hours ago -
Windows 11 Insider Preview build 26120.3863 (24H2) released to BETA
Windows 11 Insider Preview build 26200.5551 released to DEV
3 days, 7 hours ago -
New Windows 11 PC setup — can I start over in the middle to set up a local id?
ctRanger
2 days, 2 hours ago
