• Problem with responding to “Save As” dialog box
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Problem with responding to “Save As” dialog box
    Hi
    In VBA, I am saving a CSV file as an xls file before I process the data in it. After processing, I re-save the file to capture the changes. Now I get the “Save As” dialog box asking me if I want to replace the already saved file. If I choose “Yes” all is well. If I choose either “No” or “Cancel” it crashes.
    How can I work this out becuase there maybe times I’d rather not save the changes.
    Thanks!
    Rick
    Viewing 7 reply threads
    • #1279741
      What exactly do you mean by “it crashes”?
      Steve
    • #1279750
      Sorry – I get:
      Run-time error ‘1004’:
      Method ‘Save as’ of ‘object_workbook’ failed
      • #1279798
        A runtime error is different than a “crash”. The error indicates a problem with saving the workbook, either the name is invalid, or something else along those lines. As PJ indicates we would have to examine the code to see what is going on and possibly an indication of where the code fails (when you get the error you can click [debug] and see the offending line of code…
        Steve
    • #1279775
      Can you post your macro or a sanitized version of your workbook containing the macro?
    • #1279803
      This is a portion of my macro. The runtime error is generated on the last line when there is an existing file with the same name I am using to save the current workbook.
      Private Sub Ok_Click()
      Dim Workrange As Range
      Dim Oldsheet As String
      Dim newsheet As String
      Dim oldworkbook As String
      Dim Saveworkbook As String
      ‘macro to save CSV as an xls & add a sheet & return to the original sheet
      oldworkbook = ActiveWorkbook.Name
      ‘replace csv with xls as file extension
      Saveworkbook = Replace(oldworkbook, “csv”, “xls”)
      ‘save file as xls
      ActiveWorkbook.SaveAs Filename:=Saveworkbook, FileFormat:=xlExcel8
    • #1279805
      What do you want the code to do if the file already exists and the user does NOT want to replace it?
      Steve
      PS you could do something like this:
      Code:
      Option Explicit
        Dim iResponse As Integer
      'macro to save CSV as an xls & add a sheet & return to the original sheet
      'replace csv with xls as file extension
      Saveworkbook = Replace(oldworkbook, "csv", "xls")
      'save file as xls
      'check if file exists
      If Dir(Saveworkbook) = "" Then
        'file does not exist
      Else
        'File exists: Check if replacing
        iResponse = MsgBox(prompt:="File Already exists. Do you want to replace it?", _
          Buttons:=vbYesNo + vbQuestion)
          'Replace, ignore XL message
          If iResponse = vbYes Then
            Application.DisplayAlerts = False
            Application.DisplayAlerts = True
          Else
            'File not saved...
            MsgBox "File Not saved..."
    • #1279807
      I’d like the macro to continue as if nothing happened. In other words, if I click on “no” or “cancel” I don’t want the code to do anything- just proceed as if nothing happened.
    • #1279812
      Thanks sdckapr! That works perfectly. I am new to VBA and don’t have an extensive knowledge of the syntax yet. I never would have come up with that solution. I will study it so I can get a little bit better. Thanks Again!
      Arjay
    • #1279819
      Glad that it worked.
      Steve
    Reply To: Problem with responding to “Save As” dialog box
