When I try to publish to the web with Front Page, I receive the following:
“The server sent a response which Front Page could not parse. If you are trying to connect to a Front Page server, check with the server’s administrator to make sure the Front Page server extensions are installed properly.”
When checking with the administrator, he confirms that the extensions are properly installed.
He was able to publish to the site from his computer.
I believe that the web site is using Front Page 2000.
Is there some setting with my Front Page that I’m missing.
I AM able to publish to two other sites without any problems.
I’ve been working around this problem by using ws_ftp, but it’s a lot easier just to click the button in Front Page.
