Hi,
I have an IBM Net Vista PC that has been given to us (as a donation of old IT equipment to a ‘worthy cause’). It had no operating system on it, and I have been trying to load Windows 2000.
I have started with the four disk boot set, and then use the CD. After the restart is when the problems begin.
I go past the starting Windows 2000 screen from which I can select Safe Mode. In the following screen, where there is no longer the safe mode option – but the screen is still black and white, the progress meter goes the whole distance to the right hand side of the screen. The next thing is the little ‘pst’ sound of a restart and the whole sequence starts again.
I can press F8 and go to the safe mode menu, but they are onot of much value as the operating system installation has not completed.
Is there something easy?
