G’Day,
I used the command xcopy C:*.* D:/c/h/e/k/r to make a copy of a hard drive (which is running Win 98) and put it in another computer, the original drive is 6 Gb and the clone is 20 Gb. Before doing this I formatted the D: drive and used scandisk, the second hard drive was also set up as a slave and then switched to master when I put it in the other computer. I know there will be issues with drivers and such but the computer with the cloned drive won’t start. During start up it detects the drive properly and all is right with the BIOS (I think) but it comes up with an A prompt and it says something like “Enter command interrupter (ie. c:windowscommand.com)” If I try to switch to C: drive the same message appears with the A prompt.
Have I misunderstood what xcopy is capable of or have I missed a step (or two)?
Thanks in advance for any help that any of you can provide.
Problem with XCOPY
- This topic has 8 replies, 5 voices, and was last updated 20 years, 2 months ago.
AuthorViewing 1 reply threadAuthorViewing 1 reply thread
