• Problem With Shell Command? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Problem With Shell Command? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
    This command works at the command line and removes Streets and any sub direcrories
    rd “F:PropertiesStreets” /s /q
    I’m trying to run this command in VBA and getting rte 53 file not found on the following:
    Call Shell(stAppName, 1)
    Contents of stAppName is “rd F:PropertiesStreets /s /q”
    What is the proper syntax?
    Thanks, John
    Sub Remove_Property_Folders()
        ChDrive "F"             ' Make "F" the current drive.
        ChDir "F:Properties"     ' Change current directory or folder
        Dim stAppName As String
        stAppName = "rd F:PropertiesStreets /s /q"    'rd "F:PropertiesStreets" /s /q
        MkDir "Streets"         ' Make current directory or folder
    • #1082827
      rd is not an executable. Use this:
      stAppName = "cmd /c rd F:PropertiesStreets /s /q"
      cmd is the command processor cmd.exe.
      • #1082845
        Fantastic!
        The only way the following works is with msgbox bewteen calls. I think I have a timing issue.
        The folder is removed but not created without the msgbox
        Is there a way to do this without msgbox?
        Thanks, John
        Sub Remove_Make_Properties_Streets_Folders()
            Call Remove_Properties_Streets_Folders
            MsgBox "PropertiesStreets Removed"
            Call Make_Properties_Streest_Folder
        • #1082847
          You could try inserting a
          DoEvents
          or two.
          • #1082851
            10 DoEvents didn’t get it, the following seems to work:
            Thanks, John
                Dim I, OpenForms
                For I = 1 To 150000    ' Start loop.
                    If I Mod 1000 = 0 Then     ' If loop has repeated 1000 times.
                        OpenForms = DoEvents    ' Yield to operating system.
                Next I    ' Increment loop counter.
    Reply To: Problem With Shell Command? (a2k (9.0.6926) SP-3 Jet 4.0 SP-8)
