• Problem with SYMEvent
    When I select MS-DOS Prompt, sometimes I get the following message:
    This program has performed an illegal operation and will be terminated.
    Quit all programs, and then restart your computer.
    If the program consistently encounters problems, click the Start button, then select Help, Troubleshooting, and
    • #562892
      John, you need to download the latest version of SymEvent from Symantec’s website. It’s a self installing EXE file – just double click, wait till it’s finished, and reboot.
      SymEvent is a low-level system hook that Symantec products use to monitor system activity – notably Norton Antivirus and pcAnywhere.
      • #564184
        Hi Mark
        This seem to fix my problem, problem was intermittent, time will tell.
        Was my symptom a known problem?
        The web site did not explain what this update was fixing.
        Thanks again, John
        • #564213
          I’m not sure if it was a known issue or not, quite frankly – what I remember is having the exact same problem, and determining that updating SymEvent was the cure. If I recall correctly there was no mention of it in Symantec’s online support docs.
          What the update does is to replace a file called symevent(.sys, .386) which serves Symantec products such as pcAnywhere with a hook into Windows, allowing them to monitor what is happening. Since it interacts at such a low level with Windows, when it goes belly up as it did with you, you start having a miscellaneous assortment of problems. All I can say is thank goodness it’s not a problem for you anymore!
    Reply To: Problem with SYMEvent
