Hopefully someone can help. The Print Layout view is not displaying correctly and is not showing the space for the top and bottom margins – i.e. text starts immediately at the “top of the page” and finishes at the “bottom of the page”, despite having top and bottom margins set correctly. See the attachment for an example. If you do a print preview / or even a print, the margin areas show correctly – so it only seems to affect the display. Other view modes seem to work correctly.
If I start Winword with the /a switch it works correctly, but of course this doesn’t load my NORMAL.DOT so I end up having to make all the same changes each and everytime. I’ve been through and deleted and recreated the NORMAL.DOT, made sure there are no other templates / startup documents, tried reparing Word under Add/Remove programs, run Winword /r switch (I’m not sure if this is the same as repairing), and have even used OfficeIns (http://www.nirsoft.net) to disable all of the defined add-ins (Google Search, Adobe PDF, etc)
Does anyone have any ideas of how I can fix this?
