Hello,
I have a question about the meaning of the power requirements for two T-Mo internet gateways I am looking at to hopefully get the right UPS battery backup.
I have a Nokia 5G21 gateway that is rated at 12V2A and have been using a Shanqiu battery backup that can power that device correctly – has 12V2a connections.
That gateway has been having some connection and speed issues of late – unclear if it is TMo or the gateway, so TMo is sending me a different one to try, a 5G Gateway G4SE that is rated as 100 – 240V, 3A @ DC 15V, 50/60Hz. The Shanqiu backup won’t work as it is only 12V and this new gateway needs 15V.
I haven’t been able to find a battery backup that is both 15v and 3A. I did find one, a TalentCell Mini UPS Uninterrupted Power Supply at Amazon that is 15V, but only 1.5A.
My questions – might that work in a power outage for several hours even if it isn’t 3A? What is the drawback or possible warning for using a device that is rated at fewer amps than needed? Will it cause damage to the Gateway or will it just run more slowly? Or something else?
I am not even sure if the replacement Gateway will work any better than the one I have now – it may be a TMo issue and not the Gateway at all – overloaded towers, etc. I am just looking ahead to see if I can find the correct battery backup to keep that device running for several hours in a power outage.
Thanks for any help anyone might have!
