For the past few weeks, every time I boot my computer, it prompts me to run chk/dsk on my F: drive. The first few boots I did, but the prompt never stopped coming up. Lately I’ve just skipped it & gone on. This wouldn’t bother me so much except that I can’t defrag that drive, as it tells me I need to run chk/dsk. All three drives show “Healthy” in “Administrative Tools”. Other than that, the thing runs great. Anyone have any guesses?
Problems with CHKDSK
Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » Problems with CHKDSK
- This topic has 8 replies, 7 voices, and was last updated 13 years, 11 months ago.
AuthorTopicWSbushwack
AskWoody LoungerMay 12, 2011 at 12:41 pm #476580Viewing 2 reply threadsAuthorReplies-
WSDoc Brown
WSbushwack
AskWoody LoungerMay 16, 2011 at 11:22 am #1279622Did you just run chkdsk? Or chkdsk /f ? Chkdsk by itself just reports errors. Chkdsk with the /f switch repairs the corruption.
This is something that just popped up, on it’s own. It kinda reminds me of Windows98. The screen comes up & if I go ahead & let it run, the results aren’t up long enough to read.
WSCLiNT
WSbushwack
AskWoody LoungerMay 16, 2011 at 11:25 am #1279623Try running a more thorough checkdisk by using the “r” switch, and do it from the dos command line of a http://www.bootdisk.com/“]boot disk [/url].
Sorry, you’re talking way over my head. I can put a computer together & install an operating system, beyond that I’m pretty illiterate.
WSDeadeye81
AskWoody LoungerMay 16, 2011 at 2:52 pm #1279650Hi bushwack,
If you own an XP installation disk, you can boot to it and watch for the option to run the Recovery Console. Within the Recovery Console, you can run the checkdisk ‘r’ switch Clint referred to by typing ‘chkdsk /r’ without the quote marks, but note the space in front of the ‘/’ mark.
The /r option will take longer to run, but is more thorough than the /f option.If you do not have an XP installation disk, Bleeping Computer has a suggested download to create a Recovery Console CD.
WShercules550
AskWoody LoungerMay 19, 2011 at 8:52 am #1280003Start – Run – CMD – chkdsk /? (will show all options)
Decide on appropriate option(s) (e.g. /f, /r, etc.)Type, depending on option(s) decided, chkdsk (drive letter): /(option1) /(option2) – without parentheses! example: chkdsk c: /f /r
Message will appear if drive is in use, asking whether you want to perform the task at next boot. Answer yes, type exit (to exit command mode) and reboot. chkdsk will run on the specified partition with the options which you have specified.
WSScreen_Name
AskWoody LoungerMay 19, 2011 at 11:38 am #1280051I found the following link:
http://www.computing.net/answers/windows-xp/how-to-stop-chkdsk-at-startup/154355.html
There are also a couple of links on that page if that page doesn’t help you.
Regards…..
WSjaydeee
Viewing 2 reply threads -
Two blank icons
CR2
5 hours, 5 minutes ago -
ThePhoenix
7 hours, 29 minutes ago -
End of 10
10 hours, 10 minutes ago -
End Of 10 : Move to Linux
10 hours, 39 minutes ago -
Bruce
7 hours, 8 minutes ago -
test post
gtd12345
16 hours, 11 minutes ago -
Privacy and the Real ID
6 hours, 18 minutes ago -
7 hours, 7 minutes ago -
Cant log on to oldergeeks.Com
WSJonharnew
20 hours, 32 minutes ago -
Upgrading from Win 10
WSjcgc50
7 hours, 56 minutes ago -
WSlloydkuhnle
15 hours, 38 minutes ago -
The story of Windows Longhorn
23 hours, 56 minutes ago -
dmt_3904
Are manuals extinct?
1 hour, 38 minutes ago -
1 day, 23 hours ago -
Network Issue
Casey H
2 days, 11 hours ago -
Steve Bondy
2 days, 13 hours ago -
cyraxote
2 days, 15 hours ago -
2 days, 23 hours ago -
JP
thymej
3 days, 10 hours ago -
17 hours, 59 minutes ago -
Lance Whitney
Spring cleanup — 2025
3 days, 16 hours ago -
Setting up Windows 11
