Running W10 V1903 Home on an older Dell Vostro 220 as a 32 bit system. My problem existed with V1803 as well. Defined accounts are Admin, Me, Lynne, Visitor and Guest. Only Admin account has Admin priviledge. FF is the default browser for Admin, but I’m unable to set it as the default for my account or Visitor. Haven’t tried the others but I expect the same. Only options are the MS browsers. I placed a shortcut on my task bar so that I can use FF, but browser links always go to Edge. How can I install FF to all accounts so that I can choose it as the default for each account?
Problem setting default browser
Home » Forums » AskWoody support » Windows » Windows 10 » Windows 10 versions – no longer supported » Windows 10 version 1903 – May 2019 Update » Problem setting default browser
- This topic has 10 replies, 7 voices, and was last updated 5 years, 8 months ago.
Viewing 4 reply threadsAuthorReplies-
AskWoody_MVPAugust 18, 2019 at 4:17 pm #1911466Install as Administrator?
Bob99
AskWoody MVPAugust 18, 2019 at 5:13 pm #1911481Instead of going through Control Panel or the Settings panel within Win10, try setting it as the default from within a running instance of Firefox.
Go ahead and launch Firefox with your regular user account. Now that it’s up and running, click the “hamburger” icon on the far right side of the browser’s window, to the right of the URL/address bar. Select the item labeled “Options” with the gear-looking symbol next to it. You should now click the selection on the left side of the screen labeled “General” with the gear-looking symbol next to it. However, that tab/screen should open by default whenever you go into the Options menu.
On the “General” settings screen the first choice at the top is “Startup”. Under that choice are two sets of settings, one for restoring the last session, the other for making sure Firefox is the default browser (“Always check if Firefox is your default browser”). Click the box to make Firefox the default browser, and you should be all set.
Make sure to repeat these few steps with all of the other accounts that you want to have FF as the default browser.
Let us know if this doesn’t work. @Microfix is one of the MVP’s here and is quite good at solving issues with Firefox, so he may be able to help if this suggestion doesn’t work.
pnshldn
AskWoody PlusAugust 20, 2019 at 10:25 am #1913222FF is not able to set the default to FF. I end up in the Settings Default Apps page with Browser highlighted on Microsoft Edge. Other choices are IE or something from MS Store. I don’t believe this is a FF issue but something about W10 and non privileged accounts. My version of FF is 68.0.2 which I believe is latest. I tried reinstalling FF from Admin account but that did not work. I’ll try temporarily adding Admin privilege to user account to see if that works.
Bertram Pincus
BlockedAugust 19, 2019 at 3:56 am #1911657which FFversion? Newer you should be Ok. But older, pre-v56+/-, you may have issues (esp. if you also installed a FF fork like WF or Palemoon).
*Edit: and of course check your Target. Taskbar Icon, Properties, Target should be going to Cprogramfiles\mozilla firefox\firefox.exe (default location, I think -but I use a Portable)
This reply was modified 5 years, 8 months ago by
Bertram Pincus.
GuestAugust 19, 2019 at 9:22 am #1911946Goofy things like this are why I always set every account as admin until I finish installing, customizing and optimizing things. After that I go back and change the account to limited user.
MrJimPhelps
AskWoody MVPAugust 19, 2019 at 10:17 am #1911996Goofy things like this are why I always set every account as admin until I finish installing, customizing and optimizing things. After that I go back and change the account to limited user.
Doing the above is an excellent way of making sure that everything is set up the way you want it to be.
pnshldn
AskWoody PlusAugust 20, 2019 at 11:23 am #1913235I gave Admin privilege to my user account, signed out, restarted, signed in and verified Admin privilege. Ran downloaded and reinstalled FF. Got the “not your default …”, clicked “make it my default, and ENDED UP WITH EXACTLY THE SAME PROBLEM: NO FF AS A CHOICE FOR DEFAULT BROWSER. Yet the newly reinstalled FF put a shortcut on my desktop that works, but I still can’t set FF to be the default. What the h…. is going on?
AskWoody MVPAugust 20, 2019 at 12:19 pm #1913250In an Admin account, do the following steps in this link:
https://support.mozilla.org/en-US/kb/how-change-your-default-browser-windows-10
It may also be attributed to MS Edge preload on startup: try disabling this (if you don’t use edge) then do the first link again.
https://www.howtogeek.com/397718/how-to-prevent-microsoft-edge-from-preloading-on-windows-10/
Viewing 4 reply threads -
5 hours, 58 minutes ago -
1 hour, 59 minutes ago -
8 hours, 24 minutes ago -
1 hour, 16 minutes ago -
WSDavidO61
3 hours, 6 minutes ago -
PeachesP
3 hours, 18 minutes ago -
The local account tax
33 minutes ago -
15 hours ago -
7 hours, 32 minutes ago -
MP Support
1 day, 7 hours ago -
10 hours, 9 minutes ago -
58 minutes ago -
14 hours, 36 minutes ago -
Replacing Skype
3 hours, 9 minutes ago -
nhsj
51 minutes ago -
SheltieMom
2 hours, 55 minutes ago -
3 days, 7 hours ago -
3 days, 9 hours ago -
Peobody
1 day, 21 hours ago -
LarryK
3 days, 10 hours ago -
Serge Carniol
4 days, 1 hour ago -
4 days, 4 hours ago -
Inetpub can be tricked
2 days, 12 hours ago -
2 days, 22 hours ago -
4 days, 8 hours ago -
1 day, 17 hours ago
