I have Win 98 Se and Word 2000. I have some floppys that have word documents on them. 99.9 % of the info on these floppys are text. What I am having a problem with is it takes a very long time for these floppys to open. I put in a new floppy and have the same problem. Is there something else that can cause this slowness. I even changed the memory to higher ram. Could Macros have anything to do with this problem?
Problem opening 3 1/2 floppys
Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » Problem opening 3 1/2 floppys
- This topic has 5 replies, 4 voices, and was last updated 19 years, 4 months ago.
Viewing 0 reply threadsAuthorReplies-
WSWyllyWylly
AskWoody LoungerJanuary 13, 2006 at 2:02 am #994374Floppies are notoriously unreliable. It’s doubtful that the content is the problem; you’re having the same problem with multiple disks, which to me indicates the drive itself. Floppy drives suffer from head alignment problems among other things. Try this as a test: put one of these disks into a different computer and see what kind of access time you get. I’ve had floppies that would not read in one computer work just fine in a neighboring system.
As long as you are able to read the disks, I would strongly urge you to copy their contents to a more reliable medium – hard disk, CD, USB drive – before the disks become unusable.
WSpauliez
WSLyra_J
WSpauliez
AskWoody LoungerJanuary 14, 2006 at 8:13 am #994617 -
WSbigaldoc
AskWoody LoungerJanuary 14, 2006 at 9:23 am #994622You realize that you’ve just added a new twist to this thread that was not clear in your original post! Is it clear that you’re saying you have some older disks that open quickly and the ones that are giving you trouble are new (purchase time)? If that is the case, it sounds like you’ve gotten a bad or less than acceptable batch of floppies.
Viewing 0 reply threads -
46 minutes ago -
PL1
7 hours, 15 minutes ago -
9 hours, 24 minutes ago -
drmark
5 hours, 37 minutes ago -
drmark
7 hours, 35 minutes ago -
mbennett555
5 hours, 9 minutes ago -
Office gets current release
7 hours, 47 minutes ago -
1 day, 21 hours ago -
Stop the OneDrive defaults
1 day, 22 hours ago -
2 days, 8 hours ago -
X Suspends Encrypted DMs
2 days, 10 hours ago -
2 days, 11 hours ago -
2 days, 12 hours ago -
M W Leijendekker
2 days ago -
Enabling Secureboot
ITguy
2 days, 7 hours ago -
2 days, 20 hours ago -
No more rounded corners??
2 days, 16 hours ago -
Android 15 and IPV6
2 days, 5 hours ago -
3 days, 8 hours ago -
3 days, 11 hours ago -
3 days, 5 hours ago -
3 days, 18 hours ago -
May preview updates
2 days, 21 hours ago -
3 days, 10 hours ago -
crown
3 days, 7 hours ago -
jkitc
Botswana12
4 days, 10 hours ago
