• Printer Going ‘Offline’ (Business, Ultimate (6000)
    Home » Forums » AskWoody support » Windows » Windows Vista, XP and earlier » Questions: Vista, XP back to 3.1 » Printer Going ‘Offline’ (Business, Ultimate (6000)
    Whenever the DSL signal drops or I restart my router, any printers that are connected to the router become unusable but only under Vista – XP picks them up without problem. In the title bar of the printer status window, the name of the printer has ” – Offline” appended to it. The Printer frop-down menu does not show a check next to “Use Printer Offline”.In fact, when I check Use Printer Offline, the title shows that the printer is ” – Offline Offline”.
    The only solution to this problem I have found is install a new instance of the printer and delete the “Offline” one and requeue the documents to be printed. It would be great if I could move the documents to the new printer. It would be superb if I could just flip the Offline/Online switch that Vista has somewhere … smile
    Any solution ideas other than the brute-force method described above?
    Thanks,
    • #1097617
      Do the printers have fixed IP addresses?
      • #1098299
        Sorry for the tardy response. For some reason I didn’t receive an e-mail notification that someone had replied.
        Answer – no. All addresses (printers and systems) are DHCP. I also noticed today that my XP system isn’t seeing any router-connected printers. i’m beginning to wonder if the router has gone haywire and decided to do its own thing.
        Many thanks for your response,
        • #1098305
          I sent you a PM a few days ago. The e-mail address in your profile is not valid any more. Please edit your profile and enter your current e-mail address. Then subscribe to notifications again.
        • #1098354
          You ought to try setting static IP addresses for the printers.
    Reply To: Printer Going ‘Offline’ (Business, Ultimate (6000)
