• Problem Running Setup? (A2k (9.0.4402) SR-1)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Problem Running Setup? (A2k (9.0.4402) SR-1)
    A2k (9.0.4402) SR-1
    Using Microsoft Office 2000 Developer 6.00.8433
    Computer A Win 98 4.10.1998 (Development computer)
    Computer B Win 98 4.10.2222 (has no Microsoft Office programs)
    Trying to install a runtime application on Computer B
    After creating Package and Deployment on Computer A, I run Setup.exe on Computer B from Computer A network folder, I get the following message.
    Copying 7 files:
    ODESTKIT.DLL 101,888 11/03/98
    COMCAT.DLL 22,288 11/03/98
    STDOLE2.TLB 17,920 03/10/99
    ASYCFILT.DLL 147,728 03/10/99
    OLEPRO32.DLL 164,112 03/10/99
    OLEAUT32.DLL 598,288 03/10/99
    MSVBVM60.DLL 1,384,448 11/04/99
    Setup cannot continue because some system files are out of date on your system. Click OK if you would like setup to update these files for you now. You will need to restart Windows before you can run setup again. Click cancel to exit setup without updating your system files. OK Cancel
    I tried this a number of times with same error message.
    I checked the versions of Computer as follows:
    C:WindowsSystemODESTKIT.DLL 101,888 11/03/98
    C:Access2kPackageSupportODESTKIT.DLL 101,888 11/03/98
    C:WindowsSystemCOMCAT.DLL 6,144 09/01/98
    C:Access2kPackageSupportCOMCAT.DLL 22,288 11/03/98
    C:WindowsSystemSTDOLE2.TLB 16,896 01/20/00
    C:Access2kPackageDeploySTDOLE2.TLB 17,920 03/10/99
    C:WindowsSystemASYCFILT.DLL 143,632 01/20/00
    C:Access2kPackageDeployASYCFILT.DLL 147,728 03/10/99
    C:WindowsSystemOLEPRO32.DLL 164,112 01/20/00
    C:Access2kPackageDeployOLEPRO32.DLL 164,112 03/10/99
    C:WindowsSystemOLEAUT32.DLL 614,672 01/20/00
    C:Access2kPackageDeployOLEPRO32.DLL 598,288 03/10/99
    C:WindowsSystemMSVBVM60.DLL 1,384,448 11/04/99
    C:Access2kPackageDeployOLEPRO32.DLL 1,384,448 11/04/99
    Has there been any updates that I should be aware of?
    Any thoughts?
    Thanks, John Graves
    • #566631
      There was an SR-1 for the MOD as well as the one for Office. Did you apply it? If not, take a look at MSKB article .
      It">Q193034, which might be related. Q255516 applies to Windows 2000, but the symptoms sound exactly like what you described.
    Reply To: Problem Running Setup? (A2k (9.0.4402) SR-1)
