PC turned off today twice. I noticed it was running warm just by touch. I opened it up (1st time since new, 2 years) Vacuumed it out and then plugged it in to check fan and all appeared proper. Anybody using a heat monitoring application. Something simple/frree.
Recommend heat monitor?
Home » Forums » AskWoody support » PC hardware » Questions – Maintenance and backups » Recommend heat monitor?
- This topic has 18 replies, 9 voices, and was last updated 11 years, 11 months ago.
AuthorTopicWSNot Brightest Bulb
AskWoody LoungerApril 29, 2013 at 7:43 pm #488988Viewing 11 reply threadsAuthorReplies-
satrow
AskWoody MVP -
WSCLiNT
AskWoody LoungerApril 29, 2013 at 10:29 pm #1389634HWMonitor here as well, it’s free and utilizes many, if not all, onboard sensors.
The more sophisticated your motherboard, the more monitoring sensors you’ll have, irrigardless of the specific monitoring app you’ve installed. (usually)A few other tips & solutions to a hot running PC;
Cleaning the dust and grime out on a regular basis is a standard must do, but if after doing so, you still find your running hot…Try to locate exactly where you’re running high temps. Sometimes it will be a simple matter of installing a fan on the Northbridge sink.
Other times you may need to reseat a heatsink with new thermal paste, or even an upgraded after-market CPU fan & sink.It will all depend upon where your running hot, so try to pinpoint specific internal locations, by both monitoring tool and by direct observation and touch.
If you have a hot GPU card that dumps heat inside the case, you’ll need to look into fan/ventilation solutions that more adequately deal
with removing excess internal case heat. Anything more than 50 C [idle] is usually a bit too much. -
BATcher
AskWoody_MVPApril 29, 2013 at 11:46 pm #1389640 -
WSCLiNT
AskWoody LoungerApril 30, 2013 at 12:05 am #1389643Yeah, Dell is extremely limited, but they (MB sensors) are there to some extent, even on the desktop models.
The majority of your temp monitoring tools are geared more to the enthusiast MB market, like Asus and others, and less so to the generic boards
that Dell puts out. But if you have a higher end Dell gaming rig, you’ll most certainly have the sensor capabilities. It just depends on the model in many instances. -
WSgeorgelee
AskWoody LoungerMay 10, 2013 at 8:51 am #1391160Yeah, Dell is extremely limited, but they (MB sensors) are there to some extent, even on the desktop models.
that Dell puts out. But if you have a higher end Dell gaming rig, you’ll most certainly have the sensor capabilities. It just depends on the model in many instances.I have read before that Dell computers are somewhat lacking in heat sensors and other diagnostic tools. As all our PCs have been Dell, and my aging XP machine needs replacing soon, any suggestions as to a better brand to get as next would be welcome. Apologies for being somewhat off topic, just that this thread reminded me of something to look for in the new desktop.
satrow
AskWoody MVP -
AskWoody LoungerApril 30, 2013 at 7:38 am #1389663Well as my username suggests, not to smart as I have SIW but very seldom opened it. Yes indeed it does have a sensors heat info.
I downloaded HWmonitor yesterday and it had a weird glitch. I download all things to a USB drive and I did the install but when done I wanted to move the download to a folder on C: drive where I move all downloads of applications after installed. This rascal would not allow such a move so I ended up uninstalling it.
The good news so far is that after doing the vacuum clean inside PC all is running as it should (so far) “My bad” because it was purchased new 5/11 and not touched because I follow the “if it’s not broke don’t fix it” program. Reason being usually when I get done fixing something I have abused something else. Kind of a one step forward, 2 steps backward program.
satrow
AskWoody MVP -
AskWoody LoungerMay 1, 2013 at 4:58 pm #1389835Excellent, perhaps it, or the installer, was still running in the background yesterday, that would account for you not being able to movee it from the USB. Whatever, I’m pleased you have it working correctly now.
Makes sense maybe next time I will just reboot before I uninstall Geeze I amaze myself at how stupid I can be,
course I woirk hard at it.
WSWNC-User
AskWoody LoungerMay 2, 2013 at 11:16 am #1389920The free one I use that gives you more info than most folks need but has a nice graphical interface with green/red warnings is Piriform’s Speccy:
They’re the folks that also have CCleaner.
Jim
WSgumintwork
WSmpioso
AskWoody LoungerMay 2, 2013 at 10:20 pm #1389979You will find that most of these to NOT give accurate temp readings but do provide relative warning indications. To be clear, use an good, accurate infrared temp probe or surface contact type to determine your specific temps of your CPU sink which will be very close to core temp if the compound is solid and then correlate. Measure your hard disk drives as well just to be sure as heat destroys the bearing grease/lube if too high. Exhaust temps from the ps fan give you a good indication of its workload as well. Cheers.
