• Problem Populating Combo? (A2k (9.0.4402) SR-1)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Problem Populating Combo? (A2k (9.0.4402) SR-1)
    A2k (9.0.4402) SR-1
    I have a Criteria Form with two combo boxes
    FieldCombo ValueCombo
    strBusinessCity Albany
    Buffalo
    Newark
    Rochester
    strBusinessState NJ
    NY
    The operator selects a table field name from the FieldCombo box.
    I then want to populate the ValueCombo box with the distinct values of the field selected (FieldCombo) as illustrated with the examples above.
    Having a problem building the Row Source in the Query Grid for ValueCombo
    This is what I have, the following does not return any rows:
    SELECT DISTINCT [Forms]![frmCriteriaContractor]![FieldCombo] AS Expr1 FROM qrytblContractor;
    The following works. I
    • #553322
      Can you clarify some things? Are you saying you want the user to select a state from combo “A”, which will then dynamically populate combo “B” with the appropriate cities? Seems like, for one thing, you need a “where” clause in your sql. Something like : Select city from tablex where state = ComboA (the value in ComboA that the user has selected)
    • #553485
      Hi John,
      If I understand you correctly, you need some code to do what you want. Something like this in the AfterUpdate event of your field list combo should do it:
      Private Sub cboFieldList_AfterUpdate()
          With Me.cboValueList
              .RowSource = "SELECT DISTINCT " & Me.cboFieldList & " FROM qtblContractors"
              .Requery
          End With
      where cboFieldList is the name of your fieldnames combo, cboValueList is the name of your other combo and qtblContractors is the name of your query/table.
      Hope that helps.
    Reply To: Problem Populating Combo? (A2k (9.0.4402) SR-1)
