Hello!
I wasn’t quite sure where to post this question – hope this will get some replies.
My internet is provided using an Inseego M2000 MiFi hotspot device through T-Mo (no internet where I live). I’ve had this device for about 3 years and it is out of warranty. Works great! It came with a rechargeable and replaceable battery with these specs:
3.85V 5050mAh (Typ) 19.44Wh – and looks like this.
I have a few questions about a replacement battery and charging. Before it was out of warranty, it seemed to be having some charging issues, so Inseego sent me a new charger, cable, and battery – same specs as original. Turns out the charger was the issue and I never used the new battery.
Now I am thinking that I would like to charge it and have it as a spare battery, but I have a few questions. I tried to get Inseego’s help, but they aren’t being very helpful, so I thought maybe someone here could give me some feedback?
I turned off the MiFi, put the new battery in and plugged it in, but after the first MIFI screen blinked, the display went black and I couldn’t get it to show me whether it was charging or not. It just appeared to be dead. It wouldn’t turn on and it didn’t seem to take a charge when I left it plugged in for a time.
Even when my current battery is very low, even at say 2%, it will still allow for it to charge while I use it and will show that it is charging when I charge it when the device it turned off. Why would the new one not do that?
When I first got that replacement from Inseego, they said to charge it overnight at first, which I haven’t done, mainly because I am concerned that something may happen to the device itself while charging for that long, if there is an issue with the battery. Since that is my only internet, I didn’t want to risk it.
So – is it possible that trying to charge that probably dead battery could cause a problem with my device?
Should I consider buying a new replacement battery – or would its initial charge possibly do the same thing as this one?
What is the difference between the specs I have, above, and one that has these:
3.85V 3500mAh 13.48Wh – and looks like this.
When I look for a replacement, I also find one with those specs – would that work as well, and what is the difference? Some reviewers say the one that is 505mAh doesn’t fit the M2000, but that is the one that I currently have, which does fit.
Any other suggestions, advice welcome.
Thanks for the help!
LH