WSCLiNT
AskWoody LoungerMay 10, 2013 at 11:44 am #1391193I’ve built the last two computers I’ve owned, so one can pick and choose the board and components one wants
over what some manufacturer has on offer at that particular time.Higher end systems will usually always have an abundance of sensors for fans, temps, and others, in more locations than
lower end systems. I think you’ll find that pretty much all of your lower end systems will have these limitations.So before you purchase a new computer from a manufacturer, always do in depth research. Get MB spec sheets and pour
over them likes there’s no tomorrow. The last thing you want in a pricy purchase are surprises.
Even if your not looking to get a higher end system, always do your research. Knowing proc and memory speed may not be enough.There are also aftermarket solutions like fan controllers and temp sensors with LED readouts.
Then there is the temp gun which can be pretty decent.33913-zzz
As you can see from some of my temps, they’re not always accurate.
Sometimes the best way to get an idea of the REAL temps is to get your fingers in there and feel it.
128 C is uncomfortably hot, you won’t miss it. -
WSgeorgelee
AskWoody LoungerMay 10, 2013 at 5:24 pm #1391318Thanks Clint, I reckon you have answered the question convincingly – I might as well buy another Dell.
There’s no way I’m going to build a PC myself, I wouldn’t know what to buy or where to start, and it would have to be twice the size of either of the desktops I have opened – even adding ram is difficult for my fingers in the confined space of a Dell desktop.
A high end system would be out of place for my fairly basic needs, and it sounds as though all cheaper desktops are fairly similar, so I don’t need to bother too much about what I get.
George
WSbrino
AskWoody LoungerMay 18, 2013 at 8:55 pm #1392656Hey guys, HWMonitor shows a “hit” on Virustotal
https://www.virustotal.com/en/file/d3b6e35c03338e79ff566c67d7547ac26630379e0ce39e9dd8aefe63a78a1ce7/analysis/
showing up as “a variant of Win32/Bundled.Toolbar.Ask.C”
Do you get a chance to say no to that during install? -
satrow
Viewing 11 reply threads -
inetpub : Microsoft’s patch for CVE-2025–21204 introduces vulnerability
4 hours, 20 minutes ago -
Windows 10 finally gets fix
13 hours, 13 minutes ago -
AMD Ryzen™ Chipset Driver Release Notes 7.04.09.545
14 hours, 33 minutes ago -
Win 7 MS Essentials suddenly not showing number of items scanned.
Oldtimer
9 hours, 6 minutes ago -
France : A law requiring messaging apps to implement a backdoor ..
Dev runs Windows 11 ARM on an iPad Air M2
MS-DEFCON 3: Cleanup time
1 hour, 4 minutes ago -
KB5056686 (.NET v8.0.15) Delivered Twice in April 2025
lmacri
23 hours, 51 minutes ago -
How to enable Extended Security Maintenance on Ubuntu 20.04 LTS before it dies
Windows 11 Insider Preview build 26200.5562 released to DEV
Windows 11 Insider Preview build 26120.3872 (24H2) released to BETA
Unable to eject external hard drives
Robertos42
6 hours, 10 minutes ago -
Saying goodbye to not-so-great technology
3 minutes ago -
Tech I don’t miss, and some I do
38 minutes ago -
Synology limits hard drives
2 days, 23 hours ago -
Links from Microsoft 365 and from WhatsApp not working
rog7
2 days, 2 hours ago -
WhatsApp Security Advisories CVE-2025-30401
3 days, 5 hours ago -
Upgrade Sequence
doneager
Chrome extensions with 6 million installs have hidden tracking code
Uninstall “New Outlook” before installing 2024 Home & Business?
1 day, 22 hours ago -
The incredible shrinking desktop icons
Thumper
4 days, 3 hours ago -
Windows 11 Insider Preview Build 22635.5240 (23H2) released to BETA
4 days, 4 hours ago -
Connecting hard drive on USB 3.2 freezes File Explorer & Disk Management
WSJMGatehouse
Shellbag Analyser & Cleaner Update
21 hours, 7 minutes ago -
CISA warns of increased breach risks following Oracle Cloud leak
4 days, 13 hours ago -
Outlook 2024 two sent from email addresses
1 hour, 9 minutes ago -
Speeding up 11’s search
HP Pavilion Will Not Wake Up After Being Idle for Longer Period
WSwalterwood44
2 days, 14 hours ago -
Make a Windows 11 Local Account Passwordless
Drcard:))
5 days, 3 hours ago -
Ubuntu 25.04 (Plucky Puffin)
5 days, 11 hours ago
