• Project linking to Powerpoint (Project 2003)
    Home » Forums » AskWoody support » Productivity software by function » Other MS apps » Project linking to Powerpoint (Project 2003)
    Hi,
    Has anybody come across somethng that will allow youto dump a MS Project gnatt chart into a Powerpoint slide easily.
    Mike
    • #1030191
      It is very hard just to find enough screen for a single Gantt Chart. You have a copy picture button in your toolbar that will give a snapshot of what you see on your screen. Copy picture usually does not work well if your version of office is different than your version of Project. I usually use a print screen if I want a Gantt Chart image. You can also print to a .pdf file. Some versions of Project only let you print to the default printer so you have to make the Adobe printer the default before you try to print the file.
      Carla
    Reply To: Project linking to Powerpoint (Project 2003)
